Chrzanowskie Dni Fantastyki 14.09. 2013
Szybki Szpil zaprasza na drużynowy turniej Chrzanowskich Dni Fantastyki
Dla tych którzy odczuwają niedosyt po DMP chcą zmyć plamę na honorze lubo po prostu świetnie bawić się w nasze piękne hobby.
Format turnieju:
- Turniej klasy lokal
- 3x2400p (8edycja)
- Ograniczenia Euro
Rules changes:
Two characters per unit (owner's choice) will get "look out sir" versus the following spells that automatically kill models or automatically remove an entire regiment: Dwellers Below, Final Transmutation, Dreaded 13th. Normal requirements for lookout sir apply.
I. General Restrictions:
Army used can be any of the currently published GW Army books. Forge World based army lists & units may not be used on the event, except for Chaos Dwarves.
An army may have up to 4 war machines and shooting template weapons. Warmachines that use a template count as a single choice in this regard. All template weapons (from magic items, abilities, etc.) count, except for spells. Bolt thr. count as ½ a war machine(round up).
All BSBs can take all the Equipment, their unit type has acces to as if they weren't BSBs.
Army sizes, additional power dice/dispel dice and VP reduction are represented as follows:
Army (Point size, additionl power dice/dispel dice, VP reduction, if any (excluding bonus points for banners, general, etc.))
Magic Restrictions:
No duplicate non-signature spells(not including bound spells) and max 2 Spirit Leech (Signature spells are spells you can swap other spells to)
- Apart from Winds of magic, an army may only use 2 power dice/DD per magic phase. After an army generates the limit all the other extra dice are discarded. This includes channeled power dice/dispel dice.
- Player can use maximum 5 power dice to cast a spell. For spells from Lore of Death/Lore of Shadow/Lore of Hashut this max is lowered to 4 power dice.
- An army may use up to 12 power dice during each phase.
- “Count as” items/abilities may never exceed a cumulative 2 power dice/dispel dice per phase. This means that player who already spent his limit power dice limit, cant take more items which “count as adding power dice” or add power dice from channeling during game (same for dispel dice).
Detailed description
Apart from Winds of magic, an army may only use 2 power dice/dispel dice per magic phase (unless army restrictions specify otherwise). After an army generates the limit all the other extra dice are discarded. This includes channeled power dice/dispel dice.
Item restrictions:
- Any item that auto-dispels a spell counts as generating 1 dispel dice each magic phase.
Bretonnia (2400p)
No Restrictions
Beastmen (2700p, +1 Power Dice, -10%)
Tuskgor Chariots, Ungor Raiders 0-4 each
A unit cap of 50 models per unit and point cap on units 550 instead of 450 pts.
Chaos Dwarfs (2400p)
Chalice or Sorcerer Prophet. Chalice of darkness counts as 2 PD.
Iron daemon count as a war machines, K'daii destroyer count as 2 war machines.
Magma Cannon/Hellcannon 0-1/Dreadquake Mortar, max 3 in total
Dark Elves (2400p)
Max. 35 repeater Crossbows (excluding chariots & characters) in the army
Harpies, Flying characters, Rending stars max 2 of each
Dark riders 0-3
Shades max 20 models
Pendant cannot be worn by a Dreadlord or models with Crown of command
Pendant of Khaeleth/Crown of command/Cauldron of Blood/Hydra max 2 in total
Sacrificial dagger/mage lord, max 2 in total
Daemons of Chaos (2400p,+1 Dispel Dice)
Skull cannon 0-1
Beast of Nurgle models max 8 in total.
Flying units (not including Hovers) max 4 in total
The Rock of Inevitability cannot be taken
Dwarfs (2400, +2 Dispel Dice)
Max 45 Quarrelers/Thunderers in total
Grudge Throwers are a 0-2 choice
Gyrocopter doesn't count towards the war machine/template max
Anvil counts as 1 war machine.
Empire (2400p)
Max 45 str=4 shooters in total
Knightly orders 0-3
Demigryphs max 8 models
Cannon/Steam tank max 3 in total
Cannon/Steam tank/Demigryph unit, max 4 in total
Crown of Command/Steamtank, max 1 in total
High Elves (2400p)
Flying units(large target counts as 2), max 5
Book of Hoeth counts as 2 PD and 1 DD
Banner of World Dragoncounts as 1 DD
Lizardmen (2400p)
Mounted Scar-Veterans, max 2.
