Opisy członków Ar dla leniwych:
1 Kent Max Hansen, Denmark
2 Played for over 20 years and been to all ETC on the danish team. I have no favorite army, as I have and play more or less all armies.
3 Overall I liked this years comp, as it was really hard to pick the 8 armies for the team. Which shows that the balance between the armies where good. I would like to do something about the deathstars: by not allowing crown of command for all or if you choose it, it will cost you some other good choices, only allow 2 characters per unit to get “look out sir” rolls. I would like to give people more choices. So for example if and ogre army don't include a slaguthermaster, it can get 2 ironblasters, if an dark elf army doesn't include any lords, it can have 2 hydras, if you army don’t include a lord level mage it can include 1 more war machine. Something along those lines.
4 Seemed to work fine.
1. Hampus Berg, Sweden
2. Played warhammer for 6 years, attended the last 5 ETC's, two times as a Captain.
Will attend the ETC 2013 as a captain.
3. I only want to calibrate the restrictions, want to make it even harder to pick the 8 armies for your team.
4. Think the casting dice limit works fine, expecially since a lot of team took Death and shadow anyways.
1.) Matt Yeo, Wales
2.) Tournament warhammer for the last 4 years, have attended last 3 ETCs, last 2 as captain. Will be captain for 2013 as well. Started with playing Orcs & Goblins, now play Ogres as well.
3.) Last year's comp did a pretty good job, but I would like to move more towards a 'Toys for everyone' approach. This being less of restrictions on top armies (or any armies) and more of boosts to lower tier armies to bring them to the same level. This worked well with some armies this year, notably Tomb Kings. I'd also like to remove some of the blanket restrictions and instead apply them on an army by army basis, such as the repeat core unit choice restriction.
4.) 5 dice is a good compromise, I would like to remove all 4 dice caps.
1. Friedemann "dirty player" Walzer, Germany
2. I've played WHFB since the 5th Edition, have organized several tournaments, have coached the german team at two ETCs, will probably be part of the next one and have been a tournament judge for several dozens of tournaments including one ETC an I was part of last year's AR.com
I've played all armies at tournaments but mostly I play DoC, VC and DE.
3. I liked last ETC's rules pack very much and would only want to do some minor corrections, adjust to new army books, reduce general restrictions, that have proven to be unnecessary and maybe readjust the rules for a few combos that have proven to be especially nasty.
4. I like it the way it is.
