Nasze Rozpiski
Moderator: Yudokuno
Pomysł na domówke bez żadnych ograniczeń
Unnamed2000 Pts - Dark Elves Army
1 Supreme Sorceress @ 320.0 Pts
General; Magic Level 4; Lore of Shadow
Tome of Furion [15.0]
1 Master @ 217.0 Pts
Lance; Heavy Armour; Sea Dragon Cloak; Battle Standard
Pendant of Khaeleth [35.0]
Enchanted Shield [15.0]
1 Dark Pegasus @ [50.0] Pts
1 Death Hag @ 200.0 Pts
Poison Attacks; Cauldron of Blood; Frenzy; 2ndWeapon
1 Cauldron of Blood @ [110.0] Pts
2 Hag Attendant @ [0.0] Pts
Frenzy; 2ndWeapon
20 Dark Elf Repeater Crossbowmen @ 215.0 Pts
Rptr Crossbow; Light Armour; Standard; Musician
38 Black Ark Corsairs @ 420.0 Pts
Frenzy; 2ndWeapon; Light Armour; Sea Dragon Cloak; Standard; Musician
Sea Serpent Standard [25.0]
1 War Hydra @ 175.0 Pts
2 Beastmaster @ [0.0] Pts
Beastmaster's Scourge
5 Harpies @ 55.0 Pts
Models in Army: 90
Total Army Cost: 1992.0
Co o tym myślicie
Pozdro Czcibor
Frenzy; 2ndWeapon
Models in Army: 90
Co o tym myślicie
Pozdro Czcibor
Można by jeszcze dorzucić 2 piątkę harpii zamiast kilku korsarzy, ale to już taki drobny szczegół
2012 Pts - Dark Elves Roster
Total Roster Cost: 2005
Highborn (1#, 265 pts)
1 Dreadlord, 170 pts = (base cost 140 + Dark Steed 18 + Heavy Armour 6 + Sea Dragon Cloak 6)
1 Soulrender, 15 pts
1 Dragonhelm, 10 pts
1 Pendant of Khaeleth, 35 pts
1 Crown of Command, 35 pts
Noble (2#, 215 pts)
1 Master (Battle Standard Bearer), 115 pts = (base cost 80 + Lance 4 + Heavy Armour 4 + Shield 2 + Battle Standard Bearer 25)
1 Dark Pegasus, 50 pts
1 Cloak of Hag Graef, 25 pts
1 Dawnstone, 25 pts
Sorceress (1#, 125 pts) Death
1 Sorceress, 100 pts
1 Darkstar Cloak, 25 pts
Sorceress (1#, 160 pts) Fire
1 Sorceress, 135 pts = (base cost 100 + Level 2 Upgrade 35)
1 Dispel Scroll, 25 pts
Repeater Crossbowmen (20#, 240 pts)
19 Dark Elf Repeater Crossbowmen, 224 pts = 19 * 11 (base cost 10 + Shield 1) + Musician Mus 5 + Standard Bearer Std 10
1 Guardmaster, 16 pts = (base cost 15 + Shield 1)
Repeater Crossbowmen (20#, 220 pts)
19 Dark Elf Repeater Crossbowmen, 205 pts = 19 * 10 (base cost 10) + Musician Mus 5 + Standard Bearer Std 10
1 Guardmaster, 15 pts
Harpy Coven (5#, 55 pts)
5 Harpies, 55 pts = 5 * 11
War Hydra (3#, 175 pts)
1 War Hydra, 175 pts
2 Beastmaster, 0 pts
Reaper (3#, 100 pts)
1 Reaper Bolt Thrower, 100 pts
Turniej bez limitów na 2012 punktów - co myślicie?
Noble (2#, 215 pts)
1 Dawnstone, 25 pts
Zajebiste
Wszystko co w tej armii najlepsze.
Ja bym tylko zmienil minimalnie bohaterow. Na tym BsBku gralem wlasciwie od samego poczatku i zdecydowanie lepiej dac mu zwykly bicz niz lance.
No i zestawienie itemow na 2 magiczkach. Polecam moj utarty standardzik: Seal+Tome na deathie i DS/Oko na fajerze. Death jest zdecydowanie skuteczniejszy przy 3 czarach. Masz duzo pewniejsza silowke no i jeden z dwoch zajebistych czarow - -3ld i -1s/t. Zajebistosci oka nawet nie chce mi sie komentowac
Punkty na lvl na deathie i komplet itemow:
Jedna 20stka kusz na 10szke (ciezko sensownie wystawic 3x20 ). Za to wchodza itemy na sukach i 3cie harpie.
