Oby old onesy zostaly jakie sa
Moderator: Ziemko
A może do tego always kill first? Ja nie moge, co oni robią z tymi armiami?Pingwin pisze:ja bym rozważył jeszcze dwuraka i always strike firstbiegacz z itp i stubbornem Smile Piekne Smile Ide malowac jaszczurki.
Selected tidbits courtesy of Warseer's: Harry
We love to pass on on all the little tidbits we hear and here are some of the latest. We have recieved news that the GW 40k/WFB schedule is shaping up for Q1-Q2 2009 as follows:
JANUARY:
2nd wave Orks
Plastic Gretchin, Stormboys, Nobz, plastic Battlewagon.
FEBRUARY:
Lizardmen
Plastic Stegadon to be availiable as a rare, special and mount option. Up to nine said to fieldable in one list. New kroxigors.
MARCH:
Apocalypse
Stompa and one or more Baneblade variants (Stormlord and/or Shadowsword, possibly others).
APRIL-MAY:
Imperial Guard
Plastic Stormtroopers, Valkyrie, Russ variants, more.
2nd Wave Daemons
Plastic Daemon Prince, new Seekers, rest of the named Daemons, possibly generic daemons and a Battleforce
Q3-Q4:
Necrons
All the stuff reported here.
Dark Eldar
New range by Jes Goodwin, Codex by Phil Kelley. End of the year, possibly bumped even later to make sure the army is done correctly.
And More...
~There is great uncertainty as to the exact timing of these releases as we get into the Q3-Q4 timeframes, and the Apocalypse release slot is still full of uncertainty as to what the Baneblade variant(s) will be. While the 40k codex releases are thin between now and IG (reported to give plenty of time for the marine releases to sink in) the back half of 2009 is said to be stuffed to the gills with releases for both 40k and Fantasy. Standard caveats apply folks, have at it.
Frenzy jest totalnie pojebane* plastic stegadon is confirmed.. apparetly it's about 1.5 or so times larger than the existing one...
Jungle Fighter: All models move through jungle, woods, and forest as open ground and do not suffer any penalty. (Excluding Mounts)
There is no changes for Chotec rule; however, i did came across Sotek rulings
Sotek:
For units: They get +1 A on the turn they charge.
For Characters: Frenzy (still have to take test for Stupidity)
Naprawde myslisz ze jak beda bardzo chcieli sprzedac kazdemu powergamerowi 8 stegadonow to nie sprzedadza?swieta_barbara pisze:I pewnie totalnie niegrywalne - stubborn na 5 :] Juz widze jak psy sie za nimi po calym polu bitwy uganiaja. Albo zombiaki. Mniam.
no pewnie w lizakach bedzie taka sama opcja jak w ograch ... czyli jesli bedzie jakis spec char to wtedy bedzie mozna mnostwo stedziow wystawicShino pisze:jakby wam powiedzieli, ze ogry moga wystawic 8 gorgeroiw to tez byscie nie uwierzyli?
