Nie jest zla ta magia ale sadze ze 7ed miala mocniejsza magie chociazby 5 zaklecie bylo extradebelial pisze:A: When a spell form a Lore of Vampires is successfully cast, the Wizard or another friendly model within 12" recovers 1 Wounds.
0. Signature Spell. Augment. 6+ to Cast, Range 6"/12+ to Cast, Range 12"/18+ to Cast, Range 18": target all friendly Undead units within range, Infantry recover D6 plus caster's Wizard level in Wounds (roll separately for each unit); other troop types recover 1+Wiz.lvl Wounds and Vampiric, Etheral and Large Targets regain 1 Wound. This spell CANNOT heal characters or their mounts.
1. Augment. Cast on 6+, Range 12". Friendly Undead unit in close combat may re-roll failed To Hit rolls until start of caster's next Magic phase. If target is not engaged in CC it may move up to 8" in the same way as in Remaining Moves. OR Cast on 12+ to target ALL fiendly Undead units within 12".
2. Augment. Cast on 8+, Range 12". Friendly Undead unit in may re-roll failed To Wound rolls in Close Combat until start of caster's next Magic phase. OR Cast on 16+ to target ALL friendly Undead units within 12".
3. Magic Missile. Cast on 9+, Range 24" OR Cast on 12+, Range 48. Cause 2D6 St4 hits.
4. Cast on 9+, Range 18". Create new unit of 2D6+3 Zombies anywhere within range, all models in unit must be completely within range, facing any direction, at least 1" from another unit, buildings and impassable terrain, with front rank of at least 5 models. OR Cast on 14+ to summon 2D6+3 Skeleton Warriors instead of Zombies.
5. Hex. Remains in Play. Cast on 12+, Range 18". Roll D6 for every model in target unit - on a roll of '6' that model suffers a Wound with no armour saves. At the end of next Magic phase roll again, this time models suffer a Wound on the roll of 5+, and so on, to a maximum of 2+.
6. Magical Vortex. Remains in Play. Cast on 15+. Small template. Nominate direction, roll artillery dice and multiply result by 3. Any unit beneath or passed over takes D6 S3 hits per rank, with no armour saves. On missfire center template on the caster and scatter it D6". In subsequent turns vortex travels D6" in random direction. OR Cast on 25+ to use large template and increase Strength to 4.
nowe Vampire Counts 8ed [update w pierwszym poście]
Moderator: misha
Re: nowe Vampire Counts 8ed [update w pierwszym poście]
- Infernal Puppet
Naprawdę niezła magia ( szczególnie boosty kombatowe ), ale brak jesj jakiegoś czaru z wielkim powerem, w rodzaju słonka, pitki czy dwellersów. Po prawdzie to chyba nawet lepiej.
Pewnie że lepiej, bo przynajmniej nie ma dylematu przez rzuceniem czaru i koncentrujesz się tylko na wskrzeszaniu i boostowaniu armiiInfernal Puppet pisze:Naprawdę niezła magia ( szczególnie boosty kombatowe ), ale brak jesj jakiegoś czaru z wielkim powerem, w rodzaju słonka, pitki czy dwellersów. Po prawdzie to chyba nawet lepiej.
nawet na moje to leczenie ran jesli chodzi o eteryki to powinno byc 1+lv maga bo tak naprawde to taki eteryk wielkiego kuku nie robi moze hexy ale dostana z magic misla i leza dlatego trzeba bedzie je troche chowac a co do bonusow w cc to jak ci wejdzie re roll na hity a potem na wo to bedzie rzadko bardzo ale jak wejdzie za to to masakre robi hehe
Jak je wylosujeszAzgaroth pisze:Pewnie że lepiej, bo przynajmniej nie ma dylematu przez rzuceniem czaru i koncentrujesz się tylko na wskrzeszaniu i boostowaniu armiiInfernal Puppet pisze:Naprawdę niezła magia ( szczególnie boosty kombatowe ), ale brak jesj jakiegoś czaru z wielkim powerem, w rodzaju słonka, pitki czy dwellersów. Po prawdzie to chyba nawet lepiej.Wątpię, żebym tracił kostki na 6 czar, raczej będę się skupiał na pierwszych trzech
te czary są względnie tanie, nie potrzeba wiele PD żeby je rzucić. Szkoda, że Silnik dostał tak słabą defensywę bo te +2 byłoby syte.
