1. Zapraszam na turniej, po krótce oto zasady:
Rules changes:
General Restrictions:
2400 Points.
Army used can be any of the currently published GW Army books. Chaos Dwarves and DoW definatly gone?
A maximum of 5 warmachines may be taken per army
Unit sizes of are limited as follows:
- Non-infantry units (including monstrous infantry): Maximum 16 models/unit
- Infantry costing 5 points or less: Maximum 50 models/unit
- Infantry costing 6-9 points: Maximum 40 models/unit
- Infantry costing 10 points or more: Maximum 30 models/unit
Magic Restrictions:
- Apart from Winds of magic and Channeling, an army may only generate 2 PD/DD per magic phase.
- “Count as” items/abilities may never exceed a cumulative 2PD/DD per phase. This means that if you take the power scroll, you may not take any other items that “count as adding PD/DD”
- All modifers are applied from the army list and will not change during the game.
Item restrictions:
- Power Scroll counts as generating 2 PD and 2 DD each magic phase
- Each Loremaster ability counts as generating 1 PD each magic phase
- Anything item that auto-dispels a spell counts as generating 1 DD each magic phase.
Army Specific Restrictions:
Beastmen: No Restrictions
Bretts: Trebuchet is a 0-1 choice
Dark Elves: Hydra is a 0-1 choice. Max. 35 repeater Crossbows in the army
Dwarves: Each spellbreaker/spelleater rune counts as "one item". Anvil of doom counts as warmachine; Grudge Throwers are a 0-2 choice; Max +4 dispel dice instead of +2
DOC: Flamers are a 0-1 choice. Siren Song may only be taken once
Empire: Steam Tank counts as 2 warmachines; Tank, Rocket battery and Engineers are a 0-1 choice
High Elves: Book of Hoeth counts as generating +2PD and +2 DD; Shard and Crystal as +1DD/phase
Lizards: Salamanders are a 0-1 Choice; Terradons, Chameleon Skinks and Stegadons (any kind) are 0-2 choices; Beclaming Cogitations counts as generating +1 PD and +2DD/phase, Cupped hands as +2PD/phase.
Ogres: No Restrictions
O&G: No Restrictions
Skaven: Hell Pit Abomination is a 0-1 choice; Gutter runners are a 0-2 choice; Engineers are a 0-3 choice
Vampires: Wraiths and Varghulf are 0-1 choices
TK: No restrictions
WE: Wand of Wych Elm counts as generating +1 DD/phase
Warriors of Chaos: Hellcannon is a 0-1 choice. Infernal Puppet counts as generating +1 PD and +2DD /phase; Tendrils of Tzeench and Conjoined Homunculus both count as generating +1 PD/Phase.
2. Czas gier:
do 8.30 zapisy i ustawianie stołów.
8:30-11:50 - I Bitwa
12:00-15:00 - II Bitwa
15:10-18:10 - III Bitwa
3. Malowanie
Podczas zapisów proszę zgłaszać swoje punkty za malowanie. Ja w wolnych chwilach przejdę się i obejrzę czy nikt nie ściemnia. Każdy gracz na starcie otrzymuje 6 pkt za pomalowaną armię. Za każdy niepomalowany oddział/bohatera odejmujemy 1 punkt (pomalowane proksy liczą się jako oddziały niepomalowane). Nie można mieć z malowania mniej niż zero pkt.
4. Proksy
Jeśli macie wątpliwości co uznam za proksy to pytajcie. Generalnie będę liberalny, i jeśli odziały będą z tej samej armii i nie będą wprowadzały przeciwnika w błąd co do ich istoty to luz. Tzn. szejdzi z dwurakami przejdą za tych z additional weapon o ile nie ma w rozpie drugiego oddziału szejdów z dwurakami. Kusznicy przejdą za thundererów o ile w armii nie ma zwyklych kuszników itd.
5. Progi punktowe liczymy co 200pkt.
UWAGA: gramy na liczenie punktów wg Rulebooka, czyli nie ma pkt za społowionych bohaterów, uciekajace oddziały itd...
Do zobaczenia!
Turniej ETC w Białymstoku, 18.12.2010r.
