pierwsze konkretne dwarfy na 2250 bp+r
Unnamed Dwarfs Army
1 * Dwarf Lord @ 296 Pts
General; Shieldbearers; Great Weapon; Gromril Armour
#Shield Bearer
Runic Armour
Rune of Stone
Runic Talisman
Master Rune of Spite
Runic Weapon
Master Rune of Kragg the Grim
Rune of Fury
Rune of Might
1 Thane @ 115 Pts
Gromril Armour; Battle Standard
Runic Banner
Rune of Stoicism
1 Runesmith @ 120 Pts
Gromril Armour; Shield
Runic Talisman
Rune of Spellbreaking (x3)
1 Runesmith @ 95 Pts
18 * Hammerers @ 327 Pts
Great Weapon; Heavy Armour; Shield; Standard; Musician
Runic Banner
Master Rune of Grugni
1 Gate Keeper
18 Ironbreakers @ 327 Pts
Gromril Armour; Shield; Standard; Musician
Runic Banner
Rune of Courage
Rune of Determination
1 Ironbeard
1 Grudge Thrower @ 170 Pts
Engineer
Engineering Runes [75]
Rune of Accuracy
Rune of Penetrating (x2)
1 Bolt Thrower @ 85 Pts
Engineer
Engineering Runes [25]
Rune of Penetrating
1 Bolt Thrower @ 65 Pts
Engineer
Engineering Runes [5]
Rune of Burning
1 Organ Gun @ 120 Pts
3 Crew
Light Armour
3 Crew
Light Armour
10 Quarrellers @ 110 Pts
Crossbow; Light Armour
10 Warriors @ 90 Pts
10 Thunderers @ 140 Pts
Dwarf Handgun; Light Armour
Dispel Pool: 6
Casting Pool: 2
Models in Army: 106
Total Army Cost: 2250
chcialem mieć i hamerkow i ironow
do hamkow idzie lord a do ironow bsb
#Shield Bearer
Runic Armour
Rune of Stone
Runic Talisman
Runic Weapon
Rune of Fury
Rune of Might
1 Thane @ 115 Pts
Runic Banner
Rune of Stoicism
Runic Talisman
Runic Banner
1 Gate Keeper
Runic Banner
Rune of Courage
1 Ironbeard
Engineer
Rune of Accuracy
Engineer
Rune of Penetrating
Engineer
Rune of Burning
3 Crew
Light Armour
3 Crew
Light Armour
Dispel Pool: 6
Casting Pool: 2
Models in Army: 106
Ostatnio zmieniony 19 cze 2009, o 07:00 przez Pistolet, łącznie zmieniany 2 razy.
- Arbiter Elegancji
-Na lordzie masz dwuraka, a nie masz master rune of Karagg the Grim.
-BSB Strasznie mięciutki.
-Na Katapie przydalaby się runa z przerzutem.
Oprócz tego jest ok.
z tym lordem to moja nie uwaga
poprawione
kosztem czego podpakowac bsbka?
szczerze mowaic to mam mieszaneuczucia co do 10 warriorsow
dzisiaj gralem na 2 takich i jedna praktycznie od razu uciekla od klocka swordsmanow a druga (z ktorej zostaly 2) pogonila 10 z magiem
poprawione
Dismay to lipa.
Nie baw się w takie pierdółki tylko bierz rzeczy konkretne, działające oraz takie, przez które przeciwnik naprawdę sra po gaciach, jak katapę z S10 i przerzutami scattera czy płonącą armatę z kuciem i dużym inżynierem. Oprócz tego BSB z siłą 5, 1+ przerzucalnym sejvem i 3 zwoje na jednym szmicie (5 dd i 3 zwoje to tylko o jeden mniej niż przewiduje restricted -> 5 + 1 + 2 X 2).
Wyjdzie styl Gogola, ale IMO lepszej rozpiski na tarczowniku nie ma.
Trochę punktów znajdziesz na małych warriorach i przede wszystkim na ironach, których powinieneś zmienić na longów.
- Arbiter Elegancji
Szczerze, to wywalilbym jednych thundów(jak nie będzie chociaż jednej górki to wystawienie 3x10 strzelców mając duże klocki i sporo maszyn jest trudne. nawet przy jednej górce nie jest różowo). drugich możesz dać np.12 jak 10 to dla ciebie za maly gun power; do tego przydalyby się tarcze na strzelcach, a za wolne pkt. można dopakować BSB.Pistolet pisze: kosztem czego podpakowac bsbka?
Lord na tarczy jest spoko, ale warto się zastanowić nad rune of steel dla niego, albo wardem, na 5+. Lepszy jest ward na 4+ ale wtedy dajesz challenge dla bsb, a samego bsb dopakowujesz (proponuje dla bsb challenge, rune of stone, rune od resistance albo rune of preservation, KONIECZNOŚCIĄ dla Bsb jest też rune of speed na broni - masz magiczną broń która kosztuje zaledwie 5 pkt, a w ostatnich czasach czesto można trafić na jakieś eteryczne ścierwa - mała rzecz a cieszy
Miętki bsbek....
Lord spotka się z siłą 7 i już ma kuku...
M.r. of challenge na lordzie zjada cenne punkty które mógłbyś przeznaczyć na r.of resistance. tak, każdy krasnoludzki bohater musi być chodzącą puszką
Ironsi bez kamienia nie mają sensu (niestety)
dla mnie za dużo thundów...
po co Ci katapulta z siłą 12 pod dziurką ?
10 warriorów jest naprawdę rewelacyjna....i znajdź punkty na longów - lepiej ich zamiast ironów
Zgadzam się . Imho longów nie miec na te punkty to duzy problem .Grazbird pisze:
Powiem szczerze , że ja gram inaczej . Zawsze mam te 4 klocki , mało strzelców. Ale jak to woli .
A po co 10 warriorów? Najlepiej dać od razu longów w miejsce ironów np. (a w miejsce ironów możesz dać np. cannon albo slayerów). A jesli sobie zyczysz to moge Ci złożyć znośnego bsb i dać mu magiczną broń. Swoją drogą lepiej dawaj bsb i lorda razem do hamców (masz challenge i przerzut stubborna).
zawsze pozostaje stare dobre proxo-trio
karton + nożyczki + linijka
zastanawia mnie koszt pkt obu szmitow...
chyba cos tu jest nie tak?
Abandoned
Abandoned