Necro i Vampir mogą wziąć domene "naszą' albo death za free? jeśli chcemy inne niż te dwie to musimy wziąć forbidden lore?
hmm a ja może bym pomyślał nad ifka 6 czaru ,a żeby tak sobie vortex latał i hitowal np po armiach strzeleckich skitranych gdzieś tam w rogu:) nie wiele to zadaje ale zawsze uprzykrza życie a spróbuj to potem zdispelowac na 25+, wiem ze ciężko będzie to tak rzucić ale zobaczyłbym z ciekawości jaki to będzie mieć efekt
@syraf
tylko, że wpierw musisz wylosować, a szkoda by poświęcić miscast na lvl 4 generale z powodu wiru
No to poczytałem:
- vampir - wszystkie 3 lory
- necrosy - tylko death i vampiric
- Corps cart ma specjalne działanie na zombie - jeśli jest celem augmentu zabiera zombiakom ASL i daje w zamian ASF! Jest chariotem niestety
(z drugiej strony - ma impacty)
- Coach ma fajne moce: 1- +1 impact; 2- Wraciak i Nightmary dostają +1S (czyli wraciak S=6 i koniki S=5); 3 - kiling blow na wszystkie ataki i falming; 4- MR(2); 5- Eteral; 6- Fly. Wraciak dostał również chill graspa
- zombie dragon ma statsy takie jak na stronie GW, Cloud of flies -1 to hit; breath S=2, -3 do Sv
- Abysal terror dostał 2 upgrady do wykupienia: Poisony i Armour piercing
moce wampiryczne które nie były jeszcze opisane (nie znalazłem w każdym razie):
- Fear incarnate (20) - reroll udanego feart test od vampira lub jego jednostki. Jeśli testujący jest w zasięgu swojego BSB - oba efekty się znoszą (jest 1 test bez rerolla)
- Beguile (15) - wszystkie modele w HtH z vampirem test Ld -3 albo reroll udanych hitów
- Red fury ma zapis, że jeśli zadany wound jest "killujący" (czyli wszedł KB) - to do ilości dodatkowych ataków jest liczona ilość woundów z zabitego modelu za tego wounda (czyli: 5 ataków wounduje z czego 2 to KB (a trup miał 2 woundy) = 3+2+2). Sycące...
- Skabscrach za 75pkt. Devastating charge, frenzy, flaming. Death Shriek. Jeśli do końca gry nie zabije nikogo w HtH - killed.
- Cursed book ma dodatkowy zapis, że jeśli nie masz tyle kości ile chce wciągnąć książka - wtedy nic się nie dzieje i tracisz kości
Tylko Covern Throne ma opcję do bycia mountem dla vampira (nie dla necrosa)
Engine jest tylko rarem.
Dire Wolfy mają +1 do Siły w szarży i mają vanguard
Szkiele - opcja na MS do 25pkt. dla 1 unitu. Spear's za free (nie zamienia się HW na speary - tylko jak się chce to mają a jak nie - to nie mają)
Gravy - opcja na MS do 50pkt. 2hw za +1pkt. (za tarcze). Po 11 pkt.
Black Knights - po 21pkt. Sztandar do 50pkt. +3 barding, +2 lance. HA i Shield w standardzie.
Crypt Horrory - po 38pkt.
Vargheisty - 46pkt.
Vargulf - 175
Bloodzi - po 50. Opcja: alby zwykły(magiczny) banner do 50pkt. albo opcja na Flag of Blood Keep za +75pkt.
Wraithy (oddział) - po 50pkt. Opcja +25 na Banshee. Mają Chill Graspy.
Coach - 195pkt. Sv 3+, Ward 4+
Vargheisty - 46pkt.
Vargulf - 175
Ostatnio zmieniony 14 sty 2012, o 00:03 przez Bastor, łącznie zmieniany 12 razy.
Mógłbyś odpowiedzieć na moje pytanie 2 posty wyżej.
Ostatnio zmieniony 13 sty 2012, o 22:47 przez Marks, łącznie zmieniany 1 raz.
Dokladnie tak lepiej juz curse of years dawacMarkuene pisze:@syraf
2 poziomowy czarodziej z shadow bedzie mysle obowiazkowy
jakich?Bastor pisze:No to poczytałem - i nie ukrywam, jest kilka ZONKÓW:
No to zombie naprawdę będą dawać radęBastor pisze:No to poczytałem:
- vampir - wszystkie 2 lory
- Corps cart ma specjalne działanie na zombie - jeśli jest celem augmentu zabiera zombiakom ASL i daje w zamian ASF! Jest chariotem niestety(z drugiej strony - ma impacty)
Czyli corps daje tylko zombi asf?Azgaroth pisze:No to zombie naprawdę będą dawać radęBastor pisze:No to poczytałem:
- Abysal terror dostał 2 upgrady do wykupienia: Poisony i Armour piercingCzas odkładać kasę na nowe pudełka
Szkoda że zostawili ten plewny breath attack ale nie można mieć wszystkiego
rozumiem, że hero necro i vamp moga byc upgradowani tylko do lvl 2 magicznego?
