Nowy WoCh
Moderator: JarekK
Re: Nowy WoCh
zależy które bitsy;p niektóre szczypce są za duże na przykład... ale coś idzie dobrać:)
edit.
Powiem Wam, że większych spamerów niż na forum WOC ze świecą szukać... nie było jeszcze premiery a już pobiliśmy liczbą postów podobne tematy w imperium czy vc;p
edit.
Blue Fire of Tzeentch (sig spell) cast on 5+, d6 str d6 hits with warpflame rule.
1: treason of tzeentch hex, cast 7+, unit must use lowest LD in the unit and cannot use IP or HYG
2: pink fire of tzeentch, DD, 8+, teardrop that moves towards target, models touched take str=d6 hits
3: bolt of change, magic missile, 8+, str=d6+4 hit with multiple wounds d3 and warpflame. penetrates ranks like a bolt thrower, no armour saves allowed.
4: glean magic, 8+ direct damage, targets a wizard within xx" caster and the target roll off and add wizard levels to score. if you win then the enemy suffers a str 3 hit with warpflame rule, loses a wizard level and forgets a random spell. you then gain that spell and its lore attribute when you cast it. if you lose the roll nothing happens.
5: tzeentches firestorm, 13+ direct damage. small template that scatters, everything hit suffers str=d6 hit with warpflame. can make it bigger, scatters more.
6: infernal gateway, 16+. as the old one but if you roll 11 or 12 for str it does 3d6 str 10 hits instead of 2d6.
warpflame = any unit that suffers a wound from a spell with this rule takes a T test. if it fails it takes d3 wounds, if it passes it gains regen 6+ for the rest of the game. if they already have regen it gains +1 to its regen.
The tzeentch lore attribute is you get a power dice for each 6 rolled when casting spells. only the wiz that got em can use em.
Zajebiście niskie castingi.... wszystko z 2-3 kostek pomijając bramke.... zasada warpflame zajebista.... glean magic? też super...
edit. no może to warflame nie takie zajebiste w przypadku czaru nr 5 przede wszystkim
edit2
Psiaki mogą brać vanguarda
edit2
Mocno osłabiony pociskBlue Fire of Tzeentch (sig spell) cast on 5+, d6 str d6 hits with warpflame rule.
Ciekawy czar, udupia mocno niektóre jednostki1: treason of tzeentch hex, cast 7+, unit must use lowest LD in the unit and cannot use IP or HYG
Taka salka. Cholernie losowe, ale potrafi przywalić.2: pink fire of tzeentch, DD, 8+, teardrop that moves towards target, models touched take str=d6 hits
Wygląda tak sobie. Gdyby leciało jak cannonball, byłoby super, tak jest przeciętnie.3: bolt of change, magic missile, 8+, str=d6+4 hit with multiple wounds d3 and warpflame. penetrates ranks like a bolt thrower, no armour saves allowed.
Ciekawe, aczkolwiek bardzo loswe. Może być dobre do eliminowania małych magów.4: glean magic, 8+ direct damage, targets a wizard within xx" caster and the target roll off and add wizard levels to score. if you win then the enemy suffers a str 3 hit with warpflame rule, loses a wizard level and forgets a random spell. you then gain that spell and its lore attribute when you cast it. if you lose the roll nothing happens.
Taki słabszy skaveński scorch, który scatteruje.5: tzeentches firestorm, 13+ direct damage. small template that scatters, everything hit suffers str=d6 hit with warpflame. can make it bigger, scatters more.
Mega osłabiony gateway.6: infernal gateway, 16+. as the old one but if you roll 11 or 12 for str it does 3d6 str 10 hits instead of 2d6.
Bilans: parę nowych czarów, które mogą się sprawdzić i poważne osłabienie już istnięjących. Do tego ten żałosny lore atribute, który mógłby brzmieć równie dobrze brzmieć: abomination, hydra, crypt horrors and all other op units with regeneration are immune to whole lore, except of infernal gateway
Strzelam, że ogniste jest to, co ma w nazwie słowo fireA coś jest Ogniste w Magii Tzeentcha?
