Morenówka 2013 - Lokal w Gdańsku 23.03.2013
Moderatorzy: Laik, Dymitr
Młody
Post autor: Młody »
Morenówka 2013
1.Turniej organizowany jest przez klub SNOT i odbędzie się w dniu 23 Marca 2013. W Gdańsku-Morenie w domu Kultury na Nałkowskiej 3.
2.Wpisowe na turniej 10 zł od osoby,
Gramy w składach 3 osobowych, armie w drużynie nie mogą się powtarzać.
3.Kompozycja Armii
a)Gramy na 1600 pkt. Zasady Euro
Rules changes:
- Two characters per unit (owner's choice) will get "look out sir" versus the following spells that automatically kill models or automatically remove an entire regiment: Dwellers Below, Final Transmutation, Dreaded 13th, Infernal Gateway 11-12 effect. Normal requirements for lookout sir apply.
I. General Restrictions:
1600 Points.
Army used can be any of the currently published GW Army books. Forge World based army lists & units may not be used on the event, except for Chaos Dwarves.
An army may have up to 3 war machines and shooting template weapons. Warmachines that use a template count as a single choice in this regard. All template weapons (from magic items, abilities, etc.) count, except for spells. Bolt thr. count as ½ a war machine(round up).
No lord choices
0-2 same character choices
0-2 same core choices
0-2 same special choices
0-1 same rare choices
Units cannot be more than 30 models nor 350 points (including all command, upgrades, magic items/banners). This restriction applies during the creation of the roster - unit size/cost may be increased during the game (for example - by joining characters to the unit). This restriction does not apply to characters.
Magic Restrictions:
- No duplicate non-signature spells(not including bound spells) and max 2 Spirit Leech
- Player can use maximum 5 PD to cast a spell. For death & shadow spells this max is lowered to 4 power dice.
- An army may use up to 12 PD during each phase.
Detailed description
Apart from Winds of magic, an army may only use 2 PD/DD per magic phase (unless army restrictions specify otherwise). After an army generates the limit all the other extra dice are discarded. This includes channeled PD/DD.
Item restrictions:
Army Specific Restrictions:
Bretonnia
No additional Restrictions
Beastmen
Same core choices 0-3
Beastmen armies have an extra 150 points for their roster (1750 total)
All victory points scored against this army are decreased by 10% (excluding bonus points for banners, general, etc.)
Beastmen can generate 3 extra pd instead of 2
A unit cap of 50 models per unit and point cap on units 450 instead of 350 pts.
Chaos Dwarfs
Lore of Hashut can be cast with max 4 PD.
Chalice of darkness counts as 2 pd
Iron daemon, K'daii destroyer, taur'ruk, count as war machines.
Max 2 out of Str. 5 shooting templates/Lore of death/Lore of Hashut.
Daemons of Chaos
No additional restrictions
Dark Elves
Max. 25 repeater Crossbows (excluding chariots & characters) in the army.
Shades max 15 models per army.
Pendant of Khaeleth/Hydra max 1 in total
Assassins/Rending stars max 2 in total.
Dwarfs
Each spellbreaker/spelleater rune counts as +1 DD
Grudge Throwers are a 0-2 choice
May generate Max. +4 dispel dice instead of +2
Gyrocopter doesn't count for max 5 war machine/template.
Can have 4 war machines
The Empire
Cannon/Steam tank/unit of Demigryphs, max 3 in total.
High Elves
High Elves armies have an extra 50 points for their roster (1650 total)
High elves army can generate extra 3 powerdice instead of 2
Banner of the World Dragon counts as +1 DD
Same rare choices 0-2 instead of 0-1
Lizardmen
Dispel scroll/Cube of Darkness max 1 in total.
Ogre Kingdoms
Dispel scroll/Hell heart, max 1 in total.
Hell heart count as 1 DD
Max 10 Leadbelchers/maneaters with pistols in total
Rune Maw Banner counts as 1dd.
Iron Blaster/Banner of Discipline max 1 in total.
Max 2 combined units of Mournfang Cav & Ironblaster.
Orcs&Goblins
Night Goblin Shamans mushroom dice do not count as power dice in regard to the PD limit
Maximum model cap is 50 models per unit
Fanatics/Mangler squigs max 6
O&G have an extra 100 pts for their roster (1700 total), scores are NOT decreased by 10%
Skaven
Doom Rocket/Brass Orb/Storm Banner max 1 in total
Tomb Kings
Tomb King armies have an extra 100 points for their roster (1700 total)
Neferra's Scrolls of Mighty Incantations counts as 2 PD and 2 DD
Hierotitan is worth 1 PD so long as it's alive
Tomb Kings may generate up to 3 power dice per phase
Vampire Counts
Ethereal units 0-2, and max 1 of same kind/characters.
Howls/shrieks max 2 in total.
Warriors of Chaos
Talisman of Preservation/Armour of Destiny/Third eye of Tzeentch, max 1 on same model.
