1. str. 39 Skaven Mounts
2. str. 99 opcje; Mount (one choice only)
nie wygląda mi to na pieszy model w huk.
Przecież Seer na dzwonie tez w zasadzie jest pieszy...
Moderator: Hoax
po kilku maskach pewnie zmienisz zdanieMomoTheKiller pisze: dla mnie armia musi mieć klimat a nie rozpiskową moc i "szablonowe rozwiązania" he he
SPECIAL RULES
Ponderous War Machine: If the crew is forced to flee
for any reason the Warp Lightning Cannon is destroyed.
The Warp Lightning Cannon is a war machine and both
it and the crew are considered to be a single combined
model. The characteristics have been detailed for both
crew and machine as they are used at different times.
When being shot at or targeted with spells use the
higher Toughness, while in close combat use the lower
Toughness value. There is only a single combined
Wounds profile that both Warp Lightning Cannon
and crew draw from. If this combined Wound profile
reaches zero the entire model is removed as a casualty.
