Magic Resistance
A spell that is targeting at least one enemy unit with one or more models with Magic Resistance suffers a -X modifier to its casting rolls (where X is given in brackets). This is an exception to the Casting and Dispelling Modifier rules. If there are different X values that could be used, use the highest.
KRASIOWA:Wizard Conclave
The Champion of a unit with Wizard Conclave gains +1 Health Point in addition to the normal Characteristics increases associated with being a Champion, and is a Wizard Adept. This Champion may select up to two spells from predetermined spells given in brackets after Wizard Conclave. This overrides the Spell Selection rules connected to being a Wizard Adept.
A tu karty do ściągnięcia i wydrukowania:
https://www.the-ninth-age.com/filebase/ ... load/1300/