Becalming Cogitations/ Cube of darkness each count as 1 dispel dice.
Max 3 units of terradons including skink chiefs on terradons.
Skink skirmishers, Skink Kohorts counting less than 20 models, max 3.
Ogre Kingdoms (2400p)
Gnoblars units with less than 20 models, max 3
Dispell scroll/Hell heart(1DD), max 1 in total
Slaugther master/Iron blaster 0-1/Standard of Discipline/Crown of Command, max 2 in total
Max 8 Mournfang models
Orcs&Goblins (2600p)
Night Goblin Shamans mushroom dice do not count as power dice in regard to the power dice limit
Maximum model cap is 60 models per unit
Fanatics/Manglers max 9
Skaven (2400p)
Slaves, Rat Swarms, Engineers are 0-3 each
Giant Rats units with less than 20 models, max 2
Gutter runners are limited to 2 units & max 20 models in total
Screaming Bell/Second Grey Seer/Power scroll, max 1 in total.
Hellpit Abomination 0-1/Screaming Bell/2nd Assassin/Doomwheel 0-1/Warp-lightning Cannon 0-1, max 3 in total
Doom Rocket/Brass Orb/Storm Banner max 2 in total
Tomb Kings (2600p, +1 Power Dice, -10%)
Max 80 models with Bow or Giant Bow.
Neferra's Scrolls of Mighty Incantations counts as 2 power dice and 2 dispel dice
Hierotitan is worth 1 power dice so long as it's alive
Skeleton Horsemen, Skeleton Horse archers, Chariots units are 0-3 each
Warsphinx/Necrosphinx max 3 in total
Vampire Counts (2400p)
Zombies, Dire Wolfs units are 0-3 each
Flying units 0-4 (not including Hovers)
Vargheists max 8 models
Ethereal units 0-3, and max 2 of same kind/characters
Howls/shrieks max 2 in total
Red Fury/Quick Blood/Terrorgheist 0-1/Each Lord Choice, max 3 in total
Max 15 mounted characters and black knights combined
Master of Black Arts/Blasphemous Tome upgrade count as 1pd
Warriors of Chaos (2400p)
Core Chaos chariots, Marauder Horsemen, Warhounds are max 3 each, Hell Cannon is max 1
Model with 3+ ward save can’t have Third eye of Tzeentch.
Chimera/Daemon Prince, max 2
Daemon Prince can have max (3 - ½ his levels) of Soul feeder/armour save of 2+ or better/Mark of Nurgle/Fly
5 or more chariots/Deamon Prince/Unit of Skullcrushers/Hero choices on daemonic mount, max 3 in total
Wood Elves (2700p, -10%)
Max 70 glade guard
Glade Riders, Scouts units are 0-3 each[/quote
Gdzie i kiedy:
14.09.2013 Chrzanów
Miejsce:
-Hala widowiskowo-sportowa MOKSiR ul. Kusocińskiego 2 32-500 Chrzanów
Wjazd:
Przedpłata: 15zł od uczestnika (45zł drużyna) + 3 duże pkt dla drużyny
Marek Kiełbasa
Dmowskiego 6/386 43-100 Tychy
10 1020 2528 0000 0102 0185 3209
Płatne na miejscu: 18 zł od uczestnika (54 zł drużyna)
Całość wpłacana przez kapitana drużyny.
Harmonogram turnieju:
9:30-10:00 zapisy
10:05-13:00 I bitwa
13:00-16:00 II bitwa
16:00-19:00 II bitwa
Nagrody medale dla top 3 oraz skromne upominki w postaci bonów do sklepu Bard
Wymóg na turnieju:
Dopuszczalne minimalne proxy, nie ma oceny malowania.
Zgłoszenia
Zgłoszenie z rozpiskami kapitan drużyny powinien wysłać do 12.09.2013r (do 20:00) na adres imperatorff@op.pl będzie to premiowane 3 dużymi pkt do generalnej klasyfikacji.
Nasze rozpiski opublikujemy w czwartek o 20:00
Zgłoszenie powinno zawierać:
a) Nazwę drużyny
b) Imiona, Nazwiska i ID graczy oraz przyporządkowane do nich armie (kapitan jako nr.1).
c) 3 rozpisek w formacie HTML
Limit miejsc:
Na dzień dzisiejszy jest miejsca na 4 drużyny
Sędziowie:
Kapitanowie drużyn mają rozstrzygnąć wszelkie spory między sobą. Jeśli nie potrafią będą mogli się zgłosić do jednego z sędziów, którzy będą do dyspozycji graczy.
