Zabrzański Klub Fantastyki zaprasza na turniej Warhammer Fantasy Battle.
Data: 9 kwietnia 2011
System: Warhammer Fantasy Battle
Miasto: Zabrze
Adres: ul. Wolności 350a
Format: 1800 pts, ETC bez Lordów.
Początek: 9:50
Wpisowe: 10 zł
Czas:
09:50-10:00 Zapisy
10:00-12:30 I Bitwa
12:45-15:15 II Bitwa
15:30-18:00 III Bitwa
18:15 Odczytanie wyników i rozdanie nagród
Zasady turnieju:
Rules changes:
General Restrictions:
1800 Points.
No Lords.
Army used can be any of the currently published GW Army books.
An army may have up to 5 war machines and template weapons. Warmachines that use a template count as a single choice in this regard. All template weapons (from magic items, abilities, etc.) count, except for spells.
Magic Restrictions:
- Apart from Winds of magic and Channeling, an army may only generate 2 PD/DD per magic phase.
- “Count as” items/abilities may never exceed a cumulative 2 PD/DD per phase. This means that if you take the Book of Hoeth, you may not take any other items that “count as adding PD/DD”
Detailed description
Apart from winds of magic and through the channeling rule, an army may only ever add 2 dice to its power or dispel pool in each magic phase. Any dice added to the pool, regardless of source (generated, stolen, stored from previous magic phases, generated by magic items/abilities to boost spellcasting before or after the casting attempt, produced by spells, lore abilities, and so on) count. Excess dice are simply discarded and cannot be used in any way (i.e. - they can’t be stored).
Item restrictions:
- Power Scroll is banned
- Each Loremaster ability counts as generating 1 PD each magic phase
Army Specific Restrictions:
Beastmen: Beastmen armies have an extra 200 points for their roster (2600 total).
Bretts: No Restrictions
Dark Elves: Hydra is a 0-1 choice. Max. 35 repeater Crossbows in the army. Repeater Bolt Throwers 0-2. Flying units (inc. characters on flying steeds) in the army limited to 0-3. Shades max 20 models per army. Dreadlord on pegasus cannot take Crown of Command.
Dwarves: Each spellbreaker/spelleater rune counts as +1 DD. Grudge Throwers are a 0-2 choice; May generate Max. +4 dispel dice instead of +2
DOC: Max. 28 Models per unit; Flamers are a 0-1 choice. All daemonic gifts are 0-1. Bloodletters and Herald of Khorne are 0-3 total. Daemonic Battle Standard can take either daemonic icon or gifts.
Empire: Steam Tank counts as a war machine; Tank, Rocket battery and Engineers are a 0-1 choice
High Elves: Max. 500 points or 40 models per unit; Vortex Shard counts as +1DD; Book of Hoeth counts as 2PD and 2 DD; Banner of the World Dragon counts as +1 DD
Lizardmen: Salamanders are a 0-1 Choice; Terradons, Chameleon Skinks and Stegadons (any kind) are 0-2 choices; Beclaming Cogitations counts as +2DD; Cupped hands counts as +2PD
Ogres: Ogre Kingdoms armies have an extra 200 points for their roster (2600 total).
O&G: No Restrictions
Skaven: All Skaven rare choices 0-1; Gutter runners are a 0-2 choice; Engineers are a 0-3 choice;
Vampires: Wraiths and Varghulf are 0-1 choices. Wraith unit size - maximum 5 models. Army may have maximum two units (total) of: wraiths, black coach or spirit hosts. Army with grave guard using great weapons may not have Drakenhoff Banner.
TK: Tomb King armies have an extra 200 points for their roster (2600 total).
WE: Wand of Wych Elm counts as +1 DD
Warriors of Chaos: Hellcannon is a 0-1 choice. Infernal Puppet counts as +1 PD and +2DD; Tendrils of Tzeench and Conjoined Homunculus both counts as +1 PD. Favour of the Gods cannot be taken by a Champion of a Chosen of Tzeentch unit
Scoring
In both cases, bonuses (for generals, banners, etc.) are not counted towards the 50%.
Progi punktowe:
0-150 - 10-10
151-300 - 11-9
301-450 - 12-8
451-600 - 13-7
601-750 - 14-6
751-900 – 15-5
901-1050 – 16-4
1051-1200- 17-3
1201-1350- 18-2
1351-1500-19-1
1500+ - 20/0
Virtual Line of Sight
Size chart:
0: Swarms - models of this size never block line of sight or give cover.
1: Infantry, War Beasts, War Machines
2: Cavalry, Monstrous Infantry/Cavalry/Beasts, Chariots, Unique without the Large Target rule
3: Monsters, all Large Targets
Line of sight is always checked virtually, drawn "base to base". Models see in their front 1/4 zone. Line of Sight is blocked by models that are equal to or larger than both: the model whose line of sight we are checking and its target.
Line of sight and war machines:
Catapults (and similar) can place their template so that the center is over any one unit that is at least partially visible to them.
Cannons can choose any point between themselves and a visible target when firing. Over- or under-guessing to shoot at units the cannon does not have line of sight to is not allowed
Terrain
Hills are size two for each level (so a 3-step hill is size 6) and block sight / give hard cover just like models of that size. Models standing on hills add the hill size to their own size. Buildings and large rocks always block line of sight completely. Forests do not block line of sight, but soft cover applies to all shots fired through or into (but not out of) forests. Ruins do not block line of sight, but hard cover applies to all shots fired into (but not through/out of) ruins. Units standing behind obstacles gain soft (wood) or hard (stone) cover as per the RB.
Cover from intervening units/terrain
Cover is granted when at least 50% of models in target unit are fully or partially obscurred by other units/terrain from the shooting model. In order for intervening models to grant cover, their size must be at least: one point smaller than both the target unit and the shooting model.
Skirmishers
Skirmishers never block LoS, and are seen in accordance with their size on the chart, but provide cover as per the above rules. The gap between skirmishers is treated as part of the unit when determining if skirmishers give cover to something behind them. Skirmishers formed up for combat block Line of Sight like normal units.
Zaorane pole działa jak marshland.
ZGŁOSZENI:
1. Szymon.
2. Szczurek.
3. Pasztet.
4. Ździchu.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
Spring Chill 9 kwietnia 2011 EURO 1800 bez lordów Zabrze
Szkoda, że nie chcecie tego zrobić dzień później...
o.b-one pisze:Podobne uczucia towarzyszą mi po czytaniu tych wszystkich żali. Pod koniec każdego takiego posta pozostaje niesmak i jednocześnie ulga, że to już koniec...Barbarossa pisze:(..) co przynosi mieszaninę ulgi, że turlanina skończyła się, oraz niesmaku, że imba.
