Kodex IndyChD i faqi
Moderator: esgaroth
Umknął mi ten mały upgrade
Zwłaszcza z bohaterem, który mu daje na przykład warda na 4+ ?
Dalej uważacie, że kolossus nie ma racji bytu?Errata na wormongers pisze:Kollossus Daemon Tower 300 pts/model
Kollossus M:3 WS:- BS:- S:5 T:7 W:10 I:- A:- LD:-
Annihilator M:- WS:4 BS:3 S:3 T:- W:- I:2 A:1 LD:9
Troop Type: Monster.
Armour Save: 3+
Special Rules
Large Target; Terror; Impact Hits (D6+1); Unbreakable; Slave Lords
Daemonic War Platform
The Kollossus Daemon Tower counts as a Monster and has a crew of 10 Chaos Dwarf Annihilators with their own characteristics, but are treated as a single model.
The Movement value of the Kollossus is always used when the unit moves. The Chaos Dwarf crew uses their own Weapon Skill, Strength, Initiative and Attacks when attacking in combat. The crew may attack any model in base contact with the Kollossus. In combat, models rolling ‘To Hit’ the Kollossus use the Weapon Skill of the majority of the crew. Impact hits use the Strength of the Kollossus (S5).
In the Shooting phase, the crew counts as having a 360 arc and may fire their blunderbusses as normal using their own Ballistic Skill. Note that as the crew does not have ranks, their Blunderbusses will always be S3.
All hits upon the Kollossus Daemon Tower are resolved using the Tower’s Toughness and Wounds.
Daemon Phlegm (same)
Siege Engine: The Daemon Tower is idea for assaulting castle walls and buildings. When making an assault on a building the entire crew counts as the assault party and gain the Always Strikes First and Devastating Charge special rules until the end of the assault.
Character Mount
As described in the army list entries, a Chaos Dwarf Overlord, Slavemaster or Daemonsmith may ride atop a Kollossus Daemon Tower eventhough the Kollossus is Unbreakable. Only a single character may ride a single Daemon Tower. When this option is taken, the Kollossus counts as a Ridden Monster as described in the Warhammer rulebook, however, if the character is slain the Kollossus tower does not take a Monster Reaction test.
- gerald_tarrant
bardzo dobrze, że collossus jest teraz monsterem, bardzo ułatwia to życie
robi się powoli grywalny, ale Barth, oświeć mnie, jak chcesz dać collosowi warda?
Marynarz pisze: Character Mount
As described in the army list entries, a Chaos Dwarf Overlord, Slavemaster or Daemonsmith may ride atop a Kollossus Daemon Tower. Only a single character may ride a single Daemon Tower. When this option is taken, the character replaces one crewmember. Since character models have more wounds than ordinary crew, they will increase the total wounds of the tower as follows: a Kollossus ridden by an Overlord will have 12 Wounds, a Kollossus ridden by a Slavemaster or Daemonsmith will have 11 Wounds. Always the first 9 wounds will be inflicted upon Annihilator crew; the remaining wounds will then affect the character. This means the last crewmember will always be the character.
Niby przez tą zasadę.
Ale w tym upgredzie tego nie ma wiec nie wiem czy to działa
I przez to :
Barth pisze:Always use the best armour and ward saves from the surviving crew or character against all wounds inflicted upon the Kollossus model.(...)
Dla mnie jest to przegieta jednostka
Właśnie chyba faktycznie teraz tej zasady nie maAlways use the best armour and ward saves from the surviving crew or character against all wounds inflicted upon the Kollossus model.(...)
Gdy była myślałem o buildzie z overlordem z ward sv na 4+. Teraz jak jest monsterem to to odpada, nie?
Wystawiłem kollosusa raz, z bohaterem (BSB) i sztandarem dającym warda na 5+. Nie było źle tylko wtedy nie był jeszcze unbreakable i w pewnym momencie nie zdzierżył naporu... moralnie
Czyli w świetle tych zasad teraz jak to wygląda? Można jako cel wybrać bohatera na kolossusie skoro w zasadach jest napisane, że W schodzą najpierw załogi? Czyj sv wtedy używam? i kiedy mogę użyć ward sv jeśli go mam na bohaterze?
PrzesadzaszJorge pisze:Dla mnie jest to przegieta jednostka
- Infernal Puppet
Oficjalnie nie, ale w Polsce dość często się jednak dopuszcza. Ale wkrótce dostaniecie legalny AB i nie będzie bajań "bo to nieoficjalne" .
Ach te uroki bycia ciągle głodnym .Mad Mike pisze:To nie wypali. Zanim wjedzie, to sytuacja ulegnie odwróceniu i tort będzie w środku Cezarakwaku pisze:nawet gdyby miał tam wjechać tort z Cezarym w środku.
- Andronicus
Tia, a od kiedy zasady wydane przez FW uważane są za oficjalne? Jak będą gięcia, podejrzewam, że nie będzie zbyt często dopuszczany u nas.
- Infernal Puppet
Od zawsze raczej . Jeśli IA jest niedopuszczany to z racji przegięć/nieznajomości zasad/braku modeli, nigdy nieoficjalności. Jak kiedyś Blood Angesl mieli swój "codex" w white dwarfie to nie przypominam sobie turnieju na którym nie był by on dopusczony .
- Infernal Puppet
Ale firma z GW blisko kooperująca, do tego stopnia że GW zamieszcza modele FW na swoich stronach i w swoich podręcznikach ( a adnotacjami że to z FW by nie było ). Poza tym, chadecja z wszystkich armii chaosowych ma chyba największą siłę przebicia .FW to nie GW...
- Andronicus
Podobno nawet 4ed AB, wydany przez WD, nie był dopuszczany na wszystkie turnieje. Czytałem, że na jednostkach z IA też można pograć raptem 2x do roku. Zgadzam się, że skoro dopuścili Indy GT, to tym bardziej powinno się dopuścić ten z WF, ale jeśli w AL będą ostre gięcia, to nawet silne chadeckie lobby nie zdoła tego przepchnąć.
- gerald_tarrant
jak będą gięcia to będą ograniczenia i tyle
- Andronicus
Kto wie, może przez te wszystkie lata czekania na tą armię stałem się nieco cyniczny i zrzędliwy Pożyjemy, zobaczymy co z tym zrobią. Jak dla mnie jest stanowczo za wcześnie żeby się cieszyć i układać pod tą listę rozpiski
