East Games United 2011 - 21-22.05.2011, 2400 ETC, Białystok
Re: East Games United 2011 - 21-22.05.2011, 2400 ETC, Białys
Poszło zgłoszenie.
Drukujecie rozpy?
Drukujecie rozpy?
ja nie drukuje, jesli masz ochote mnie w tym wyreczyc to NZS zwroci koszta.
Zgłoszenia do jutra, nie spać!!
jutro postaram sie dogadac z kierowniczka i napisze.
update listy. moje zgloszenie tez juz poszlo
Jak już grać na EURO to tereny też trzeba wziąć:
Final AR pisze:Terrain
Hills are size two for each level (so a 3-step hill is size 6) and block sight / give hard cover just like models of that size. Models standing on hills add the hill size to their own size. Buildings and large rocks always block line of sight completely.
Forests do not block line of sight, but soft cover applies to all shots fired through or into (but not out of) forests.
Ruins do not block line of sight, but hard cover applies to all shots fired into (but not through/out of) ruins.
Units standing behind obstacles gain soft (wood) or hard (stone) cover as per the RB.
Buildings are treated as: as infinitely high, units inside are height 2 I (in terms of what they can see and determining cover against their shots). All buildings are level 1
Lakes – treat lakes exactly the same as rivers in the Rulebook
Hedges/fences etc. – treat all of them as stone obstacles: grant hard cover and -1 to hit in close combat against the defender, exactly as per the rulebook.
Fields – Soft cover for any unit inside the terrain (discerned by majority of models/base), no other effects.
kolejny update, przypominam ze rozpy wysylamy najpozniej dzis do polnocy!
nie ma graczy z zagranicy
- Cauliflower
Jak ktos chce jechac ze mna - sobota rano, to mam miejsca.
Napiszcie mi pmke, a najlepiej smsa, bo wracam do Polski dopiero w piatek.
Nie bedzie mnie jesli cos sie spierdoli z lotem, ogolnie chce przyjechac.
Czemu z reprezentantow tylko ja sie zglosilem?!?
a nie tylko, Robson wlasnie sie zglosil
zaraz poleci update zgloszen. przyjezdzajcie, warto - dobre nagrody, Juwenalia w trakcie, na pewno nie pozalujecie.
2 reprezentantow ETC, 23 graczy na liscie. jesli ktos wysle zgloszenie jeszcze dzis, to bede mily i dam 4 punkciory
