A te przedmioty przypominają mi artefakty z herosów jedynki. Żenada totalna.
Mroczny klimat battla wprost z bajek braci Grimm.
Sf(x)= x^2+cx
chciałeś to masz
Sf(x)= x^2+cx
chciałeś to masz
Lore of light
The special bonus is that against undead and daemonic units all spells cause an additional D6 hits.
Exorcism: Direct Damage. Deals 2D6 S4 hits, against which all successful Ward saves must be re-rolled. For each wizard other than the caster using the lore of light within 12" the strength is increased by 1.
Curse of Anraheir is back in lore of beasts, didn't read what it did, I jsut recognise its name from Shadow of the horned rat.
Lore of beasts had a spell that gave +1 Strength and Toughness I think it was, thats the number 1 spell anyway.
There was another that was similar that gave plus 3 strength and plus 3 Attacks as well.
The bolt thrower spell is still in there too, its now called the Amber spear.
The dragon spell has 2 levels, first level is casting value 16, that turned your wizard into 3 possible things, think you chose which, a Spiked Dragon (Ithink it was called, something along those linwes anyway), which had stats along the lines of a High elf sun dragon, Hydra was anotehr, and I can't remember the 3rd thiing.
2nd level of this spell was 20+ to cast, turned you into a greater fire dragon or teh Mountain chimer as mentioned in the sticky. Its also a remains in play spell , which sucks.
The frog scroll is 50pts, and is used as per a scroll, but the spell still goes off.
The wizard must roll equal to or under their wizard level to keep the backlash in check, or they are turned into an amphibian, then in each of their subisquent turns they get to roll a 4+ to come back into play.
however the enchanted shield has now gone down to just 5pts! (Along with a shield which allows you to disrgard the first hit caused on the character on a 2+)
There are some AWESOME items, but there are some which appear to mostly be for comedy (or nostalgic) value.
50pt Heavy armour with a 4+ ward save?
45 pts 4+ ward save
35pts Heavy armour with 5+ ward save?
YES PLEASE
Oh and there is a banner of +1 movement!!
The other trickster's shard is Models in base contact (friend of Foe) reroll successful ward saves.
Chyba pod koniec czerwca, napewno przed RB.sebol pisze:Kiedy mają być te pdfy zmieniające booki na 8 ed?
