Data: 6.08.2011
Format: 3 bitwy po 2400 pkt
Wpisowe: 10zł
Nagrody: Zależne od frekwencji
Limit miejsc: 16
Adres: ul. Kochanowskiego 3/1 , Kraków
Tutaj link jak trafić:
http://www.truelegion.fora.pl/forum-glo ... ie,69.html
Start turnieju: równo 10:00 zaczynamy grać bitwy (zapisy od 9:45)
Zakończenie turnieju 18:00
Czas na bitwę: 2,5h
Turniej zgłoszony do ligi.
Obowiązują zasady 8 edycji WFB oraz ograniczenia EURO:
Rules changes:
- Dark Elf Sorceresses cannot cast spells using more dice than normal wizards .
General Restrictions:
Army used can be any of the currently published GW Army books.
An army may have up to 5 war machines and template weapons. Warmachines that use a template count as a single choice in this regard. All template weapons (from magic items, abilities, etc.) count, except for spells.
Magic Restrictions:
- Apart from Winds of magic and Channeling, an army may only generate 2 PD/DD per magic phase.
- “Count as” items/abilities may never exceed a cumulative 2 PD/DD per phase. This means that if you take the Book of Hoeth, you may not take any other items that “count as adding PD/DD”
Detailed description
Apart from winds of magic and through the channeling rule, an army may only ever add 2 dice to its power or dispel pool in each magic phase. Any dice added to the pool, regardless of source (generated, stolen, stored from previous magic phases, generated by magic items/abilities to boost spellcasting before or after the casting attempt, produced by spells, lore abilities, and so on) count. Excess dice are simply discarded and cannot be used in any way (i.e. - they can’t be stored).
Item restrictions:
- Power Scroll is banned
- Each Loremaster ability counts as generating 1 PD each magic phase
Army Specific Restrictions:
Beastmen: Beastmen armies have an extra 200 points for their roster (2600 total). All victory points scored against this army are decreased by 10% (excluding bonus points for banners, general, etc.).
Bretts: No Restrictions
Dark Elves: Hydra is a 0-1 choice. Max. 35 repeater Crossbows in the army (regardless of who carries them). Repeater Bolt Throwers 0-2. Flying units (inc. characters on flying steeds) in the army limited to 0-3. Shades max 20 models per army. Dreadlord on pegasus cannot take Crown of Command.
Dwarves: Each spellbreaker/spelleater rune counts as +1 DD. Grudge Throwers are a 0-2 choice; May generate Max. +4 dispel dice instead of +2
DOC: Max. 28 Models per unit; Flamers are a 0-1 choice. All daemonic gifts are 0-1. Bloodletters and Herald of Khorne are 0-3 total. Daemonic Battle Standard can take either daemonic icon or gifts. Lord of Change counts as 1 PD
Empire: Steam Tank counts as a war machine; Tank, Rocket battery and Engineers are 0-1 choices
High Elves: Max. 500 points or 40 models per unit; Vortex Shard counts as +1DD; Book of Hoeth counts as 2PD and 2 DD; Banner of the World Dragon counts as +1 DD
Lizardmen: Salamanders are a 0-1 Choice ; Terradons and Stegadons (any kind) are 0-2 choices; Beclaming Cogitations counts as +2DD; Cupped hands counts as +2PD
Ogres: Ogre Kingdoms armies have an extra 200 points for their roster (2600 total). All victory points scored against this army are decreased by 10% (excluding bonus points for banners, general, etc.). Rhinox Riders are allowed.
O&G: Night Goblin Shamans are 0-3 (max 3 of any kind of NG shaman); mushroom dice do not count as power dice in regard to the PD limit.
Skaven: All Skaven rare choices 0-1; Gutter runners are a 0-2 choice; Engineers are a 0-3 choice;
Vampires: Wraiths and Varghulf are 0-1 choices. Wraith unit size - maximum 5 models. Army may have maximum two units (total) of: wraiths, black coach or spirit hosts. Army may include a maximum of two of the following: Helm of Commandment, Master of the Black Arts, Drakenhoff Banner.
TK: Neferra's Scrolls of Mighty Incantations counts as 2 PD AND 2 DD. Hierotitan is worth 1 PD so long as it's alive. Sphinxes of all kinds: 0-3 per army
WE: Wand of Wych Elm counts as +1 DD
Warriors of Chaos: Hellcannon is a 0-1 choice. Infernal Puppet counts as +1 PD and +2DD; Tendrils of Tzeench and Conjoined Homunculus both counts as +1 PD. Favour of the Gods cannot be taken by a Champion of a Chosen of Tzeentch unit
Scoring
We are (still) considering the following victory points mechanic, and encourage you to test it and provide feedback:
In both cases, bonuses (for generals, banners, etc.) are not counted towards the 50%.
Progi:
0-150 10-10
151-300 - 11-9
301-450 - 12-8
451-600 - 13-7
601-750 - 14-6
751-900 – 15-5
901-1050 – 16-6
1051-1200- 17-3
1201-1350- 18-2
1351-1500-19-1
1500+ - 20/0
Gramy scenariusze w kolejności:
1. Dawn attack
2. Breakthrough:
Cel: przekroczenie swoimi oddziałami połowy pola bitwy i utrzymanie swoich oddziałów w tej strefie.
Wynik bitwy: określa się licząc wyłącznie wartość punktową nieuciekających oddziałów własnych, które na koniec bitwy są na połowie stołu należącej do przeciwnika (oddział stoi na tej połowie gdzie jest większa część oddziału/modelu). Liczy się finalną wartość oddziału (więc jeśli na koniec bitwy oddział jest społowiony, to liczy się za niego tylko połowę punktów).
Progi co 150 punktów
3. Blood and Glory:
Bitwa kończy się w momencie (natychmiast), kiedy odporność armii przeciwnika spada do 3 lub niżej (przez stratę generała lub sztandarów).
Wynik bitwy określa się następująco:
- zwycięstwo w pierwszej turze: 20-0
- zwycięstwo w drugiej turze: 20-0
- zwycięstwo w trzeciej turze: 19-1
- zwycięstwo w czwartej turze: 18-2
- zwycięstwo w piątej turze: 17-3
- zwycięstwo w szóstej turze: 16-4
W przypadku nie wypełnienia scenariusza, wynik 10-10 modyfikuje się o zdobyte punkty złamania. Wynik nie może być wyższy niż 15-5.
Zgłoszenie powinno zawierać imię, nazwisko lub ksywkę i nr ID ze strony ligowej http://ranking.wfb-pol.org/players.php
Nie ma oceny hobbystycznej, za zgłoszenie się (w temacie , przez pw do mnie) w terminie do 1.08.2011 dodatkowe +3pkt do klasyfikacji generalnej (będę egzekwował te punkty)
Na turnieju będą dopuszczone proxy w ramach przyzwoitości - max 25 modeli (maszyna liczy się jako jeden oddział)
Jeżeli nie masz odpowiednich figurek, napisz do mnie może uda się je załatwić, dysponujemy ich dosyć dużą ilością. Tak samo w przypadku problemów lub wątpliwości z rozpiską można do mnie pisać.
ZGŁOSZENIA:
1. Sevi HE
2. Xier DoCh
3. Kotson TK
4. Undead TK
5. Dibo BoCh
6. Legion Emp
7. Michał Bret
8. Charki O&G
9. Fluffy O&G
10. Kuba WE
11. Gremlin WE