![Wink :wink:](./images/smilies/icon_wink.gif)
Życie
Ale spoko, trzeba poczekać na pełny rulling. Poza tym, wątpię żeby ludzie grali na tęczy, przy tak mocnym lorze nurglowym.
No byłoby dziwne żeby czary z ognistymi atakami zdejmującymi regenkę dawały/polepszały regenkę...
nurgle rządzi. reszcie moja druga zielona armia ma sens.
- swieta_barbara
- habydysz
DP nurgla to bedzie moc :]
Z tego co pamietam atrybut nurgla byl taki, ze za kazda zadana rane na 6 dostajesz rane i tafa +1 do konca gry. Spoko to sie z tym vortexem laczy.
- Murmandamus
wygląd na to że nadszedł w ogóle cykl Nurgla. Wiecie moc papy kupy czasem maleje , czasem wzrasta do poziomy przewyższających pozostałych bogów chaosu. Wygląda na to że to ten czas.
- swieta_barbara
- habydysz
Murmandamus pisze:wygląd na to że nadszedł w ogóle cykl Nurgla. Wiecie moc papy kupy czasem maleje , czasem wzrasta do poziomy przewyższających pozostałych bogów chaosu. Wygląda na to że to ten czas.
![Obrazek](https://lh6.googleusercontent.com/-bRK32pZylQc/UP25ufJvtRI/AAAAAAAABRU/LKszaX31pmM/s640/wfbkl4.jpg)
Tak mi sie przypomnialo
![Very Happy :D](./images/smilies/icon_biggrin.gif)
Ktoś coś wie na temat lora lalusiów??
Tzeentch ostatnio chyba choruje. Moim zdaniem może tragedii nie ma, ale dupy nie urywa w porównaniu z Nurgle.
Glean Magic fajny, bo kradnie się atrybut dodatkowo. Spokojnie pociskałbym nawet na Lvl4 chłopaków.
Bolt spoko do bicia w monstery i MC/C od boku (mag i tak pewnie chula na dysku, więc to nie tak trudne)
Dużo zaletą jest sporo pocisków do czyszczenia śmietnika, i to co zabiera IP i HYG w sam raz na hordy slavesopodobne.
Ale +d3T i Regenka to aż się prosi o SKULLCRUCHER UNSTOPPABLE MACHINE![Very Happy :D](./images/smilies/icon_biggrin.gif)
@Kacper
"Daemon Princes have their traditional hatreds, and are bananas, I made a 1+ 5++, S7 on the charge s4 flaming breath weapon, charmed shield, hits on 2+, 2+ ward against flaming, roll a d6 for each unsaved would on a 6 regain a wound, flying, not large target monster for under 400 points."
Daemon Prince -235
Mark of Khorne - 10 (+1 s on the turn you charge)
Sword of Striking
Charmed Shield
Dragonbane gem
Scaled skin
Flaming breath (s4 flaming breath weapon)
Soul feeder (Roll a d6 for each unsaved wound you do, on 6 you regain a wound)
Chaos Armour - 20
Daemonic Flight - 40
390 points for 5 s7 attacks on the charge at Ws9 with +1 to hit at I9
Flaming breath weapon
1+ armour!!
Blaster Banner jest MoT only
@Kacper
Daemon Prince -235
Sword of Striking
Charmed Shield
Dragonbane gem
Scaled skin
Chaos Armour - 20
1+ armour!!
Ostatnio zmieniony 31 sty 2013, o 11:16 przez trikk, łącznie zmieniany 3 razy.
Release the Przemcio!
Kurde jeszcze tylko przeżyć dzisiejszy dzień i... już w sobotę będzie można zagrać na nowym AB
Macie jakieś ciekawe koncepcje na DP nurglowego?
![Twisted Evil :twisted:](./images/smilies/icon_twisted.gif)