Sędzia rozstrzyga tylko i wyłącznie kwestie sporne nie ujęte w zasadach i uściśleniach.
Sędziowie:
3 osobowy komitet sędziowski zostanie wybrany na turnieju
ZASADY SĘDZIOWANIA:
http://www.mediafire.com/view/?1ucpaoab4tfjfn7
Obostrzenia dot. składu drużyn:
W drużynie nie można powtarzać armii.
Rozpiski:
Gramy na jawne rozpiski.
Scenariusze:
3x PB. Losowanie strony, wystawiania, zaczęcia zgodnie z podręcznikiem.
Stoły dla poszczególnych par wybierane są losowo. (Rzut D6 dla kaźdej pary, wynik 6 i wynik już wylosowany przerzucamył).
Mapki:
Mapki z ETC 2013.
Rozstawienie poszczególnych makiet będzie lekko skorygowana.
Rozstawienie graczy:
Parowanie EURO
1. (1&2th match up of Team A v. Team B)
Both Teams put up 1 army.
Both Teams put up 2 opponents
Both Teams choose their match
2. (3&4)
5. (5)
Team A last army («in hand»)
Team B last army («in hand»)
All this must be time limited to 20 minutes max.
Tables - random.
System punktacji:
Drużyna w jednej rundzie może zdobyć 0-60 DP
Każdy z graczy na rundę może uzyskać 0-20 punktów, wyniki drużyny sumujemy.
Drużyna, która w danej rundzie uzyskała więcej niż 39 punkty z bitew otrzymuje 40 MP. Drużyna, która zdobyła mniej niż 19 punktów otrzymuje 20 MP. Pozostałe drużyny otrzymują ilość MP równą liczbie zdobytych DP w danej rundzie. Ranking ustalany jest na podstawie najpierw sumy MP, następnie sumy DP.
Kod:
Progi:
0-149 10-10
150-299 - 11-9
300-449 - 12-8
450-599 - 13-7
600-749 - 14-6
750-899 – 15-5
900-1049– 16-4
1050-1199- 17-3
1200-1349- 18-2
1350-1499-19-1
1500+ - 20/0
Lista Zgłoszeń
SS Artyści
1.Solo
2.Andrzej
3.Domin
SS Kultyści Fluffego
4.Eltharion
5.Fluffy
6.Lucky Man
ZKF I
7 Cosmo P
8 Szczurek P/R
9 Szymon P
ZKF II
10 Zdzisiu R
11 Młody R
12 Denis R
Sucha Bila
13 Laik P
14 Sergiusz P/R
15 Suchy P
RyK-Czestochowa
16 Bombaj
17 SaS
18 Marek Bąk
Wstępna lista zgłoszeń do środy wyklaruje się kto gdzie gra.
_________________
Format turnieju:
- 3x2400p (8edycja)
- Ograniczenia Euro
Rules changes:
Magic Restrictions:
Item restrictions:
Bretonnia (2400p)
No Restrictions
Dark Elves (2400p)
Dark riders 0-3
Skull cannon 0-1
Empire (2400p)
Knightly orders 0-3
High Elves (2400p)
Lizardmen (2400p)
Skaven (2400p)
Max 70 glade guard
Gdzie i kiedy:
14.09.2013 Chrzanów
Miejsce:
Wjazd:
Marek Kiełbasa
9:30-10:00 zapisy
10:05-13:00 I bitwa
Wymóg na turnieju:
Zgłoszenia
a) Nazwę drużyny
Limit miejsc:
Sędziowie:
Sędziowie:
ZASADY SĘDZIOWANIA:
Rozpiski:
Scenariusze:
Mapki:
Mapki z ETC 2013.
Parowanie EURO
2. (3&4)
5. (5)
Tables - random.
