Uściślenia na ETC
Lidder
Uściślenia na ETC
Post autor: Lidder »
Info dość ważne dla naszych graczy. Zapewne śledzicie temat, ale tutaj topic będzie otwarty. Będzie można wyciągać wnioski jak zmiana zasad, nawet niewielka, wpływa na rozpiskę.
Link: http://warhammer.org.uk/phpBB/viewtopic ... 18&t=86122
Movement Phase
1. Are “virtual pivots” allowed?
A. Yes
Magic Phase
1. Various spells and effects: “Place the template within 24...”. Does this mean one part of the template needs to be within 24”, or just its center, or the whole template?
A. Just the center.
Shooting Phase
1. Cannon sees nothing. Can he fire at empty spots and hit models behind hills and other models?
A. No
2. Cannon sees a dragon. Yet he doesn't see the spot 8” in front of dragon (other units are in the way). Can he fire an optimal shot against the dragon?
A. Yes
3. Do war machines have arc of sight?
A. yes
4. A template hits the seer & screaming bell. Who is hit and how?
A. Both hit
5. On a similar note, does a Seer on the Bell get a Look-out sir roll against templates?
A. No.
6. When the bell is hit but not killed by cannon ball, does it stop the cannon ball?
A. Yes
Close Combat Phase
1. Abomination purchases warpstone spikes to give “Warpstone Weapons” to all of its attacks. Does this include the thunderstomp or results 1-2 and 5-6 from its table?
A. Only 1-2 and 5-6
Magic Items
1. Does the Other Trickster’s Shard force its bearer to re-roll his ward saves?
A. No
2. Models with a ward save, some of them in contact with the Other Trickster's Shard, some not. Do wounds from targeted attacks to sharded models carry over to unsharded models?
A. Yes
Other
1. Do you always have to use the generals leadership gained through Inspiring presence
A.No, always use the best Ld available.
Dodatkowo informuje, że co tydzień (mniej więcej o tej porze) wpada po 25 pytań. Jeśli macie jakieś pytania czemu tak a nie inaczej to pytajcie. Kto jak głosował nie zdradzę, ale będę podawał argumenty, które przeważyły.
L.
kudłaty
Post autor: kudłaty »
Czyli jednak na ETC nie gramy z LD generalską zawsze?
Dastor
Post autor: Dastor »
Wirtualny pivot też od jednostek wroga, czy tylko od terenów i swoich ?
Lidder
kudłaty pisze:Czyli jednak na ETC nie gramy z LD generalską zawsze?
Podobno wychodzi FAQ na początku maja, które to potwierdzi.
Dastor pisze:Wirtualny pivot też od jednostek wroga, czy tylko od terenów i swoich ?
j.w. będzie wspomniane o krawędzi stołu. Na razie masz zawsze wirtualny pivot.
Rince
Post autor: Rince »
Rotfl... wirtuale o jednostki wroga to jakies nieporozumienie.
Dastor
Mega bieda....
Goglem
Post autor: Goglem »
Może jestem daleko za murzynami, ale o co chodzi z tym virtual pivotem ?? :mrgreen:
Myth
Post autor: Myth »
EDIT: bzdury napisałem, Lidder wyjaśnił, więc się nie kompromituję i nie mieszam ;-)
Ostatnio zmieniony 20 kwie 2011, o 12:36 przez Myth, łącznie zmieniany 1 raz.
Lidder
Goglem pisze:Może jestem daleko za murzynami, ale o co chodzi z tym virtual pivotem ?? :mrgreen:
Chodzi o to, że pivot to nie część ruchu. Jednak musi on wciąż się kończyć w legalnej pozycji - nie na inpasach, i "1'' od".
Król Goblinów
Post autor: Król Goblinów »
czyli virtual pivot to aktualnie niemożnośc zablokowania abomki/czołgu, yes?
Lidder
Król Goblinów pisze:czyli virtual pivot to aktualnie niemożnośc zablokowania abomki/czołgu, yes?
yes, ale na ETC. U nas gramy jak ja każę :mrgreen:
Lidder
są bonusy z tego, że pracuje nad tym. dostaje non-stop spojlery co będzie w nowym FAQ GW... oj zdziwicie się... :D
Manfred
Post autor: Manfred »
a data wyjścia FAQ'a ?
Lidder
koło 7.
Furion
Post autor: Furion »
Lidder pisze:Jeśli macie jakieś pytania czemu tak a nie inaczej to pytajcie
Ok. Na WTF ociągają się z odpowiedziami, może tu dostanęje szybciej ;) Przekopiuje tekst po angielsku, nie będę dwa razy tego samego pisał.
49. Can I freely decide how early or late to generate spells for wizards as long as it happens before I deploy any of them? (relevant BRB rule: p. 142, Deploment: "Before you deploy any of your Wizards, remember to generate..")
A. No. Roll when the match is starting, even before choosing sides.
Justify this answer please. Would love to hear the line of thought behind that one!
12. Can i place a template direct damage spell/or and its centre out of a unit and hope for a lucky scatter (Pit Of Shades) when spells discription states "anywhere within 24"?
A. No, must be placed on a unit.
Q: Do ranged direct damage spells that use a template have to
target an enemy unit? (p31)
A: Yes, the template must be placed over the target enemy
unit.
Q: When targeting a unit with a small or large round
template, must the whole template be within the maximum range
of the spell? (p31)
A: No, the hole in the centre of the template must be within
range.
How come you came to a conclusion that center must be placed on unit?
31. Will using a swift reform to enter a building from a long distance away "teleporting" the reforming unit be considered "worst play" in the same way as miner congas were at previous ETCs?
A Yes
Clarification required. What does "long distance" mean? Do you mean:
a) x > Mv
b) Mv < x < 2xMv
c) x < 2xMv
48. Can Vampires cast Vanhel's Danse Macabre only on their front (with the unit in which they are in and themselves counting as "in front" ) or can they cast the spell in a 360° radius as it was in the 7th edition?
A. It can be cast on any unit, meaning a 360° radius. 'Old' spells follow their own wording, but cannot be cast into combat unless otherwise mentioned.
How on earth you came to that conclusion? It hasn't been FAQ'd and rulebook clearly says "unless stated otherwise (...)" [page 31]
