VC 9th age
Moderator: misha
Re: VC 9th age
Odpowiednikiem w 9A jest Monstrous Revenant. Nekromanta może na nim jeździć.
Zaszłyszane na jakimś turnieju:
- Twój WS?
- Tak
Court of The Damned spoilery 2.0
What did the change entail?
So the main focus of the change was to create a debuff effect that would target enemy units. There were several suggestions for this, including giving a Horrid bubble, lowering the agility and defensive skill of the opponent or even buffing our own combat potential. As the role defined for the unit was a debuff it was decided, the latter option was discarded and a purely combat debuff was selected. Alongside this, in accordance with all the chariots, the random attacks of the ghostly horde has been changed to a set value of 8 attacks. This is slightly higher than the average, and better than i've ever rolled... (damn my cursed dice).
The next important aspect of changing the court was addressing the issues faced in the durability of it. Now this resulted in 2 rather significant changes that really helped to bring it into a position that will hopefully see a lot more use:
1) The Court has now gained mounts protection (6+). This is a big improvement for mounted characters as we were always faced with low armour saves - not an exciting prospect when you're going to stick your favourite vampire on top of one of these things.
2) The Court has now gained war platform. This is one of the biggest boons for this model and I believe it will really change the way this model is used completely. Now, this obviously comes with one problem that I hope most of you will only find a minor inconvenience. As the war platformrule has been added to allow it to join units of infantry, it has undergone a base change from 50x100mm to 60x100mm. Whilst no one enjoys the prospect of rebasing a model (this decision was not taken lightly), it was deemed necessary to try and define the role of this model a lot more. Hopefully you will all find it worthwhile to bring such a great model back in to play.
So all in all, the changes we will see on the Court are as follows:
1) Unholy Dominion: All models in enemy units within 6" of one or more models with this Global Rule suffers -2 Agility and -2 Defensive Skill
2) Ghostly horde attacks changed from 2d6 to 8
3) Court of the Damned gains Mounts Protection (6+)
4) Gains War Platform
5) Base change from 50x100mm to 60x100mm
Nagash is coming...
Kolejna nowość
http://www.the-ninth-age.com/index.php? ... and-lamia/
Nagash is coming...
Czy szkielety corowe sprawdzają się w boju? Z czym sensownie je wystawić?
Szkielety to coś koło 50 mam
ale ostatnio testowałem w hordzie przeciwko szczurom i średnio się sprawdzili :/
Co sądzicie o nowych punktach? Trochę głupio jest dawać obniżki na niegrywalne jednostki bez redesignu ich zasad - wciąż pozostaną niegrywalne...
Jedyną "niegrywalną" wcześniej figurką którą teraz będę używał będzie Corpse Cart.
Jeszcze jedno pytanie czy Hard Target z nietoperzy kumuluje się z HArd Targetem z VonK? Jeśli tak to można rozważyć jeszcze Swarmy i nietoperze?
Nagash is coming...
Hard target normalnie się stackuje.Vesemirus pisze:Co sądzicie o nowych punktach? Trochę głupio jest dawać obniżki na niegrywalne jednostki bez redesignu ich zasad - wciąż pozostaną niegrywalne...
Hej czy ja dobrze widzę że wóz że zwlokami np. jest podstawka 60x100 mm, zawsze tak było czy wcześniej 50x100mm ?
Podstawka się zmieniła by mógł jako war platforma wchodzić do oddziału piechoty.
Dobrze że nie przyklejalem na pewniaka do 50 ;p
Hej mam pytanie co do zasady Unholy Apetite: czy jeśli ghastami zyskałem unholy apetite po czym wróg uciekł a ja w pogoni nabiłem się na inny oddział to czy mogę w fazie walki skorzystać z tej zasady?
jakby nie patrzeć jest to kolejna tura walki...
Unholy Appetite - Close Combat. After a Round of Combat in which at least one attack with Unholy Appetite caused an unsaved wound, all attacks with Unholy Appetite from models in the same unit must reroll failed to-hit rolls until the end of the next Player Turn.
Kluczowe tutaj jest "next Player Turn". W definicji nie ma nic o tym że to musi być w tej walce(jak to jest np. w rending banner), więc tak, przerzucasz wszystkie ataki z oddziału który w poprzedniej turze gracza zranił.
Keep Calm
and
Przestań Mamucić
"Making people happy is something to be proud of, especially if you can do it by accident"
177013
"You make my heart pussy go poggers!"
~Anon to PM
"Mamut Ty weź się rozpędź a ściana sama Cię znajdzie"
~Biggos
and
Przestań Mamucić
177013
~Anon to PM
~Biggos
