Border Princes
Border Princes
Niezależne Forum WFB/9th Age
Teraz jest 23 wrz 2019, o 17:16
Strefa czasowa: UTC + 1
Utwórz nowy wątek Ten wątek jest zablokowany. Nie możesz w nim pisać ani edytować postów.  [ Posty: 1 ]
Autor Wiadomość
 Tytuł: Zasady specjalne armii - Imperium
PostNapisane: 14 lut 2013, o 20:48
Avatar użytkownika
Dołączył(a): 27 lut 2007, o 15:49
ZASADY ARMIJNE:
Regimental Units (RU) & Detachments (D.):
- D. cannot be taken without RU
- D. size: up of 5 to a max. of half the number of models in the RU
- D. can purchase any equipment upgrades listed in their army list entries, but they may not include Command group
- points cost of a D., and any upgrades it has taken, counts towards the points total of the same category as the RU they are purchased with.
- Only units with RU special rule can have D.
- Only units with D. special rule can be detachments
- as long as the RU is not fleeing, their D. that have at least one model within 3" use the RU Leadership, unless it would otherwise be higher
- If RU has any of the special rules listed below, they confer the same special rule onto alll of their D. whilst they have at least one model within 3"; s.rules: FRENZY, HATRED, HOLD THE LINE, IMMUNE TO PSYCHOLOGY, STUBBORN, STEADFAST, STUPIDITY
Detachments special rules:
- D. must be deployed at the same time as RU with at least one model from the D. within 3'
- D. always arrives into battle in the same time as RU
- Support fire & counter charge imediately when RU declares stand & shoot or hold (but not flee) reaction; but only when D. is within 3" from RU.
- Support fire (only shooting D.), immediately as Stand & shoot reaction
- Counter charge (all D.); if it declares it, D. immediately makes move resolved out of sequence after oponents move all charging units; enemy does not get to make charge reactions against counter charge
SPIS ZASAD SPECJALNYCH Z WYJAŚNIENIEM W AB EMPIRE
Mechanical steed (MS): -Unreliable; roll d6 for each MS at the start of each of your Movement phases. on 2-6 MS is unafected, on 1 the MS movement characteristic is reduced by d3 to a minimum of 1.
Full plate armour: 4+ armour save combinet with other as normal
Hold the line! (General & Captain): unit including General or Captain rolls 3d6 uses two lowest score for Break Tests
Imperial Griffon:
Bloodroar: enemy unit rolls additional d6 discarding the lowest for Fear & Terror tests
Two Heads: additional atack with +1 to Hit against models with Large Target rule
Pegasus:
Iron-hard Hooves: re-rolls failed To Wound rolls when making a Stomp
Swift as the Wind: re-rolls '1 when charging unless joining a unit
Master Engineers:
Master of Ballistics: if not fleeing, within 3", one war machine can re-roll one artillery dice (but not for a bounce); you must nominate which war machine will used this; if used M.Engineer cannot fire his own weapon;
Stand Back, Sir! : Look out sir rule just like for unit & lone character, the hit is instead resolved against the nearest friendly war machine
Warrior Priest
Divine Power: channel power & dispell dice just like wizards
Righteous Fury: WP and any unit he is in has Hatred rule but not the mounts & characters
Battle Prayers: augment spells, casts just like bound spells (Power level 3) with innate ability rule; any Regimental Unit, any of its Detachments within 3" are also targeted by the spell
With Hunter
Accusation: after deployment, before first turn, nominate a single model of opponent; WH has reroll to hit , killing blow and sniper special rule against this;
Grim Resolve: WH automatically passes Fear test (but not unit); WH and unit he is with threat Terror opponents like Fear causing
Tools of Judgement: when atacking Wizard or models with Undead, Nehekharan Undead or Deamonic special rule WH can re-rolls failed rolls To Wound.
Flagellants:
The end is nigh!: in base contact with enemy, at the start of CC phase, F. imediately suffers d6 S3 hits; this do not count towards combat resolution. If one model is removed, unit gains special rules listed below until the end current phase: 1- re-rolls To Hit, 2-3 - re-rolls To Hit and To Wound, 4+ - +1Toughness, & re-rolls To Hit and To Wound
Grand Mater:
Master of Battle: unit of Knightly Orders or Demigryph Knights joined by GM gains Immune to Psychology, lost immediately if GM leaves or die.
War Altar:
Holy Fervour: all friendly empire units within 6" has Hatred even mounts but not characters (zgodnie z erratą do AB Empire ze strony GW, bohaterowie również dostają hatred)
The Power of Sigmar: all Battle Prayers cast by Arch Lector mounted on WA affects friendly units within 6"
Golden Griffon: Enchanted Item, Innate Bound spell, Power Level 4. Arch Lector can cast Banishment (lore of light)
Horn of Sigismund: Enchanted item, WA has Terror
Steam Tank:
Steel Behemoth:
Steam Points:
Steam Engine:
Steam Gun:
Steam Cannon:
Luminark of Hysh
Aura of Protection:
Locus of Hysh
Solheim's Bolt of Illumination:
Celestial Hurricanum:
Locus of Azyr:
Portents of Battle:
Storm of Shemtek:
_________________
"(...)Imperium raz zaatakowane, zawsze kontratakuje(...)"
Kajus C+, Misja Kleopatra
GALERIA
Góra
 Zobacz profil
Wyświetl posty nie starsze niż:  Sortuj wg
Kto przegląda forum
Użytkownicy przeglądający ten dział: Brak zidentyfikowanych użytkowników
Nie możesz rozpoczynać nowych wątków
Nie możesz odpowiadać w wątkach
Nie możesz edytować swoich postów
Nie możesz usuwać swoich postów
Szukaj:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
Template made by DEVPPL - Przyjazne użytkownikom polskie wsparcie phpBB3 - phpBB3.PL
[ Time : 0.024s | 10 Queries | GZIP : Off ]
