KULTOWO DRUŻYNOWO 8 ETC rules Wawa 15/01/11
- Offspringman
- Kretozord
pilneOffspringman pisze:niestety Pedros się posypał.
szukamy trzeciego do skladu.
na razie mamy WoCh i VC
Jak zawsze
no to i my zagramy - "MSWi... Gamonie" czyli Draco, Śmiechu i ja
- Jedy Knight
- Forma Skrótowa
Możecie zacząć się przygotowywać. Będzie tak;
_Barbarossa_ pisze:So here's what we should publish maybe. Still not convinced about HE losing the +50 points.
ETC AR 4.0
Open rosters are to be sent to jedyknight@poczta.fm by the captains of the teams, by July 14th.
Rosters will be published on this forum as soon as possible, all at the same time.
Faulty rosters, or the ones sent after this date shall be penalized. (Basic penatly = 5 points).
Force majeure exemptions possible.
Rules changes:
I. General Restrictions:
2400 Points.
Army used can be any of the currently published GW Army books.
An army may have up to 5 war machines and template weapons. Warmachines that use a template count as a single choice in this regard. All template weapons (from magic items, abilities, etc.) count, except for spells.
Magic Restrictions:
- Apart from Winds of magic and Channeling, an army may only generate 2 PD/DD per magic phase.
- “Count as” items/abilities may never exceed a cumulative 2 PD/DD per phase. This means that if you take the Book of Hoeth, you may not take any other items that “count as adding PD/DD”
Detailed description
Apart from winds of magic and through the channeling rule, an army may only ever add 2 dice to its power or dispel pool in each magic phase. Any dice added to the pool, regardless of source (generated, stolen, stored from previous magic phases, generated by magic items/abilities to boost spellcasting before or after the casting attempt, produced by spells, lore abilities, and so on) count. Excess dice are simply discarded and cannot be used in any way (i.e. - they can’t be stored).
Item restrictions:
- Power Scroll is banned
- Each Loremaster ability counts as generating 1 PD each magic phase
Army Specific Restrictions:
Beastmen: No Restrictions
Bretts: No Restrictions
Dark Elves: Hydra is a 0-1 choice. Max. 35 repeater Crossbows in the army. Repeater Bolt Throwers 0-2.
Dwarves: Each spellbreaker/spelleater rune counts as +1 DD. Grudge Throwers are a 0-2 choice; May generate Max. +4 dispel dice instead of +2
DOC: Max. 28 Models per unit; Flamers are a 0-1 choice. Siren Song may only be taken once
Empire: Steam Tank counts as a war machine; Tank, Rocket battery and Engineers are a 0-1 choice
High Elves: Max. 500 points or 40 models per unit; Vortex Shard counts as +1DD; Book of Hoeth counts as 2PD and 2 DD; Banner of the World Dragon counts as +1 DD
Lizardmen: Salamanders are a 0-1 Choice; Terradons, Chameleon Skinks and Stegadons (any kind) are 0-2 choices; Beclaming Cogitations counts as +1 PD and +2DD; Cupped hands counts as +2PD
Ogres: No Restrictions
O&G: No Restrictions
Skaven: All Skaven rare choices 0-1; Gutter runners are a 0-2 choice; Engineers are a 0-3 choice;
Vampires: Wraiths and Varghulf are 0-1 choices. Wraith unit size - maximum 5 models. Army may have maximum two units (total) of: wraiths, black coach or spirit hosts.
TK: No restrictions
WE: Wand of Wych Elm counts as +1 DD
Warriors of Chaos: Hellcannon is a 0-1 choice. Infernal Puppet counts as +1 PD and +2DD; Tendrils of Tzeench and Conjoined Homunculus both counts as +1 PD.
II. Pairings.
1.
Both Teams put up 1 army.
Both Teams put up 2 opponents
Both Teams choose their match
2.
3.
4.
Both teams put up 1 army.
Those 2 armies face each other.
The remaining 2 armies face each other.
All this must be time limited to 30 minutes max.
