Kodex IndyChD i faqi
Moderator: esgaroth
Re: Kodex IndyChD i faqi
Hexacon daje kości dispela więc chyba tak, jeśli użyje ich lord....
Chłopska Bretka
Update z 4 grudnia 2010
(wklejam kontekst i kolorem to co się zmieniło)
1.) Kolossus:
(...)Daemonic War Platform
Unlike other war machines, Kollossus Daemon Towers may make march moves and declare charges as normal. The Kollossus may move and shoot, and may declare a Stand and Shoot charge reaction. Additionally, ignore the war machine rules as described in the Warhammer rulebook for ‘Charging a War Machine’ and ‘Warmachines in Close Combat’. The Kollossus Daemon Tower is treated as an ordinary unit for the purposes of charging and close combat. This means any model in base contact/supporting attacks with the Kollossus may attack it and the entire Kollossus crew may attack any unit(s) it is in base contact with. Impact hits use the Strength of the Kollossus (S5). The Kollossus does not automatically fail characteristic tests, it uses the highest characteristic value of the particular characteristic being tested from either the Annihilator crew, accompanied character or the tower itself. Always use the best armour and ward saves from the surviving crew or character against all wounds inflicted upon the Kollossus model.(...)
2.)Errata: Armour of the Furnace, the armour provides a 2+ ward save against flaming attacks rather than being completely immune to them.
3.)Errata: Axe of Zhrazak, the weapon provides the bearer with +2 Strength and the Always Strikes First special rule.
4.)Earthshaker Cannon
• Change "halve their Movement value" to "halve their TOTAL Movement".
5.) Dwarfs of Chaos FAQ
If a Character riding demon tower has Amulet of Hashut how many attacks do anihilators get +1 total or + 1 per anihilator( or per wound), should it be 1 total as its 1 model.
-----------The entire crew become subject to Frenzy.
ŹRÓDŁO(warmongers) 4.12.20010
1.) Kolossus:
- gerald_tarrant
tak sobie myślę, żeby pocisnąć na jakiś tur chadecją i teraz pytanie
czy na turniejach na zasady euro można grać Indy GT?
(mały) UPDATE Z 10 STYCZNIA 2011
1.) Hobgoblin Spear Chukkas
* Have 3 Hobgoblin crew, rather than just 2.
2.) Kollossus Daemon Tower 300 pts/model
Character Mount
As described in the army list entries, a Chaos Dwarf Overlord, Slavemaster or Daemonsmith may ride atop a Kollossus Daemon Tower. Only a single character may ride a single Daemon Tower. When this option is taken, the character replaces one crewmember. Since character models have more wounds than ordinary crew, they will increase the total wounds of the tower as follows: a Kollossus ridden by an Overlord will have 12 Wounds, a Kollossus ridden by a Slavemaster or Daemonsmith will have 11 Wounds. Always the first 9 wounds will be inflicted upon Annihilator crew; the remaining wounds will then affect the character. This means the last crewmember will always be the character. Characters use their own Weapon Skill to attack in close combat, though the majority Weapon Skill of the crew is used for all other close combat purposes.
Character Mount
- gerald_tarrant
Barth pisze:(mały) UPDATE Z 10 STYCZNIA 2011
- gerald_tarrant
że tak ożywię dyskusję:
ile cali od klocka zwykle strzelacie z rakietki?
bo zwykłym cannonem optimum to imo 6 cali, ale my nie mamy bouncea tylko templatę.
jakie macie przemyślenia na ten temat?
Nie wiem czy to dobre miejsce na tą informacje ale na Masterze w Krakowie dopuszczamy podręcznik Indy GT. Mam nadzieje że w związku z tym pojawią sie liczni reprezentacji waszej armii.
No więc Panowie malujcie figuraski bo na 2800 p. wejdzie tego troszkę
Czcij Koze !!
- gerald_tarrant
Helcannon 0-1 jak u Warriorów
limit 30 blunderbussów
limit 5 template weapons/war machines działa dobrze na nasze monster&handlery
hexagon=1dd
imo będzie ok
hexagon=1dd
imo będzie ok
- gerald_tarrant
