Zacząlem analizować Twoją rozpiskę Luc i coś mi się nie zgadza
obecne ograniczenia:
masz 38 magicznych strzałek - 2 wyboryWood Elves
All limits are about models, you can spread them anyway you like among units, unless
otherwise specified.
May select up to 5 choices from the pool below:
● Each mounted character using the Lore of Death – 1 choice (3 choices if 6 or more sisters of the thorn are present in an army)
● Each unit of Wild Riders after the first – 1 choice
● Each 10 Waywatchers (or part thereof) 1 choice
● Each 15 models (or part thereof) equipped with trueflight arrows or hagbane arrows after the first 15 models 1 choice
● Each Waystalker after the first – 1 choice
● Moonstone of the Hidden Ways – 1 choices (4 choices with lore of death)
● Acorn of Ages (if taken with Moonstone of the Hidden Ways) 1 choice
● Sisters of Twilight 2 choices
May take any Wood Elf Special Characters
sisterki na orzełku - 2 wybory
15 waywatcherów - 2 wybory
do tego jest jeszcze zapis
bohaterowie w Twojej armi kosztują w sumie 1385pkt jeśli dobrze policzyłem i jest to 57,7% czo daje kolejny 1 wybów.Generic pool choices
The following pool choices apply to all armies with the exception of Orcs and Tomb Kings(as
they have no pools)
● If the total points spent on all lords and heroes is greater than 50% of the armies points 1 pool choice
● If the total points spent on all lords and heroes is greater than 60% of the armies points 1 further pool choice
● If the army contains one or more characters with leadership 10 for the purpose of ‘Spirit Leach’ and one or more wizards with access to the lore of death spell 'Spirit Leech' 1 further pool choice
W sumie masz 7 wyborów na 5 możliwych. Chyba że źle interpretuje jakieś zapisy
