Skaven 7ed AB - czyli co wyszło z kanałów...
Moderator: Hoax
ta bestyjka jest nie skaveńska a nurglowa...
więcej info http://www.games-workshop.com/gws/conte ... d=3800006a
Incoming: Skaven
— Article by Adam Troke
The Skaven are warped and mutated creatures, as much rat as man. They are hideous, hunched monsters, a grotesque parody of humanity - the stuff of nightmares given form. From their underground empire they plot the downfall of the other races, preparing for a day when they can rise up and usurp the civilised world.
As a race the Skaven fight as an innumerable horde, a chittering, squealing army of cruel and malicious warriors who, though individually weak, are incredibly dangerous in large numbers. Armed with notched blades and pilfered spears, the Skaven Clanrats are supported by towering war machines of incredible power - from the arcane technologies of the Doomwheel and Warp Lightning Cannon to the infernal magic of the Screaming Bell. With these ramshackle weapons of war in their midst, the Skaven are a truly terrifying and deadly foe.
This November, the Skaven are being set loose, with a 112-page army book packed full of detailed background, lavish artwork and all the rules you'll need to unleash the Skaven on the battlefield. Of course, there's also a dazzling array of fantastic new miniatures on their way too, including stunning multi-part plastic kits and finely detailed metal miniatures.
Keep an eye out for September's issue of White Dwarf for even more tantalising Skaven news!
Warhammer Armies: Skaven - 112 pages of pure, rat-shaped awesomeness!
This plastic Clanrat is just one of the fantastic new Skaven miniatures coming this November.
Incoming: Skaven
k0zi pisze:ta bestyjka jest nie skaveńska a nurglowa...
Incoming: Skaven
Bedzie kolko
112 stron
Podręcznik do Imperium do 7 ed. ma dla przykładu 97 stron, a stary podręcznik do skavenów- 84, więc może byś Sztajgerland napisał o co Ci chodzi?
Ostatnio zmieniony 24 sie 2009, o 13:39 przez Myth, łącznie zmieniany 1 raz.
Nie będę się nudził w drodze do szkoły i z powrotem
. Cieszy mnie ta rozlazłość.
skaveny 5ed 96 stron +okładkaMyth pisze:Podręcznik do Imperium do 7 ed. ma dla przykładu 97 stron, a stary podręcznik do skavenów- 84, więc może byś Sztajgerland napisał o co Ci chodzi?
skaveny 6ed 80 stron +okładka
Myth masz jakąś wersję rozszerzoną?
skaveny 7ed 112 sreon + okładka!
szykuje się dużo czytania i oglądnia! mniam... mnie taka wieść bardzo cieszy raczej niż smuci że będzie taki opasły book
btw pewnie ze 4 strony to same zasady kółka będą zajmowały
oj tak, ludzie na początku 6ed skavów ledwo łapali jak działa wlc, potem tłumaczyło się zasady ratlingów i dzwona... a potem mają pretensje że to niby na czas gramy:P
I o to chodzi bo na zawodach kończymy w 3 turze kiedy właśnie przeciwnik miał dojść do nas a my mu połowę armii wycięliśmy;)
p.s dłużej trwa przenoszenie i rozstawienie
Szczególnie jak się bawiło przy sklejaniu i nie da się ich ustawić
ee ja nie mam żadnych problemów, co się da jest na poczwórnych podstawkach, oprócz tylnego i pierwszego ranku i boku jednego, wszystko ponumerowane i sklejone że się mieści po ułożeniu... wypakowanie zajmuje mi 10-15minut przy ok 250 modelach, potem wszystko już ułożone i tylko przenieść trzeba na większej podstawie typu pudełko po pizzy... naprawdę, nie wiem gdzie tu problem widzicie, starczy sposób...
swego czasu Swingu miał jeszcze wszystko na magnesach w metalowym pudełku więc regonu wyjmował na stół ułożone od razu...
jak sie nie chce poświęcic troche czasu na przygotowanie armii pod kątem transportu i układania to się potem będziecie męczyć za każdym razem wyciągając armię:P
dobrze vocal prawi ; ). magnesy piekna sprawa ; )
- Arbiter Elegancji
człowiek kilka dni nie zagląda do tego tematu bo myśli że tu dalej lista życzeń, a zamiast tego wreszcie jakieś konkrety
. Okladka wymiata, a in nowe modele clanratów bardzo mi się podobają, już się doczekać nie moge AL i kolejnych świeżutkich modeli
. A w szczególności nowych stormverminów
te nowe modele cr średnie, coś wyliniałe te szczurki, malutko sierści, ale fakt, pod względem estetycznym i czysto kolekcjonerskim biją na głowe stare modele clanów, nie ma 2-ch zdań.
Mimo to i tak raczej nie będe mógł sobie pozwolić na kupno jakichkolwiek nowych figsów, więc raczej nastawiam się na fajne zmiany w zasadach
Sorry, że tak palne, ale raczej większość skavów jest wyliniała. Jak wyobrażasz sobie życie w milionowych społecznościach , w wilgoci, brudzie i lekarzami-psycholami, którzy i tak są dostępni tylko dla hersztów? Tam 100% choruje.
zadzwońcie pod infolinie jak chcecie pomóc w leczeniu chorym szczurom;p
o do modeli - wg wyglądają bardzo indywidualnie a jeżeli tak będzie z każdym z osobna to wole stare modele które imitują bezosobową masę;p ot taka moja opinia
pomijając kwestie realizmu w dziedzinie życia skavenów, dużo bardziej podobają mi się modele które zarastają sierściąRogatyszczur pisze:Sorry, że tak palne, ale raczej większość skavów jest wyliniała. Jak wyobrażasz sobie życie w milionowych społecznościach , w wilgoci, brudzie i lekarzami-psycholami, którzy i tak są dostępni tylko dla hersztów? Tam 100% choruje.
