Trollowy Grill 29.04.2012 Koszalin 2400 ETC
Moderatorzy: Laik, Dymitr
JaSzczuras
Post autor: JaSzczuras »
Termin: 29.04.2012. Niedziela
Bitwy: 3
Zasady: 8 edycja + uściślenia sędziowskie http://strony.aster.pl/barbaros/uscislenia.html
Format: 2400 nowe ETC
Stoły i makiety: stoły 72x48 cali.
Ranga turnieju: lokalny
Miejsce turnieju: Koszaliński Klub Osiedlowy "Na skarpie" - ul. Na skarpie 17
Liczba miejsc: 24
Sędzia: Sędzia Główny: Rule Book, Szczur
Proxy: Dopuszczone w ramach rozsądku
Wpisowe: 5zł
Zgłoszenia: Border Princes -> http://forum.wfb-pol.org/viewtopic.php?f=24&t=34870
Zasady:
Rules changes:
I. General Restrictions:
2400 Points.
Army used can be any of the currently published GW Army books. Forge World based army lists & units may not be used on the event, except for Chaos Dwarves.
An army may have up to 4 war machines and shooting template weapons. Warmachines that use a template count as a single choice in this regard. All template weapons (from magic items, abilities, etc.) count, except for spells. Bolt thr. count as ½ a war machine(round up).
All BSBs can take all the Equipment, their unit type has acces to as if they weren't BSBs.
Magic Restrictions:
- Player can use maximum 5 PD to cast a spell. For death & shadow spells this max is lowered to 4 power dice.
- An army may use up to 12 PD during each phase.
Detailed description
Apart from Winds of magic, an army may only use 2 PD/DD per magic phase (unless army restrictions specify otherwise). After an army generates the limit all the other extra dice are discarded. This includes channeled PD/DD.
Item restrictions:
Army Specific Restrictions:
Beastmen: Beastmen armies have an extra 200 points for their roster (2600 total), All victory points scored against this army are decreased by 10% (excluding bonus points for banners, general, etc.), Beastmen can generate 3 extra pd instead of 2. Can use 4 instead of 3 same core units and have a unit cap of 50 models per unit and point cap on units 550 instead of 450 pts.
Bretonnia: No Restrictions
Chaos Dwarfs
Hellcannon, Iron daemon are each 0-1.
Iron daemon, kdai destroyer and every model with hashut lore count as war machines
Chalice of darkness counts as 2 pd
Max 3 outof lore of Hashut, Str. 5 war machine shooting templates, Kdai destroyer, iron daemons.
Chalice or Sorcerer Prophet
Lore of Hashut can be cast with max 4 PD.
Dark Elves: Hydra is a 0-1 choice. Max. 35 repeater Crossbows (including characters and excluding chariots) in the army. Repeater Bolt Throwers 0-2. Harpies are 0-2. Shades max 20 models per army, Pendant of khaeleth cannot be taken by lord characters, player may take up to 2 of following: Pendant of khaeleth\Crown of command\any number of wizards using death & shadow magic\Cauldron of Blood\Hydra.
Dwarfs: Each spellbreaker/spelleater rune counts as +1 DD. Grudge Throwers are a 0-2 choice; May generate Max. +4 dispel dice instead of +2; gyrocopter doesn't count for max 4 war machine/template.
Daemons of Chaos
Max. 30 Models per unit; All daemonic gifts are 0-1. Daemonic Battle Standard can have gifts if his magic banner does not cost over 50pts. Siren song cannot be taken by Herald of Slaanesh. Max 6 flamers in the army. MOS: If taken by herald it gives you 'loremaster: Lore of Tzeentch' or the ability to randomly determine spells(as a normal lvl 2) from any of the 8 rulebook lores.
The Empire: Steam tank 0-1. Cannons 0-3, steam stank count as a cannon.
High Elves: High Elves armies have an extra 100 points for their roster (2500 total); High elves army can generate extra 3 powerdice instead of 2; Vortex Shard counts as +1DD; Book of Hoeth counts as 3PD and 2 DD; Banner of the World Dragon counts as +1 DD
Lizardmen: Salamanders are a 0-1 Choice;Scar-Veterans 0-2, player may take up to 2 of following: Beclaming Cogitations\ Focus of Mystery\ Focused Rumination \Higher State of Consciusness; Beclaming Cogitations counts as +2DD; Cupped hands of the Old Ones counts as +2PD; Higher State of Consciusness counts as 2 discplines (takes two slots, but cost same points); Crown of Command & Higher State of Consciousness cannot be taken on 1 model; A maximum total of 6 Skink, Chameleon skinks and Skink Cohorts units combined maybe taken in an army (Cohorts containing kroxigor or numbering above 20 models do not count for this restriction). Max 1 of these in army death lore/bane head/feedback scroll
Ogre Kingdoms: Hellheart counts as 2dd & 1pd, Greedyfist on death mage counts as 2dd, Rune Maw Banner counts as 1dd. Each leadbelcher/ sniper maneater with pistol(s) counts as 3 models towards to shooting cap. Max 3 combined units of Mournfang Cav & Ironblaster. 0-1 Ironblaster.
