Pytanie co do niejasności w zasadach
Vampire Counts
Moderator: misha
Shinue
Re: Pytanie co do niejasności w zasadach
Post autor: Shinue »
Kod: Zaznacz cały
Q: As Necromancy spells may be cast multiple times in a magic phase and that there is no restriction on using a bound items only once in a magic phase, can the Book of Arkhan be used as long as we have power dice, rolling to see if it burns out after every use?
A. Yes, the Book of Arkhan can be used multiple times in the magic phase as it contains a spell (Vanhels Danse Macabre) which is classified as a "Necromancy" spell and specifically allowed to be cast more than one in a Magic phase. Note the Rulebook page 37 states "A bound spell is just like an ordinary spell."
S. VC book pages 38, 39, 86 / Rulebook page 37
a tu masz link: http://www.vampirecounts.net/Thread-Dir ... rpe-Noctem
warto przeczytać całego FAQa. spójrzcie na to:
Q: In the second paragraph of the Amendments´section, the Errata for Vampire Counts states to ignore page. 88 of the VC army book and use the general rules for army composition. Does it mean that a wight king or a necromancer can be the army general if the happen to be the characters with the highest Leadership, or a VC army must still be led by a vampire model?
A. Given that the Vampire Counts Official update itself states, to ignore all of page 88 (which contains the rule that a Vampire must lead the army), yes a Wight King or Necromancer may in fact be the General.
S. Vampire Counts Official Update / VC book page 88.
Drwal
Post autor: Drwal »
Ciekawe ;)
August
Post autor: August »
Shinue pisze:warto przeczytać całego FAQa. spójrzcie na to:
Nie do końca. W aktualnej eracie (może cytujesz jakąś pierwszą wersję?) stoi:
Page 88 – Army List Entries
Ignore everything on this page, except for the second
paragraph in the Choosing Characters section, and use the
rules for ‘Choosing Your Army’ in the Warhammer rulebook.
Właśnie w tym drugim paragrafie "Choosing Characters" stoi że generałem musi być wampir.
Shinue
rzeczywiście :(
a szkoda bo pancerniak king byłby fajnym generałem ;)
Gregor
Post autor: Gregor »
Wtedy nie mógłbyś mieć lorda, bo ma 10 ld.
eliah91
Post autor: eliah91 »
Mam pytanko:
Co się dzieję ze sztandarowym jak przegramy walkę?
Od razu się sypie?
Daw
Post autor: Daw »
Nie sypie się. Tracisz sztandarowych gdy klocek ucieka. Vampy przecież nie uciekają :)
eliah91
Też tak myślałem.
Widzisz jaka łajza jest z Tutajca?
Niezły wałek na zabicie gwardii. :evil:
misha
Post autor: misha »
hehe
łobuziak rzeczywiście :)
mi jeden gracz jak graliśmy na duuże ptk wmawiał, że jak wyjdę bohaterem z oddziału to oddział nie może więcej się ruszyć. Co ciekawsze przepchnął takie coś w 2 wcześniejszych bitwach uh. No cóż. Trzeba się pilnować.
Assur
Post autor: Assur »
Shinue pisze:rzeczywiście :(
Przez chwile mógł. Ta aktualna errata wisi chyba od stycznia.
Janiszek
Post autor: Janiszek »
Czy banshee będąc w combacie może krzyczeć do oddziału/jendostki poza combatem?
gerald_tarrant
Post autor: gerald_tarrant »
tak
Janiszek
zostałem zwałowany! :^o
Azgaroth
Post autor: Azgaroth »
gerald_tarrant pisze:tak
To coś się zmieniło w FAQ ? Bo w Armyoboku wyraźnie stoi, że banshee w combacie krzyczy tylko na jednostkę z którą walczy.
gerald_tarrant
fakt #-o
to ja wałowałem :oops:
Janiszek
:shock:
<podkulony ogon>
Daw
Post autor: Daw »
O Bosh! :D:D:D:D
Nie ma Lipy! Tutaj nieźle forsuje wałki żeby kumpla ograć :D
kharnak
Post autor: kharnak »
Czy Carstien Ring jest One Use Only czy działa za każdym razem kiedy właściciel ginie ? Army Builder twierdzi że One Use Only natomiast Army Book przeciwnie.
Azgaroth
kharnak pisze:Czy Carstien Ring jest One Use Only czy działa za każdym razem kiedy właściciel ginie ? Army Builder twierdzi że One Use Only natomiast Army Book przeciwnie.
W armybooku nie ma rzeczywiście napisane "One use only" ale jest napisane "The first time the wearer of this ring is slain roll a D6". Czyli rzucasz kiedy lord zginie po raz pierwszy, przy następnej śmierci ten przedmiot nie ma już zastosowania.
kharnak
Dzięki :)