Tables - random.[/color]
III. Scoring
We are considering the following victory points mechanic, and encourage you to test it and provide feedback:
In both cases, bonuses (for generals, banners, etc.) are not counted towards the 50%.
0-20 Victory-Points per game
60-100 Battle-Points per team, except for the last round, when the lower limit is dropped.
(The losing team gets 60 points even if they score less[except in the final round] – the winning team never gets more than 100 points, even if they score more. Real Battle Points [non-limited by the 100-60 bracket] will be used in case of the Battle Points tie as tie-breaker.)
Victory points to Battle points per game:
0-150 Victory-Points difference - 10-10
151-300 - 11-9
301-450 - 12-8
451-600 - 13-7
601-750 - 14-6
751-900 – 15-5
901-1050 – 16-6
1051-1200- 17-3
1201-1350- 18-2
1351-1500-19-1
1500+ - 20/0
IV. Scenarios
There will be no scenarios at the ETC due to: lack of good proposals and balance issues.
V. Virtual Line of Sight
Size chart:
0: Swarms - models of this size never block line of sight or give cover.
1: Infantry, War Beasts, War Machines
2: Cavalry, Monstrous Infantry/Cavalry/Beasts, Chariots, Unique without the Large Target rule
3: Monsters, all Large Targets
Line of sight is always checked virtually, drawn "base to base". Models see in their front 1/4 zone. Line of Sight is blocked by models that are equal to or larger than both: the model whose line of sight we are checking and its target.
Line of sight and war machines:
Catapults (and similar) can place their template so that the center is over any one unit that is at least partially visible to them.
Cannons can choose any point between themselves and a visible target when firing. Over- or under-guessing to shoot at units the cannon does not have line of sight to is not allowed
Terrain
Hills are size two for each level (so a 3-step hill is size 6) and block sight / give hard cover just like models of that size. Models standing on hills add the hill size to their own size. Buildings and large rocks always block line of sight completely. Forests do not block line of sight, but soft cover applies to all shots fired through or into (but not out of) forests. Ruins do not block line of sight, but hard cover applies to all shots fired into (but not through/out of) ruins. Units standing behind obstacles gain soft (wood) or hard (stone) cover as per the RB.
Cover from intervening units/terrain
Cover is granted when at least 50% of models in target unit are fully or partially obscurred by other units/terrain from the shooting model. In order for intervening models to grant cover, their size must be at least: one point smaller than both the target unit and the shooting model.
Skirmishers
Skirmishers never block LoS, and are seen in accordance with their size on the chart, but provide cover as per the above rules. The gap between skirmishers is treated as part of the unit when determining if skirmishers give cover to something behind them. Skirmishers formed up for combat block Line of Sight like normal units.
- Jedy Knight
- Forma Skrótowa
DS 2/3.
Still looking.
Still looking.
- swieta_barbara
- habydysz
Tego nie ogarniam. HE sa za slabe? Moim zdaniem draft nr 2 byl lepszy._Barbarossa_ pisze:So here's what we should publish maybe. Still not convinced about HE losing the +50 points.
- Jedy Knight
- Forma Skrótowa
Grasz w Sobotę, Trollu?Grolshek pisze:Trzeba bidulkom elfom dorzucić jeszcze z 50 pkt. żeby mogły ponad 30WL wystawić... A chosenów obciąłbym do piętnastu... Grały tyle lat na każdym turnieju w 7ed. więc pora obciąć to przegięcie !!!
Mogę twoje Warriory wziąć do teamu i słuchać cię przez 8 godzin. Masz większe szanse niż na forum. Co wybierasz?
- swieta_barbara
- habydysz
Nawet Tobie czasem sie cos udaJedy Knight pisze:Grasz w Sobotę, Trollu?Grolshek pisze:Trzeba bidulkom elfom dorzucić jeszcze z 50 pkt. żeby mogły ponad 30WL wystawić... A chosenów obciąłbym do piętnastu... Grały tyle lat na każdym turnieju w 7ed. więc pora obciąć to przegięcie !!!
