1.Turniej organizowany jest przez klub SNOT i odbędzie się w dniu 26 kwietnia 2009 (Niedziela). W Gdańsku-Morenie w domu Kultury na Nałkowskiej 3.
2.Na turnieju będziemy zbierać "dobrowolną" darowiznę na klub w wysokości 10 zł ;]
3.Kompozycja Armii
a)Gramy na 2250 pkt.
b)Turniej gramy na zasadach EURO, oto zasady wystawiania armii:
4.Gramy 3 bitwy Pitched Battle na stołach 72x48 cali.Restrictions on the composition of the army
Army restriction
No army can be doubled, no SOC allowed.
Army size: 2000/2250/2500 points (depending on category, see below) with semi-secret (assassins, fanatics, magic items, demonic gifts etc. are kept secret) rosters.
General composition rules
- Armies are 2000/2250/2500 points.
- No characters that are: special, named or Albion
- No DoW or RoR in non-DoW armies .
- Rare choices may not be repeated, except for HE, where they can be repeated once for each choice.
- Max. 2 of the same Special choice.
- Max. 3 of the same Core choice, except ranked infantry without missile weapons and beast herds.
- Max. 3 units of chariots (incl. characters).
- Max. 9 PD/10DD in an army *
- Max. 3 units of flyers (incl. characters)
- Max. 45 models with missile weapons with a range of 20”+ (not incl. war machines, characters and chariots).
- Max. 5 warmachines.
*Magic description
You can use a maximum of 9 power dice in each magic phase. Each bound spell you use count as 1 power dice, all following bound spells used in the same turn counts as 2 power dice.
Every ability that grants the bearer complete knowledge of a single lore counts as one power dice in each magic phase.
All dice you would not normally generate, such as Focused Rumination Slann discipline free dice, Skaven warpstones, night goblin mushrooms, power of darkness etc., also count in the total number of dice you can use in a magic phase.
Tomb Kings count each dice they use for a spell as 1 power dice and casket of souls counts as 2 dice total. They can not chose not to use all the dice when casting an incantation, for example a Liche Priest can’t choose only to use 1 dice on a spell. You can how ever choose not to cast a spell with a model. The 2 basic power dice all armies get only counts if they are used to dispel RIP spells with.
Max 10 dispel dice per army. First dispel scroll (and similar working items) you have in your army counts as 1 dispel dice, in EACH magic phase. The second and all other scrolls, counts as 2 dispel dice in each magic phase. So if you have 3 scrolls you can use a maximum of 5 dispel dice each magic phase. Dice from magic resistance does count in this maximum. Being allowed to reroll your dispel dices every turn counts as 2 dispel dice.
Dice removed by the Chaos Dwarf Chalice of Darkness count as dice used. You remove 3 power dice, you can use only 6 more in your magic phase.
Race specific:
DAEMONS OF CHAOS - Bloodthirster with Immortal Fury, Keeper of Secrets with Siren Song and Lord of Change with Will of Tzeentch count as an additional hero choice; Herald BSB may take either daemonic gifts or a daemonic icon, not both; Daemonic Gifts may not be duplicated (except for Spellbreakers); Horrors are limited to 0-2.
DARK ELVES - Ring of Hotek counts as 3 dispel dice each phase; every assassin after the first counts as a hero choice; Shades limited in unit size to max. 10 models; the Pendant of Khaleth counts as a hero choice.
EMPIRE - Steam Tank counts as two Rare choices
ORCS & GOBLINS - Max 6 goblin fanatics.
SKAVEN - Max 3 ratling guns; Jezzails count as war machines (ratio 4:1, always rounding up)
VAMPIRE COUNTS - The Drakenhoff banner counts as an additional hero choice; the Helm of Commandment counts as an additional hero choice if taken on a Vampire Lord.
WOOD ELVES - Treeman Ancient counts as Treeman.