Pozdro.
P.S
Nie sluchaj Rastiego. Kontry masz w sam raz
Mnie tyle wystarczalo na premackowych turniejach grajac w parze z krasiami, a to bylo 3k.
Pozdro.
P.S
Przeanalizowałem Twoją radę Rince - tylko ,że nie da się tak zrobić - mam 503 punkty na herosów - w tej chwili wykorzystuje 502
... Wprowadziłem takie zmiany ( trzecich Harpii niestety nie mam ) więc dałem Shadów...
Total Roster Cost: 2007
Highborn (1#, 275 pts)
Dreadlord, 180 pts = (base cost 140 + Dark Steed 18 + Repeater Crossbow 10 + Heavy Armour 6 + Sea Dragon Cloak 6)
Noble (2#, 217 pts)
Master (Battle Standard Bearer), 117 pts = (base cost 80 + Beastmasters Scourge 6 + Heavy Armour 4 + Shield 2 + Battle Standard Bearer 25)
1 Dawnstone, 25 pts
Repeater Crossbowmen (10#, 105 pts)
10 Dark Elf Repeater Crossbowmen, 105 pts = 10 * 10 (base cost 10) + Musician Mus 5
Shades (5#, 85 pts)
5 Shades, 85 pts = 5 * 17 (base cost 16 + Extra Hand Weapon 1)
Help??? Myślałem ,żeby wyrzucić Pegaza i walnąć bsb na konika??
Noble (2#, 217 pts)
1 Dawnstone, 25 pts
Shades (5#, 85 pts)
Faktycznie, zapomnialem o limicie na hero
A tak pieknie sie skladalo!
Chyba nie oplaca sie zamieniac na konia, bo za te 32 punkty jakos wielce magiczek nie podpakujesz.
Ewentualnie moglbys jeszcze pokminic nad opcja magiczki w lordach. 3 lvl z tome of furion chyba sie zmiesci. I wtedy z herosow wywalasz jedna mala i 5tke shejdow. 4 czary z deatha z 3 lvlem bylby baardzo syte w tej rozpie.
Wlasnie na taka bretke (ktora boli porno zlozone delfy) zajebisty jest ten bsbek z biczem. sila 4ap - chyba lepej byc nie moze.
Tak, bardzo. Z 1 lvlem liczysz tylko na zerowke, a ten lore oferuje duzo wiecej naprawde mocnych czarow. Do tego dochodzi kwestia losowosci liderkowej snajperki, ktora ograniczasz dorzucajac w tej samej turze silowke. Oprocz tego cast... 10+ liderkowa, czyli takie powiedzmy pewne 4 kosci. 3 lvl sporo zmienia. Wtedy mozesz np przy 6ciu kosciach i rzutach na wiatry 3/3 4/4, probowac lidere z 3ech i sile z 3ech. Na 7 i na 9. Do tego chodza super fajne czary -3ld i -1t/s, bardzo przydatne przy 50 kuszach i Hydrach z sila 5 vs T4.
No i oczywiscie masz +3 do dispela, a nie gowniackie +1...
heh
Total Roster Cost: 2012
High Sorceress (1#, 225 pts) Death
1 Supreme Sorceress, 225 pts
Noble (2#, 217 pts)
1 Dawnstone, 25 pts
Więcej raczej nie da się wycisnąć - musiałbym z Poka lub Bsb zrezygnować. Coś jeszcze byś zmienił?
Noble (2#, 217 pts)
1 Dawnstone, 25 pts
taka tam rozpiska na chariotach i smoczydle
2400 pkt
Dreadlord standard, ale ma black dragon egg zamiast stubborna( może to błąd, ale podoba mi sie opcja 4d6 z st 4 w combacie dodatkowo
czarodziejka 2 level +1 czar, dodatkowa kosc do dispela, uzywa shadow
czarodziejka, uzywa fire
kociol bsb
core
2x 10 kusznikow z muzykami
25 korsarzy z frenzy fcg
17 warriorow z muzykiem
special
3 x chariots
3 x 5 shejdes
rare
hydra
Mysle co by moze wywalic magiczkę z fire, kilku warriorow i dac 2 x 5 harpii jeszcze
2400 pkt
kociol bsb
core
special
3 x chariots
3 x 5 shejdes
rare
hydra
