OŁ zaprasza na: Majowe DoRZynki !
Moderatorzy: Laik, Dymitr
cahir
Post autor: cahir » 1 maja 2012, o 09:57
Klub Miłośników Gier Bitewnych "Ośmiornica Łódzka" zaprasza na turniej "Majowe DoRZynki". Turniej zgłoszony do Ligi WFB.
1. Informacje ogólne:
- Czas: 20.05.2012
- Miejsce: Łódzki Dom Kultury
- Godzina: zapisy od 9, start pierwszej bitwy o 9.30
- Zasady i format: 2400 EURO, draft #3 (http://warhammer.org.uk/phpBB/viewtopic ... 8&t=100748)
Rules changes:
I. General Restrictions:
2400 Points.
Army used can be any of the currently published GW Army books. Forge World based army lists & units may not be used on the event, except for Chaos Dwarves.
An army may have up to 4 war machines and shooting template weapons. Warmachines that use a template count as a single choice in this regard. All template weapons (from magic items, abilities, etc.) count, except for spells. Bolt thr. count as ½ a war machine(round up).
All BSBs can take all the Equipment, their unit type has acces to as if they weren't BSBs.
Magic Restrictions:
- Player can use maximum 5 PD to cast a spell. For death & shadow spells this max is lowered to 4 power dice.
- An army may use up to 12 PD during each phase.
Detailed description
Apart from Winds of magic, an army may only use 2 PD/DD per magic phase (unless army restrictions specify otherwise). After an army generates the limit all the other extra dice are discarded. This includes channeled PD/DD.
Item restrictions:
Army Specific Restrictions:
Beastmen: Beastmen armies have an extra 200 points for their roster (2600 total), All victory points scored against this army are decreased by 10% (excluding bonus points for banners, general, etc.), Beastmen can generate 3 extra pd instead of 2. Can use 4 instead of 3 same core units and have a unit cap of 50 models per unit and point cap on units 550 instead of 450 pts.
Bretonnia: No Restrictions
Chaos Dwarfs
Hellcannon, Iron daemon are each 0-1.
Iron daemon, kdai destroyer and every model with hashut lore count as war machines
Chalice of darkness counts as 2 pd
Max 3 outof lore of Hashut, Str. 5 war machine shooting templates, Kdai destroyer, iron daemons.
Chalice or Sorcerer Prophet
Lore of Hashut can be cast with max 4 PD.
Dark Elves: Hydra is a 0-1 choice. Max. 35 repeater Crossbows (including characters and excluding chariots) in the army. Repeater Bolt Throwers 0-2. Harpies are 0-2. Shades max 20 models per army, Pendant of khaeleth cannot be taken by lord characters, player may take up to 2 of following: Pendant of khaeleth\Crown of command\any number of wizards using death & shadow magic\Cauldron of Blood\Hydra.
Dwarfs: Each spellbreaker/spelleater rune counts as +1 DD. Grudge Throwers are a 0-2 choice; May generate Max. +4 dispel dice instead of +2; gyrocopter doesn't count for max 4 war machine/template.
Daemons of Chaos
Max. 30 Models per unit; All daemonic gifts are 0-1. Daemonic Battle Standard can have gifts if his magic banner does not cost over 50pts. Siren song cannot be taken by Herald of Slaanesh. Max 6 flamers in the army. MOS: If taken by herald it gives you 'loremaster: Lore of Tzeentch' or the ability to randomly determine spells(as a normal lvl 2) from any of the 8 rulebook lores.
The Empire: Steam tank 0-1. Cannons 0-3, steam stank count as a cannon.
