temat jest o zasadach a nie o nadziejach na sukces w grze smokiem
Moderator: misha
Wendigo pisze:Czy jak dam generałowi moc forbidden lore to może on korzystać z innego lore'a niż lore of vampires?
sluszne info mi wpadlo, skonsultowałem się z Furionem, zwrócił uwagę, ze Forbidden Lore daje mozliwosc losowania z RB, ale nie wymusza, wiec kmina na Lorda generala z Lightem czy Heavenem odpadaForbidden Lore 25 ptk
Vampire can generate spells from any one of the lores in the Warhammer rulebook, except for the Lore of Life.
opis mówi, że rzucasz przed modelem ktory pierwszy wykonuje rzut 'to hit' czyli w CC po inicjatywie.Battle of Wills:
Immediately before the first model in an enemy unit rolls To Hit against the Coven Throne or a character upon it (either in close combat or shooting) the opponent must roll a D6 and add it to his unit’s Leadership (attacks that do not roll To Hit are exempt from this effect). Next, roll a D6 and add it to the Coven Throne’s Leadership. Substract the enemy’s from Coven Throne’s total and apply the result to the table below – the result last until the end of the turn.
0 or less: No effect
1-2 The enemy is at -1 WS and -1 BS to a minimum of 1
3-5 The enemy must re-roll successful To Hit rolls
6+ Every model in the attacking unit makes a single close combat attack, resolved against its own unit. War Machines take a single Strength 3 hit for each remaining crewman against the crew’s Toughness. Affected units may not otherwise shoot or attack this turn.
do pojedynków z kowbojami?a champion jest przydatny