Orcs&Goblins: Night Goblin Shamans mushroom dice do not count as power dice in regard to the PD limit. Maximum model cap is 60 models per unit. +100 pts.
Skaven: All Skaven rare choices 0-1; Gutter runners are limited by 2 units & 20 models total; Engineers are a 0-3 choice; Can take max 2 of the following: doom rocket, brass orb, storm banner;
Vampire Counts
Master of black arts & blasphemous tome upgradeare 1pd each. 0- 3 etheral units (incl. Heroes). 0-2 red fury and/or quickblood abilities. 0-4 howls (death shriek counts as 2). 0-1 Terrorgheist , a max of 4 flying units, max 15 mounted characters and black knights combined
Tomb Kings: Tomb King armies have an extra 200 points for their roster (2600 total), All victory points scored against this army are decreased by 10% (excluding bonus points for banners, general, etc.), Neferra's Scrolls of Mighty Incantations counts as 2 PD AND 2 DD. Hierotitan is worth 1 PD so long as it's alive. Sphinxes of all kinds: 0-3 per army. Tomb Kings may generate up to 3 power dice per phase
Wood Elves: Wood Elf armies have an extra 200 points for their roster (2600 total) All victory points scored against this army are decreased by 10% (excluding bonus points for banners, general, etc.), Wood Elves can take 4 of the same core unit instead of 3, Wand of Wych Elm counts as +1 DD; Only Glade guards (including scouts) count for max of 45 models with shooting weapons
Warriors of Chaos: Hellcannon is a 0-1 choice. Infernal Puppet counts as +1 PD and +2DD; Tendrils of Tzeench and Conjoined Homunculus both counts as +1 PD. If you have warriors, knights and or chosen with marks of tzeentch in army then you can take max 2 out of 3 of warshrines and favor of the gods (2xwarshrines or warshrine and favor of the gods).
II. Pairings.
1. (1&2th match up of Team A v. Team B)
Both Teams put up 1 army.
Both Teams put up 2 opponents
Both Teams choose their match
2. (3&4)
3. (5&6)
4. (7&8)
Not chosen army of Team A plays against Team B last army («in hand»)
Not chosen army of Team B plays against Team A last army («in hand»)
III. Scoring
0-20 Victory-Points per game
60-100 Battle-Points per team (in all rounds)
(The losing team gets 60 points even if they score less – the winning team never gets more than 100 points, even if they score more. Real Battle Points [non-limited by the 100-60 bracket] will be used in case of the Battle Points tie as tie-breaker.)
Victory points to Battle points per game:
0-150 Victory-Points difference - 10-10
151-300 - 11-9
301-450 - 12-8
451-600 - 13-7
601-750 - 14-6
751-900 – 15-5
901-1050 – 16-4
1051-1200- 17-3
1201-1350- 18-2
1351-1500-19-1
1500+ - 20/0
IV. Scenarios
Pitched battle scenario
V. Simple Line of Sight
cumulative).
- When such a unit is doing the shooting there are no to hit penalties for interfering or non-blocking
units or terrain, other than interfering woods.
Rozkład jazdy:
9.30 - 10.00 - zapisy i formowanie sali pod nasze stoły - prośba niech się ktoś pojawi :P
10.00 - 12.30 pierwsza bitewka - scenariusz ten co zwykle
12.30 - 16.00 druga bitewka - scenariusz tęgie garbowanie skóry czyt. bitwa pierwsza
16.00 - 18.30 trzecia bitewka - scenariusz - prostowanie kręgosłupa moralnego - czyt. batteline
19.00 - Szczur zamyka salę i wytacza się z klubu :P
JaSzczuras
Zapisani:
Rogaś
Zaleś
Szczur
Tutka
Bobo
Artur
Johny
Stadej
GrimgorIronhide
Post autor: GrimgorIronhide »
JaSzczuras pisze:prosiłbym o ponowne wpisanie się osób chętnych w temacie na BP - link u góry aby zwiększyć ruch w temacie
Oki, UWAGA :!: czynię ruch (spocznij).
Bananovitch
Post autor: Bananovitch »
Takoż ;)
http://laiglenid.blogspot.com/-jak Bananek Bretońców malował.
Jagal
Post autor: Jagal »
Czemu znowu w terminie mastera! ;/
Metalowi quesci,
4ed rycerze na piechotę.
JaSzczuras
Jagal pisze:Czemu znowu w terminie mastera! ;/
Następnym razem nie będzie w terminie mastera, poza tym to drużynówka ten master więc Ci co nie jadą mogą zajrzeć do Nas.
Szczecin już składa ekipę :)
