9 age - Pytania ogolne
Re: 9 age - Pytania ogolne
Mógłby ktoś mi podać link do aktualnych zasad 9th Age (czy też strony, gdzie to 'tworzą') oraz KoW2 (jeśli jest dostępne free).
Podobno w grudni jest master we Wrocławiu, to przydałoby się ogarnąć zasady
http://www.the-ninth-age.com/index.php? ... d43ad42ef1
Mitril mail + ironfist dają as1+? Nie łączy się z tarczami, ale ironfist nie jest teraz tarczą, czyli powinno działać.
Dzięki KoW2 już sobie znalazłem
Przecież wszystko masz w opisie zasadyVolley Fire
Shooting Weapons with this Special Rule or Shooting Attacks from models with this Special Rule ignore
intervening models for Cover purposes when shooting. (However, they don't ignore Terrain and must still be
able to draw a Line of Sight to their target). Furthermore, (unless making a Stand and Shoot Charge Reaction) if
the Unit hasn't moved in the last Movement Phase, all models with a Volley Fire Shooting Weapon may shoot
(even if they are further back than the usual first two ranks allowed to shoot). If a multipart model has this rule,
then the rule is only applied to the part of the model that has the rule.
Od 4000 w górę ograniczenia podwajasz, na 1500 i w dół zmniejszasz o połowę.
ktoś pisał w 9th w dyskusji ogólnej ze można na magic weapon dać ogniste ataki np. ze sztandaru na oddziale gdzie to można znaleźć w rulebooku?
Aha okPocisk pisze:Nie można znaleźć zakazu
MAGICAL MOVE
All moves made during the Magic Phase are Magical Moves. The move is performed as if in the Remaining Moves
sub-phase, which means that it follows the same rules and restrictions as if this was a new Remaining Moves
sub-phase (for example, fleeing Units or Units in combat cannot move). Actions that a Unit could normally do in
the Remaining Moves sub-phase can be made (such as wheeling, reforming, joining Units, leaving Units and so
on), except that the Unit cannot march. Magical movement always has a given limit (for example, "target may
make a 12" Magical Move"): This distance is used instead of the target's Movement Characteristic (remember
that no marching is allowed). If a Unit has already done a Magical Move in this Magic Phase, it cannot move
again.