High Elves: High Elves armies have an extra 100 points for their roster (2500 total); High elves army can generate extra 3 powerdice instead of 2; Vortex Shard counts as +1DD; Book of Hoeth counts as 3PD and 2 DD; Banner of the World Dragon counts as +1 DD
Lizardmen: Salamanders are a 0-1 Choice;Scar-Veterans 0-2, player may take up to 2 of following: Beclaming Cogitations\ Focus of Mystery\ Focused Rumination \Higher State of Consciusness; Beclaming Cogitations counts as +2DD; Cupped hands of the Old Ones counts as +2PD; Higher State of Consciusness counts as 2 discplines (takes two slots, but cost same points); Crown of Command & Higher State of Consciousness cannot be taken on 1 model; A maximum total of 6 Skink, Chameleon skinks and Skink Cohorts units combined maybe taken in an army (Cohorts containing kroxigor or numbering above 20 models do not count for this restriction). Max 1 of these in army death lore/bane head/feedback scroll
Ogre Kingdoms: Hellheart counts as 2dd & 1pd, Greedyfist on death mage counts as 2dd, Rune Maw Banner counts as 1dd. Each leadbelcher/ sniper maneater with pistol(s) counts as 3 models towards to shooting cap. Max 3 combined units of Mournfang Cav & Ironblaster. 0-1 Ironblaster.
Orcs&Goblins: Night Goblin Shamans mushroom dice do not count as power dice in regard to the PD limit. Maximum model cap is 60 models per unit. +100 pts.
Skaven: All Skaven rare choices 0-1; Gutter runners are limited by 2 units & 20 models total; Engineers are a 0-3 choice; Can take max 2 of the following: doom rocket, brass orb, storm banner;
Vampire Counts
Master of black arts & blasphemous tome upgradeare 1pd each. 0- 3 etheral units (incl. Heroes). 0-2 red fury and/or quickblood abilities. 0-4 howls (death shriek counts as 2). 0-1 Terrorgheist , a max of 4 flying units, max 15 mounted characters and black knights combined
Tomb Kings: Tomb King armies have an extra 200 points for their roster (2600 total), All victory points scored against this army are decreased by 10% (excluding bonus points for banners, general, etc.), Neferra's Scrolls of Mighty Incantations counts as 2 PD AND 2 DD. Hierotitan is worth 1 PD so long as it's alive. Sphinxes of all kinds: 0-3 per army. Tomb Kings may generate up to 3 power dice per phase
Wood Elves: Wood Elf armies have an extra 200 points for their roster (2600 total) All victory points scored against this army are decreased by 10% (excluding bonus points for banners, general, etc.), Wood Elves can take 4 of the same core unit instead of 3, Wand of Wych Elm counts as +1 DD; Only Glade guards (including scouts) count for max of 45 models with shooting weapons
Warriors of Chaos: Hellcannon is a 0-1 choice. Infernal Puppet counts as +1 PD and +2DD; Tendrils of Tzeench and Conjoined Homunculus both counts as +1 PD. If you have warriors, knights and or chosen with marks of tzeentch in army then you can take max 2 out of 3 of warshrines and favor of the gods (2xwarshrines or warshrine and favor of the gods).
III. Scoring
0-20 Victory-Points per game
60-100 Battle-Points per team (in all rounds)
(The losing team gets 60 points even if they score less – the winning team never gets more than 100 points, even if they score more. Real Battle Points [non-limited by the 100-60 bracket] will be used in case of the Battle Points tie as tie-breaker.)
Victory points to Battle points per game:
0-150 Victory-Points difference - 10-10
151-300 - 11-9
301-450 - 12-8
451-600 - 13-7
601-750 - 14-6
751-900 – 15-5
901-1050 – 16-4
1051-1200- 17-3
1201-1350- 18-2
1351-1500-19-1
1500+ - 20/0
IV. Scenarios
Pitched battle scenario
V. Simple Line of Sight
cumulative).
- When such a unit is doing the shooting there are no to hit penalties for interfering or non-blocking
units or terrain, other than interfering woods.
- Wpisowe: 10 zł od osoby.
- Sędzia WiP
Harmonogram:
9.30-12.15 - I bitwa
12.30-15.15 - II bitwa
15.45-18.30 - III bitwa
2. Nagrody:
- Dla każdego gracza przygotowujemy pamiątkowy dyplom udziału w turnieju.
- Dla pierwszych 3ech miejsc i dla najlepszego hobbysty - wyjątkowe dyplomy.