System punktacji:
Kod:
Progi:
0-149 10-10
150-299 - 11-9
300-449 - 12-8
450-599 - 13-7
600-749 - 14-6
750-899 – 15-5
900-1049– 16-4
1050-1199- 17-3
1200-1349- 18-2
1350-1499-19-1
1500+ - 20/0
Lista Zgłoszeń
SS Artyści
1.Solo
2.Andrzej
3.Domin
4.Eltharion
5.Fluffy
6.Lucky Man
ZKF I
7 Cosmo P
8 Szczurek P/R
9 Szymon P
ZKF II
10 Zdzisiu R
11 Młody R
12 Denis R
Sucha Bila
13 Laik P
14 Sergiusz P/R
15 Suchy P
RyK-Czestochowa
16 Bombaj
17 SaS
18 Marek Bąk
_________________
Ostatnio zmieniony 11 wrz 2013, o 15:30 przez Solo, łącznie zmieniany 13 razy.
Nagrody Puchar dla zwycięskiej drużyny oraz medale dla top 3
good oneLimit miejsc:
Gremlin pisze: 5. Kosmo (99% szans obecności; Przewodnie motto turniejowe: mam chimerę i kranczerów, wyssę życie z wrogów wielu)
Macie racje. Turniej będzie miał format 3 osobowej druzynowki. Jeszcze dziś solo powinien nanieśc poprawki.
odruchowo wlepił te zasady z jakiegos preDMP chyba ; p
Pozyczone od Shina,
Solo pisze: Gdzie i kiedy:
14.09.2013 Chrzanów
Wisła Kraków.
Taa, faktycznie. Musiałem sie przekopać przez wielki blok zbitego tekstu, żeby znaleźć datę, która nie jest w żaden sposób wyszczególniona. Ogarnij to Solo i daj do nagłówka i w tytule tematu, bo juz sie mnie ktoś pytał, kiedy właściwie jest ten turniej
Mi też nie było łatwo, ale gdy zobaczyłem pierwszy raz ten temat to wysiliłem moje wszystkie zmysły i przebiłem się przez zasłonę położoną przez Sola i odkryłem datę!
Tak samo jak Andrzej sugeruję edit, bo nic w tym tekście nie widać
Wisła Kraków.
Andrzej pisze:Taa, faktycznie. Musiałem sie przekopać przez wielki blok zbitego tekstu, żeby znaleźć datę, która nie jest w żaden sposób wyszczególniona. Ogarnij to Solo i daj do nagłówka i w tytule tematu, bo juz sie mnie ktoś pytał, kiedy właściwie jest ten turniej
ctl+f
Wszystko wskazuje na to że nie będzie od nas żadnego teamu.Laik pisze:z Krakowa sie ktos wybiera? bo zastanawiamy sie nad przyjazdem a przy 3 teamach to nie ma sensu za bardzo
Wisła Kraków.
To, że oni chcą zawsze nasze rozpiski, nie oznacza, że mamy chcieć tego samego... Po co Ci one? Żeby zobaczyć, że znowu grają tym samym?Laik pisze:Od nas będzie 1 team.
Solo kiedy wrzucisz Wasze rozpiski?
Mnie na tym turnieju i tak nie będzie, więc to Twoja sprawa Laik czy będziesz chciał tych rozpisek, tyle że nie wiem po co Ci one
jak byście zaczęli mówić po polsku było by miło.... to wy -8billa chcieliście rozpiski zawsze przed turem. Bo niby to zwiększa frekwencje. ..big LOL... wiec proszę się nie czepiać że król słońce robi to sam...
Piotrze, z całym szacunkiem, ale nie zrozumiałeś tego co zostało tu napisanePiotrB pisze:jak byście zaczęli mówić po polsku było by miło.... to wy -8billa chcieliście rozpiski zawsze przed turem. Bo niby to zwiększa frekwencje. ..big LOL... wiec proszę się nie czepiać że król słońce robi to sam...
Laik chce, żeby Solo opublikował rozpiski ich teamów. To, że Solo chce żeby przesłać mu rozpy uważam za normalne bo jak widzisz jest pewien problem z frekwencją na tym turnieju, więc jako organizator też chciałbym wiedzieć czy ktoś przyjedzie (jak wyśle rozpe bardziej prawdopodobne że przyjedzie).
A prośba Laika ma związek z tym, że Solo zawsze prosi 8 Bile o opublikowanie naszych rozpisek przed turniejem.
Teraz kumasz?
Szaitis pisze:To, że oni chcą zawsze nasze rozpiski, nie oznacza, że mamy chcieć tego samego... Po co Ci one? Żeby zobaczyć, że znowu grają tym samym?Laik pisze:Od nas będzie 1 team.
z całym szacunkiem masz chyba polityczne rozdwojenie jaźni....
