Nowy legionowski klub "Nightbreeze" zaprasza na ligę Warhammera Fantasy Battle.
Czas: rozpoczęcie 1 lutego, zakończenie 1 kwietnia
Zasady: Każdy gracz musi rozegrać określoną liczbę bitew z określonymi przeciwnikami. Wszystkie bitwy będą rozgrywały się na zasadach Euro (spisane poniżej). Rozpiski jawne, wysyłamy je na forum klubu 31 stycznia < http://www.wfblegionowo.fora.pl > Miejsce bitwy - dowolne, lub w naszym klubie na piaskach.
Zgłoszenia proszę przysylać do 30.01 na adres nightbreeze.legionowo@gmail.com
Dopuszczalne poxy.
Wpisowe wynosi: 15zl
Gramy na zasadach ETC:
Ograniczenia ETC:
2400 Points.
Army used can be any of the currently published GW Army books.
An army may have up to 5 war machines and template weapons. Warmachines that use a template count as a single choice in this regard. All template weapons (from magic items, abilities, etc.) count, except for spells.
Magic Restrictions:
- Apart from Winds of magic and Channeling, an army may only generate 2 PD/DD per magic phase.
- “Count as” items/abilities may never exceed a cumulative 2 PD/DD per phase. This means that if you take the Book of Hoeth, you may not take any other items that “count as adding PD/DD”
Detailed description
Apart from winds of magic and through the channeling rule, an army may only ever add 2 dice to its power or dispel pool in each magic phase. Any dice added to the pool, regardless of source (generated, stolen, stored from previous magic phases, generated by magic items/abilities to boost spellcasting before or after the casting attempt, produced by spells, lore abilities, and so on) count. Excess dice are simply discarded and cannot be used in any way (i.e. - they can’t be stored).
Item restrictions:
- Power Scroll is banned
- Each Loremaster ability counts as generating 1 PD each magic phase
Army Specific Restrictions:
Beastmen: No Restrictions
Bretts: No Restrictions
Dark Elves: Hydra is a 0-1 choice. Max. 35 repeater Crossbows in the army. Repeater Bolt Throwers 0-2.
Dwarves: Each spellbreaker/spelleater rune counts as +1 DD. Grudge Throwers are a 0-2 choice; May generate Max. +4 dispel dice instead of +2
DOC: Max. 28 Models per unit; Flamers are a 0-1 choice. Siren Song may only be taken once
Empire: Steam Tank counts as a war machine; Tank, Rocket battery and Engineers are a 0-1 choice
High Elves: Max. 500 points or 40 models per unit; Vortex Shard counts as +1DD; Book of Hoeth counts as 2PD and 2 DD; Banner of the World Dragon counts as +1 DD
Lizardmen: Salamanders are a 0-1 Choice; Terradons, Chameleon Skinks and Stegadons (any kind) are 0-2 choices; Beclaming Cogitations counts as +1 PD and +2DD; Cupped hands counts as +2PD
Ogres: No Restrictions
O&G: No Restrictions
Skaven: All Skaven rare choices 0-1; Gutter runners are a 0-2 choice; Engineers are a 0-3 choice;
Vampires: Wraiths and Varghulf are 0-1 choices. Wraith unit size - maximum 5 models. Army may have maximum two units (total) of: wraiths, black coach or spirit hosts.
TK: No restrictions
WE: Wand of Wych Elm counts as +1 DD
Warriors of Chaos: Hellcannon is a 0-1 choice. Infernal Puppet counts as +1 PD and +2DD; Tendrils of Tzeench and Conjoined Homunculus both counts as +1 PD.
We are considering the following victory points mechanic, and encourage you to test it and provide feedback:
In both cases, bonuses (for generals, banners, etc.) are not counted towards the 50%.
Konatak: PW, GG 7287038 lub mail nightbreeze.legionowo@gmail.com
Serdecznie zapraszamy i Pozdrawiamy klub nightbreeze
Liga Legionowo od 01.02
Ostatnio zmieniony 9 sty 2011, o 20:07 przez Trubas, łącznie zmieniany 1 raz.
Jeżus pisze:Trubas okazałeś się mieć większą choppę, więc masz swoją nagrodę:
Zawsze chciałem być w Nemezis
nowy FAQ jest
''Three things make The Empire great – faith, steel and gunpowder!"
Legionowski Klub Miłośników Fantastyki
http://www.facebook.com/pages/Legionows ... 0549447769
