nowe modele i unity?
Empire
Moderator: #helion#
Gerald
Re: nowe modele i unity?
Post autor: Gerald »
pewnie nawet go zjadl i dlatego jest taki opasly :)
''Three things make The Empire great – faith, steel and gunpowder!"
Legionowski Klub Miłośników Fantastyki
http://www.facebook.com/pages/Legionows ... 0549447769
Reyki
Post autor: Reyki »
HE mają smoka więc nie marudzić.
KFC-Karl Franz Chicken
scoutmaster
Post autor: scoutmaster »
kolejne nowości z WarSeera trochę o zasadach:
Re: The Empire rumours.
What I can get from the WD:
units led by Empire Generals and Captains roll 3D6 for Break Test, discard highest;
Witch Hunters have Sniper and Killing Blow;
Imperial Griffons are S6, 5W - I don't have my old Army Book here, but it seems to me these are different? They can be two-headed as a special option (with built-in game effect);
Karl Franz grants his Ld to models within 18"; 24" if he is upon Deathclaw or the Imperial Dragon;
Deathclaw has +1 A and Ld respect an Imperial Griffon, the usual faithful rule and makes enemy units roll an additional D6, discard lowest when testing Fear/Terror caused by it.
The General on the Imperial Griffon model has the option of two heads (helmetd or not) and lance or sword (different from the Reikland Runefang).
The two magic altars can be fielded without Wizard on top, thus counting as a rare choice (I guess that was already known).
Demi-Gryphs Knights with cavalry halberds are shown with the shield too (I guess they'll use it only against shooting).
Murmandamus
Post autor: Murmandamus »
Czyli Cold Blood taki na Geniu i bedzie nieźle. I Yebac arcylektora.
https://kow.fora.pl/
Blaesus
Post autor: Blaesus »
Herosi na piechotę - ok. Świetny kapłan z dwoma brońmi (tylko po co? :) Mimo to przy drobnej konwersji może być z tarczą)
Maszynki - może trochę tandetne? Na pewno ładny plastik, szczegóły i pudło z bitsami. Czy to na prawdę będzie oddzielnie sprzedawane z War Altarem?! To niemal to samo...
Demigryfy - mega ! Sądząc po ForgeWorldowym modelu, miałem obawy. Na szcęście wzostały rozwiane.
Gryf - Genialny, wypięta pierś, dumny, wielki. (aczkowliek niezbyt skuteczny :) ). Imperialny! Karl w końcu nie wygląda jak papuga. Jest super!
Okładka - byłoby idealnie, gdyby nie ten menel pod hełmem. Ja rozumiem, że żołnierze imperialni mogą dużo pić, bo kto by to wszystko na trzeźwo wytrzymał... ale zżulić kapitana? (BTW. Czyżby w końcu kapitanowie mogli nośić broń repeater?
Teraz pozostają obawy względem zasad. A mianowicie magicznych przedmiotów. Cóż stanie się z Armour of Meteoric Iron?
Patrząc na konie przy nowych zabawkach (np. przy mikrofalówce) i wyjście demigryfów, sądzę, że nie ma co spodziewać się nowych rycerzy w ciągu dłuuugiego czasu...
tilt112
Post autor: tilt112 »
Gerald pisze:tylko czekac jak na turniejach beda badz sie gwiezdnego imperium z lewej seria z dzial,po prawej mozdzieze wala a za nimi rakietnica strzela jak katiusza tuz obok katarynki kaskadowo wala we wszystko. Po czym przeciwnik patrzy na nasze zaplecze i pyta sie co to jest to male na wuzku a ty mu na to- muj panie to jest zabawka z kategori win the game :)
Nie wiem co to znaczy "badź"
Ale wiem ze trzy literowe slowa typu: bać, wóz, mój idzie sie nauczyc...
Przemcio
Post autor: Przemcio »
hehe to może generał stanie się grywalny :?: :mrgreen: :?:
Bizim
Post autor: Bizim »
Tak samo jak kapitanowie w klockach...
Swoją drogą to będzie oznaczać, że genio na gryfie też kula 3d6 na ld. Dać mu jeszcze koronę i będzie nie do złamania. :twisted:
kowaljl
Post autor: kowaljl »
Gryf trochę dopakowany. S 6 :) W 5 :-) nieźle, T minimum 5 i A też minimum 4. Nie wygląda to złe tylko nadal niema najważniejszej rzeczy czy będzie miał armor jakiś. Ale TS z siła 6 :-) :-) :-) a jeśli chodzi o demigryfy to ważniejsza tarcza w walce niż ten +1 do siły:)
Bizim
Post autor: Bizim »
Imo od AS (chociaż ja tam liczę na 4+ od tego zderzaka :P) na gryfie ważniejszy jest jego koszt punktowy...
