ETC 2016 relacja
Moderator: swieta_barbara
Macias
Re: ETC 2016 relacja
Post autor: Macias »
To 11 straty jest już wliczając karne z tego co się orientuję.
Imperialna moc!
Artur
Post autor: Artur »
A ruskie nie wtubią makaroniarzom ?
Macias
Nawet jeśli to włosi mają tak gigantyczną przewagę że wygraną mają praktycznie pewną. Jak hiszpanie stracą co najmniej 3 pkt to włosi wygrywają bez względu na swój wynik.
EDIT Laik przegrał do 1 wg TK
Imperialna moc!
Kalesoner
Szczur Królów
Post autor: Kalesoner »
Jak Francuzi zrobią Maxa, to nie mamy szans na 2gie.
EDIT:
El Rey opisuje sytuację karniaków dla Hiszpanów:
Here is what happen with the Spanish BH player in the game vs Denmark. He told the danish player that the unit was sober, they chatted about it at the start, that he only needed 2 scoring units. And the danish player stay away from beast army because the unit was sober and there could move fast with light troops and then join mino lord to the unit. In turn 2 IIRC the BH player had to take a panic test on the centaur unit, which he rolled for and failed twice. He then claimed they where drunk instaed of sober, so they did not have to take the test in the first place. He the danish player got rightly upset and got me as coach and we got the judges. They ruled that the unit feld, because if he was not sober, why had he taken the panic test in the first place.
So that was the first issue in this game with the player. As the centaur unit ran off the table some other units had to take panic test. Here the danish player asked if the small unit of centaurs with mino character in it, had to take a panic test. They where within 6". The BH player aid no, because the unit is frenzy because of the minotaur. So he did not. It was right on the table edge, so if failed it would have run off. We first took his word for it. But I went to ask the german BH if it was true later and he told me it was not. I then went to get the jugde and went down to the table. I find it unlikely the BH player did not know the rule. So now there had be 2 cases in the same game, where is shows this guy is not playing legit. Furthermore in games befoe this, against Russia the BH had also cause problems, which Russia complained about.
Artur
Post autor: Artur »
Swoją droga bardzo dziwne: Lohost nienawidzi Tinego jak psa, a ten siedzi prawie połowę relacji tylko przy jego stole - czy jest świadomy ryzyka ? :D
Roksana
Post autor: Roksana »
Artur pisze:Swoją droga bardzo dziwne: Lohost nienawidzi Tinego jak psa, a ten siedzi prawie połowę relacji tylko przy jego stole - czy jest świadomy ryzyka ? :D
połowę? Większość zdjęć na instagramie jest właśnie z ze stołu Lohosta :)
jawor
Post autor: jawor »
Co się stało u Laika?
JarekK
Bothunter
Post autor: JarekK »
Abrasus 16-4
Furion
Post autor: Furion »
Abrasus kończy ETC z 52 / 80, średnia 13 na mecz.
Bardzo ładny wynik, gratulacje!
Gasior
Post autor: Gasior »
Lohost 20!!
:twisted: always Vampire :twisted:
Shenq
Post autor: Shenq »
U laika ze zdjęcia widać że stardragon ostał się na 1 ranie, peszek
JarekK
Bothunter
Janus 14!
JarekK
Bothunter
Guldur 10!
Roksana
Marek 18
rover
Post autor: rover »
No Panowie, cisnac jakby nie bylo jutra :)
Macias
No to potrzeba 21 od Crusa+Shina żeby był max
Imperialna moc!
Furion
Jeszcze czekamy na Ordinowców, z 6 graczy na razie 79 punktów.
Laik z Szaitisem widać, że w ogóle nie zgrani. Mogli zrobić wyniki na krzyż, wtedy Ż-34 zostało by zdetronizowane na rzecz M-33 ;)
Shenq
Post autor: Shenq »
Jak sytuacja u shina i crusa?
Jest max info fb
Ostatnio zmieniony 7 sie 2016, o 17:25 przez Shenq, łącznie zmieniany 2 razy.
Macias
Crus 8
Imperialna moc!
Shakin' Dudi
Post autor: Shakin' Dudi »
Gdzieś są jakieś foty jak to u Shina i Crusa wygląda?