Chimera 0-1
Wood Elves
Wood Elf armies have an extra 100 points for their roster (1700 total)
b)Na turnieju obowiązują aktualne uściślenia sędziowskie
4.Gramy 4 bitwy na stołach 48x48 cali
5.Turniej zaczyna się o 9.30
6. Przedziały punktowe
- 1 Duży pkt co 120 małych
7.Bonusy za Generała, Sztandar Armii po 75 VP, Sztandary po 25 , i zabicie herosa czempionem 50 pkt.
8.Dopuszczamy proxy ale proszę zbytnio nie przesadzać z proxowaniem ;)
9.Program Imprezy
Sobota
9.30- 11.30 I Bitwa
11.30- 13.30 II Bitwa
13.30- 15.30 III Bitwa
15.30- 17.30 IV Bitwa
Dodając obsuwy prawdopodobnie skończymy z pół godziny później. ;)
10.Turniej będzie zaliczony do Polskiej Ligi.
11.W każdej bitwie gramy Battleline
12.Na turnieju będzie dostępne cappucino i herbatka za free ;]
13.Sędziowie
Główny:
Karol Pietrowicz
Ostatnio zmieniony 6 mar 2013, o 18:13 przez Młody, łącznie zmieniany 5 razy.
Pozdro
Młody
Snot Fanpage
Młody
Post autor: Młody »
Lista zgłoszonych:
1. Snot Alfa - Jagal, Macias, Młody
2. BWT
3. Zad Trolla
4. Demonic Blowjob of Chaos - Guzka, Malin, Mapet
5. Jama Zła - KJ, Błażej, Necromanter
6. Tczew squad - Rilam, Sowa, Żwir
Szukają teamu:
1.Krystian
2.Żbik
3.Buła
4.Ptasznik
Ostatnio zmieniony 14 mar 2013, o 13:38 przez Młody, łącznie zmieniany 4 razy.
Pozdro
Młody
Snot Fanpage
Michał
Post autor: Michał »
Zapisz BWT skład.
AND THEY SHALL KNOW NO FEAR
KOLEJNY PUNKT DLA NAS !!! BWT KOCHANA !!!!
Cosmo pisze: 19 sie 2014, o 20:33 BTW gdzie spia Ci co nie chodza spac przed polnoca? Jakies zwierzeta z Nemezisu, BWT, Front..?
Błażej
Post autor: Błażej »
rozumiem że w HE speciale 0-4 i rary 0-2 ?
Młody
Post autor: Młody »
Rary tak, specjale nie :p
Pozdro
Młody
Snot Fanpage
Loki
Post autor: Loki »
ooooooo kurczę znów L4 będę musiał wziąć........
A MESSAGE TO THE EMPIRE:
JaSzczuras
Post autor: JaSzczuras »
Poczekajcie widzę, że szykuje się weekend z WFB na pomorzu, najpierw wjazd do was pewnie nic nie zwojujemy i nie przywieziemy ciasta i jeszcze na trzeźwo trza będzie wrócić do Koszalina na niedzielną singla u nas.
Dobra przekonaliście mnie
Zapiszczcie Zad Trolla, jeszcze nie wiem jak z kim ale będziemy.
Pająk
Post autor: Pająk »
Loki pisze:ooooooo kurczę znów L4 będę musiał wziąć........
Ty zachowaj L4 na Włocławek :wink:
krystian1wielki
Post autor: krystian1wielki »
Moje imperium szuka teamu :wink:
JaSzczuras
Pająk pisze:
On już wtedy ma pewnie urlop :)
Loki
Post autor: Loki »
JaSzczuras pisze:
Pająk pisze:
Dokładnie!! :D
Malin
Post autor: Malin »
Zapisz team:
Demoniczny Blowjob Chaosu :D
Guzka,
Mapet,
Malin
Michał
Przyczepie się do regulaminu, bo moge :)
1. O której zaczynamy ? masz Młody wpisane rozpoczęcie o 10:00 a w drugim miejscu bitwa nr 1 od 09:30
2. Ile bitew gramy ? masz wpisane 5 a potem w programie imprezy masz 4
Z całym szacunkiem Młody, ale co to za fuszera :)
Młody
Post autor: Młody »
Ok, naprawione.
Zapomniałem też dopisać że gramy na mniejsze stoły ;)
Pozdro
Młody
Snot Fanpage
Drwal
Post autor: Drwal »
Zapisz team:
Jama Zła squad
Ja
Błażej
Necromanter
przelas
Post autor: przelas »
szukam teamu gram lizakami
ptasznik
Post autor: ptasznik »
jesli ktos mnie przygarnie to chetnie zagram orkami.
Michał
Osoby bez drużyny zgadajcie się i mamy 6 skład.
Rilam
Post autor: Rilam »
Tczew się zjawi. Rilam Sowa Żwir !
Mapet
Post autor: Mapet »
trzeba było zrobić 1400p bo na 1600 przy tych cięciach nie mam co wstawić :wink:
