ktoś po prostu musi finansować te fanaberieRemo pisze:Naprawdę?Vesemirus pisze:
AUGUST
Codex Space Marines
W takim razie gdybym kilka lat temu nie zaprzestał grania Kosmicznymi Marynarzami to w sierpniu na półce miałbym 5 już kodeks.![]()
Natomiast Bretonnia przez 19 lat dwa "kodeksy"... Brawo GW.
Co zmieni się w 9 edycji? (Podsumowanie link w 1 poscie)
Re: Co zmieni się w 9 edycji?
Z bugmansbrewery
Got some (hopefully) positive information regarding 9th edition.
This info come from a GW related source. What do they know, right? I am just repeating what I have heard.
So take this with a pinch of salt as usual. First off, possible release at the end of June/early July. Nothing new here.
Now, on how 9th edition will work. 9th edition won’t be one game as we know Warhammer now. There will be three
different playstyles. GW wants to add some of the elements that have made 40K so popular. Think kill-team, formations
and so forth. With the hope of fantasy becoming more popular. And the game will be played in three different time sets:
Pre-apocalypse, apocalypse and finally post-apocalypse.
The first part Post-apocalypse as in after The end times will be the skirmish part that we have heard of with round bases.
And with merged armies. This will be a small game. Think of it as a friendly start for anyone who has not played Warhammer
before. It will be fast (and easy) to play, cheaper because you need fewer miniatures (A couple of heroes, two five man units,
one monster and maybe some cavalry for example) and more dynamic. This will hopefully be a fun way to start, you don’t have
to spend loads of $$$ and paint a hundred miniatures.
The second part, Apocalypse will be The end times. Straight up with some 9th edition updates.
And lastly there will be the Warhammer we all know and love. Pre-apocalypse. This is the complicated game with lots of rules and
big armies. The rules won’t be 8th edition but close enough. You can call it a usual edition update.
This approach is for GW to broaden their customer circle. As it is now Warhammer is a hard game to just “dive into”. As mentioned
above it has loads of rules, is very expensive and requires lots and lots of miniatures. So the fresh start of Warhammer will be more
intro friendly. So this is GW’s attempt to make everyone happy. Because after all they don’t “want” to lose their current and very
loyal customers. May it be a painter or a gamer, or both!
And that is why the old Warhammer structure will live on as well. And your current armybooks will be more or less usable in 9th but
the new books will be with merged armies as I mentioned above. But how and when the books will be updated (or even IF there will
be updates) there was no mention of.
This is a smart move from GW (for once). Hopefully there will be many new players. And old veterans who already have armies will
likely get tempted to buy a small skirmish force with that cool looking faction you never started because you couldn’t afford/wanted
an entire army with. Win/win! And as mentioned in various threads yhe starter box will be (Super?)Humans VS Chaos(Khorne?)
Sounds very promising if true. As I said. Take with a pinch of salt.
Thank you for looking!
- Verminlord
- Warzywo
Tylko po co okrągłe podstawki do skirmisza? Zaczynam zbierać j jakąś armię, mam kilkanaście modeli na okrągłych podstawkach a jak chce ją rozbudować na duże pkt to muszę te modele przepodstawkować. Nie lepszy byłby skirmisz na kwadratach.?
- wind_sower
Teoretycznie dobry ruch, można pograć coś a'la mordheim a później jak złapiesz bakcyla przechodzisz na duże punkty. Gdyby to jeszcze było grywalne i wspierane jak WM to byłby odlot
Weźcie pod uwagę fakt, że te zapowiedzi są mocno nieoficjalne. Podobne oczekiwania co do przyszłego kształtu battla były już prezentowane wcześniej (3 sposoby grania). Jednak przyszłość pokaże, ile z tego jest prawdą. Osobiście niestety nie oczekuję, by GW zmieniła system w kierunku opisanym powyżej. Raczej spodziewam się, że będzie skirmishem, tak jak opisano to powyżej.
A moim zdaniem to słabe. Oczywiście nie pod względem marketingowym, bo to chyba porządnie przemyślano, ale pod względem ciągłości uniwersum. Którą z wersji świata zamierzają wspierać przyszłymi kampaniamii? Wszystko co miało wydarzyć się przed apokalipsą i w jej trakcie już się wydarzyło.
- Verminlord
- Warzywo
No jest to rozwiązanie. Albo trzeba się będzie bawić w zmianę podstawek. W sumie kilkanaście modeli to nie tak dużo, problem się pojawi kiedy ktoś będzie chciał mieć dużą różnorodność modeli/jednostek w skirmiszu.Azurix pisze:Właśnie po to, abyś do Skirmisha musiał mieć osobno kupione modele
GW jest na giełdzie ta firma musi przynosić zyski, cieszcie się że jest jakieś rozwiązanie w postaci alternatywy na skirmis + eot + after.
Równie dobrze mogli by sprzedać WFB jakimś Chino-afro-amerykanom i wtedy albo było by lepiej albo gorzej, kolejne rozwiązanie to zupełnie zmiana świata WFB odcięcie się od weteranów którzy już swoje zostawili i szukanie nowego rynku zbytu produkując dysfunkcyjne makro cyber pokemny dla graczy lat 7-12 jak engry birds itp.
Więc z takiej alternatywy jestem zadowolony i na pewno zostanę przy grze, czas emerytury dopiero w 10 ed
a miejmy nadzieje że nigdy.
Co prawda to dopiero plotki więc co słabsze charaktery będą szukały innych rozwiązań np zmiana systemu albo nadmierna bulimia.
Zestaw ksiazek
1 fluff pre
2 fluff apo
3 fluff post apo
4 rule pre
5 rule apo
6 rule post apo
7 galeria fotek
Tak mysle ze 600 zeta jest ok a edycja kolekcjonerska 1200 co najmniej z numerowanym odciskiem palca prezesa. To tak zeby latwo dalo sie wejsc w system
Ew kazdy rule set osobno ale wowczas po co najmniej 300. A co gracze i tak kupia
1 fluff pre
2 fluff apo
3 fluff post apo
4 rule pre
5 rule apo
6 rule post apo
7 galeria fotek
Czy zasugerowałeś właśnie, że szukanie lepszych rozwiązań kosztem starych przyzwyczajeń jest objawem słabości charakteru, a trzymanie się kiecki jednego wydawcy "bo było się z nim od zawsze" nawet jeśli nie podobają Ci się jego działania to zaś przejaw siły charakteru?Solo pisze:Co prawda to dopiero plotki więc co słabsze charaktery będą szukały innych rozwiązań np zmiana systemu albo nadmierna bulimia.
- Verminlord
- Warzywo
Solo ja wiem, że GW musi przynosić zyski ale są pewne granice. Jeżeli zrobią skirmisz na okrągłych podstawkach to będzie to jawny skok na kasę. Jakoś twórcy WM i Hord mają zyski plus tworzą zbalansowany system kontaktując się z graczami. Znaczy, że się da tylko trzeba chcieć. GW ma olbrzymi fan base, który systematycznie zniechęcają.