LIZARDMEN - Characters mounted on Stegadons also use the relevant special or rare slot (Engine of the Gods count as Ancient Stegadon); Terradons limited in unit size to max. 5 models; discipline Becalming Cogitation count as 1 dispel dice.
The ladder system:
All armies are divided into three categories; A, B and C. Category A armies are limited to 2000pts, B to 2250pts and C to 2500pts.
When calculating victory points at the end of the game, once you have the result, then add 10% to any category A army's losses (e.g. 1234 would become 1234+123,4=1357) rounding off as normal. Any category C army would conversely have its losses reduced by 10% (e.g. 567 would become 567-56,7=510).
Category A (2000pts)
Demons of Chaos
Vampires
Category B (2250pts)
Bretonnia
Chaos Dwarfs
Dark Elves
Dwarfs
Empire
High Elves
Warriors of Chaos
Lizardmen
Skaven
Tomb Kings
Wood Elves
Category C (2500pts)
Ogre Kingdoms
Orcs & Goblins
Dogs of War
Beasts of Chaos
5.Turniej zaczyna się o 10.00 (Zapisy od 9.30).
Osoby które stawią się o godzinie 9.15 w na miejscu w celu pomocy przy wystawianiu stołów otrzymają 5zł zniżkę na wejściówkę.
6. Przedziały punktowe
0-200 10-10
201-400 11-9
401-600 12-8
601-800 13-7
801-1000 14-6
1001-1200 15-5
1201-1400 16-4
1401-1600 17-3
1601-1800 18-2
1801-2000 19-1
2001+ 20-0
Bonusy za Generała, Ćwiartki, Sztandary po 100 VP
7.Na turnieju odbędzie się prosta 8 pkt ocena malowania:
0-3 pkt, % pomalowania armii (0; 1-50; 51-99, 100)
0-2 pkt, % WYSiWYGu na armii (0; 1-99; 100)
0-1 pkt, konwersje/WOW (uznaniowo)
0-1 pkt, posiadanie kostek, wzornikow, miarki oraz podanie w czasie oceny swojego ligowego nr ID (do wgladu tutaj http://ligawfb.prv.pl/)
0-1pkt, wydrukowana czytelna rozpiska
8. Każda para po ostatniej bitwie jest zobowiązana do:
odłożenia terenów do kartonu
odniesienia swojego blatu,
odniesienia krzesełek.
Za spełnienie wyżej wymienionych kryteriów zostanie przyznane każdej osobie 12 pkt do klasyfikacji ogólnej. Za niespełnienie 12 pkt karnych.
9. Dopuszczamy proxy ale proszę zbytnio nie przesadzać z proxowaniem .
10. Bitwy będą trwały po 2,5 h, przerwy między bitwami po 15 minut , czyli jeżeli pójdzie wg. planu to o 18.30 skończymy.
11. Turniej będzie zaliczony do ogólnopolskiej ligi.
12.Sędziowie: członkowie klubu SNOT.
13.W związku z tym ze regulamin wisi od niedawna, nie ma potrzeby wysylania rozpisek. Organizator zastrzega sobie możliwość sprawdzenia poprawności rozpiski w czasie turnieju, jeżeli napotka bledy w rozpisce będzie zmuszony nałożyć na osobe która gra bledna rozpiska 5 pkt karnych. Jeżeli macie jakiekolwiek pytania dotyczące zasad piszczie na forum.
Zgłaszajcie się na forum, będzie wiadomo ile stołów rozstawić.
14. Na turnieju przewidziane są dyplomy oraz ‘statuetki’ dla zwycięzców, możliwe że będą również nagrody rzeczowe.
Lista zgłoszeń:
1. Kołek
2. Kowal
3. Xet
4. Szymon
5. Młody
6. KJ
7. Thurion
8. Jagal
9. Błażej
10. Malin
11. Kuba
12. Benek
13. Teofil
14. Szrederator
15. Mati
16. Loki
17. Michał
18. Guzka
19. Mike
20. Pabiś
21. szme1
22. Szymon_Mały
23. Żbik
24. Oskar Przydatek
