koleś z WF w odpowiedzi na maila z pytaniem o termin wydania zasad, o którym wspomniano w WD pisze:Hi there.
Unfortunately White Dwarf has published some incorrect information by mistake. The book is likely to be released in August or September.
Thanks
Tris Buckroyd
Chaos Dwarf Updated - official news
Moderator: esgaroth
Re: Chaos Dwarf Updated - official news
Jednak światełko w tunelu
czekamy dalej ale nie tak długo
CHAOS DWARF DREADQUAKE MORTAR £75.00
The terrifying Dreadquake Mortar is amongst the largest and most devastating of the siege engines fielded by the Dwai Zharr. Akin to the bombards used by other races, the Dreadquake Mortar uses a vast boiler to generate steam pressure to fire its munitions. The sorcerous energies bound within these immense, volatile shells explode on impact, striking the battlefield like a hammer blow and causing untold devastation.
Complete resin kit. Dreadquake Mortar designed by Tim Adcock and Keith Robertson. Crew designed by Keith Robertson.
Available to pre-order now for release in the week commencing 25th July. Experimental rules for this mechanical behemoth are available to download here.
- gerald_tarrant
Dreadquake Mortar:
Large Template
S5/S10 1D6 wound
Incinerating rule : Flaming Attack + something unknown.
Quake wave : same effect as ash storm spell with these changes :
the target unit may only use its basic move and not charge or march. The unit also treats all terrain
(except impassible terrain) as dangerous terrain.
Slow to fire : the Dreadquake Mortar is difficult to operate. If the ogre slave is slain, the
Dreadquake Mortar will fire on a 3+ roll.
Uses the Black Powder war machine misfire chart with a -1 on the roll.
Dreadquake Mortar 155 points
M WS BS S T W I A LD Troop Type
Mortar - - - - 7 3 - - - War-machine
Chaos Dwarf 3 4 3 3 4 - 2 3 9
Slave Ogre 6 3 2 4 4 3 2 3 7
Unit Size: One Dreadquake Mortar and three Chaos Dwarf crew.
Equipment (Crew)
*Heavy Armour
(Chaos Dwarf only)
*Hand Weapon
Special Rules
*Resolute
*Relentless
*Contempt
Options
*The Dreadquake Mortar my be crewed by an additional Slave
Ogre.............................................................................................20 points
(note this adds three extra wounds rather then one)
*It may be mounted on a Steam Carriage if there is at least one Iron
Daemon in the Army....................................................................25 points
*The Iron Daemon may be Hellbound........................................25 points
Large Template
S5/S10 1D6 wound
Equipment (Crew)
*Heavy Armour
(Chaos Dwarf only)
*Hand Weapon
Special Rules
*Resolute
*Relentless
*Contempt
Options
Gerald wkleiłeś z PDF-a by Ogr Mage.
A na stronce FW są troche inne.
Bazowy koszt to 195.
Quake powoduje, że zdajesz dangerousy jak ruszasz się lub strzelasz z broni Move or Fire.
I nie ma large template
oraz inicerating.
Infernal Puppet pisze:Skavenom udaje się 100%, nieudane projekty to sabotaże konkurencji więc się nie liczą.
Taki tam niusik z CDO
tradycyjne źródło niusaloeś z WF w odpowiedzi na maila od Veshnakar pisze: Hi there.
Firstly, thanks for your support regarding our Chaos Dwarf releases. We do plan to release a few more things for them but at present we don’t have any plans for normal Chaos Dwarf warriors before the end of the year. We will be releasing one or two more character models as well as a two different Bull Taurus models.
Thanks
Tris Buckroyd
- gerald_tarrant
konkurencyjnie ci się też rozpuszczą/popękają...
Forge World Chaos Dwarf Hellsmith Games day 2011: http://cgi.ebay.com/Forge-World-Chaos-D ... 1e65ecebc8
- Ulegasz stereotypom.