3. Zgłoszenia
- Zgłoszenia graczy w formie: imię, nazwisko, (nick), miejscowość , nr ID ligowy oraz POPRAWNA rozpiska w formacie HTML, - należy wysyłać na adres cahir112@gmail.com do 16 maja, warto swoje przybycie zapowiedzieć w temacie poniżej. Za rozpiskę nadesłaną w określonym terminie + 3DP. Osoby przyjeżdżające spoza Łodzi proszone są również o podanie numeru telefonu w mailu.
4. Zasady:
- 3 gry, każda po 6 tur (za nierozegranie w wyznaczonym czasie przynajmniej 4 tur obu graczy obydwoje dostają -2 DP.
- tereny na stołach ustawione przed rozpoczęciem turnieju przez organizatorów, zakaz zmiany ustawienia terenów
- WE mają dodatkowy las
- obowiązują polskie uściślenia sędziowskie (http://strony.aster.pl/barbaros/usc8.pdf)
- gracze muszą posiadać wyraźne rozpiski (gracze z rozpiskami nieczytelnymi tracą -3DP) oraz zasady do swoich armii, wzorniki, miarki i kostki
Bonusy małych punktów:
-100pkt za generała,
-100pkt za BSB,
-25pkt za inne sztandary,
-50pkt za zabicie lorda/bohatera przez czempiona w pojedynku,
-50% wartości uciekającego bądź "sćwiartkowanego" oddziału.
5. Proxowanie:
- Na turnieju można proxować w ramach przyzwoitości - wszelkie duże ilości samych podstawek, znaczniki i wzorniki będą usuwane ze stołu na korzyść punktową przeciwnika.
- Proxować wolno tylko i wyłącznie tymi samymi rodzajami figurek, tj. Infantry za Infantry, Monstrous Cavalry za Monstrous Cavalry.
6. Ocena modelarska:
- Na turnieju NIE obowiązuje wymóg pomalowanych armii, ale zostanie przeprowadzona prosta ocena ilości pomalowanych modeli. Za 50%+ - 1 DP, a za 90%+ - 2 DP.
7. Jedzonko:
- Między bitwami są 15sto minutowe przerwy, a pomiędzy 2 i 3 półgodzinna, żeby skoczyć do pobliskiego chinola i spożyć ciepły posiłek. Oczywiście istnieje możliwość zamówienia pizzy czy innego jedzenia do ŁDKu.
Pierwszy wątek będę aktualizował w miarę postępów.
Lista zgłoszonych:
0. Cahir (WoCh)
1. Misiek (WoCh)
2. Urban (?)
3. Yrsen (O&G - R)
4. Euru (DWF - R)
5. Jakub Michalec (VC - R)
6. Cluzoe (O&G)
Ostatnio zmieniony 14 maja 2012, o 19:16 przez cahir, łącznie zmieniany 6 razy.
"Jeździec patrzy na nią. Ciri widzi błysk oczu w szparze wielkiego hełmu, ozdobionego skrzydłami drapieżnego ptaka. Widzi odblask pożaru na szerokiej klindze miecza trzymanego w nisko opuszczonej dłoni."
NOAK
Re: OŁ zaprasza na: Majowe DoRZynki !
Post autor: NOAK » 1 maja 2012, o 10:07
Czy aby na pewno chcecie grac w lutym? :wink:
cahir
Post autor: cahir » 1 maja 2012, o 10:09
Faux pax straszne. =D już błąd naprawiłem.
cahir
Post autor: cahir » 10 maja 2012, o 10:00
UP listy zgłoszonych!!
Zapraszamy wszystkich serdecznie!
cluzoe
Post autor: cluzoe » 14 maja 2012, o 11:35
OK, Przyprowadzę moje "zielone" dzieci.
Reyki
Post autor: Reyki » 17 maja 2012, o 15:02
Widzę ogromne zainteresowanie. Czy turniej się w ogóle odbędzie?
KFC-Karl Franz Chicken
cahir
Post autor: cahir » 18 maja 2012, o 12:06
Tak, będzie, niezależnie od ilości chętnych.