Havelock
Post autor: Havelock »
Coś mi nie pasowało w tych demigryfach i już wiem co - o ile barding nawiązuje do starych artworków warhammerowych i generalnie do starego świata jakim go znaliśmy kilka edycji temu, to już tarcze są bez sensu, jakby z WoWa. Mogły by być bardziej heraldyczne. No i nie wspomnę już o tej idiotycznej trąbce...
#helion#
Post autor: #helion# »
Havelock pisze:Coś mi nie pasowało w tych demigryfach i już wiem co - o ile barding nawiązuje do starych artworków warhammerowych i generalnie do starego świata jakim go znaliśmy kilka edycji temu, to już tarcze są bez sensu, jakby z WoWa. Mogły by być bardziej heraldyczne. No i nie wspomnę już o tej idiotycznej trąbce...
chryste panie...to już jest stricte czepialstwo...tarcze wymienisz sobie ze zwykłych KO, które mimo upływu czasu naprawdę są świetne...trąbkę też można zrobić, albo ze starego KO, albo z jakiegokolwiek innego regonu... #-o #-o #-o
"(...)Imperium raz zaatakowane, zawsze kontratakuje(...)"
Kajus C+, Misja Kleopatra
GALERIA
Brushlicker
Post autor: Brushlicker »
@kowalij
Uracz mnie prosze fotkami tego Twojego gryfa, bo moje odczucia do tego sa bardzo mieszane....w sensie ze do oficjalnego modelu :mrgreen:
Miales trudnosci z usunieciem elfa?
I gdzie mozna kupic te wielkie podstawki?
Martin von Carstein
Wybacz, że nie odpowiedziałem. Nie zauważyłem przez tą falangę. ;)
Martin jak mozna miec unit wielofunkcyjny ?? Co uzywasz tego czasem jako rycerstwo, czasem jako rajtarow?:)
Tak chciałem robić, raz używać jako rajtarów, drugi raz jako rycerzy (gdybym np. potrzebował kolejnego oddziału).
Zresztą sam zobacz:
Są zbroje 3/4? Optycznie zbroja płytowa.
Pudło to 12 takich nowożytnych rycerzy. Czyli dwa oddziały takich rajtarów.
Część dostanie pistolety, część młoty. Jest też kopia i trąbka. Odział Rajtarów to cienka linia, będzie tam po równo mniej-więcej panów piorących i strzelających.
Jak będę chciał wystawić rycerstwo - zazwyczaj w dwóch, trzech szeregach. W pierwszy pójdą młociarze, pałaszowi, trębacz i kopia ze sztandarem. Zakryją pistoleciarzy (usuwanych w pierwszej kolejności - jako trupy - z racji miejsca w tylnym szeregu)
WYSWIG powinien być.
Ps. W dalekiej przyszłości zamierzam zresztą dokupić jeszcze Ironside, "Żelaznobokich" Cromwella. Ale to wyłącznie na Rajtarów. ;)
Ps. Hełm sekretny był używany oczywiście też w XVII wieku. Zakładany pod kapelusze. ;)
Ostatnio zmieniony 28 mar 2012, o 16:03 przez Martin von Carstein, łącznie zmieniany 2 razy.
Marks
Post autor: Marks »
Zdaje mi się, że ten generał na kurze może podzielić los wszystkich tego typu wynalazków - zostanie odstraszony przez wrogą artylerię.
A to ciekawe:Ah! One more thing: the Planetarium model (ten celestial bodies) is fully rotating, even when assembled. And it has several angles, too.
Reyki
Post autor: Reyki »
Panowie. Przyjżyjcie się dokładnie podstawkom.
Wozy dla magów oraz altar- rydwanowe.
Kurokotynieloty- 50/50
Gryfy- rydwanowe (popatrzcie na wielkość jeźdźca i porównajcie skalę razem z wozami. Dodatkowo ta megaśna podstawka jest prawie kwadratem a tu wyraźnie widać że to prostokąt.
Gryfy nie będa na tych megaśnych podstawkach jak arachnarok, terrorgheist czy helka.
Na megaśnej będzie pewnie coś innego.
Brushlicker
robusz mi nadzieje
Cannon of nuln =D
Bizim
Post autor: Bizim »
Markuene pisze:Zdaje mi się, że ten generał na kurze może podzielić los wszystkich tego typu wynalazków - zostanie odstraszony przez wrogą artylerię.
Niech tylko będzie w stanie szerzyć pożogę i zniszczenie jak dojdzie to się wystawi nawet 4 cannony co by wroga artyleria nie miała łatwego życia. :twisted:
Przemcio
Nauczyć się angielskiego... to nie boli jak wół masz napisane, że unit, któremu przewodzi genek lub kapitan testuje na 3D6... samotny ciul na gryfia niczemu nie przewodzi :mrgreen: :twisted:
Bizim
Post autor: Bizim »
Jak nie?
Samotny generał dowodzi unitem o nazwie empire general. :P
