Dnia 16 Kwietnia
Warszawa, Gimnazjum nr 2 przy ulicy Narbutta 65/71
Punkty: 2x1350
Wejściówka: 15 zł od osoby
NAGRODY:
ZGŁOSZENIA:
Zgłoszenia przyjmujemy do 14-go kwietnia pod adresem kgbbastion@gmail.com z rozpiską w formatach html, txt lub wklejoną w treść maila. Zgłoszenia muszą zawierać IMIĘ, NAZWISKO i NR ID. Za poprawne zgłoszenie przysługują 2 dodatkowe punkcisze.
Jeśli ktoś nie ma nr ID, można go wyrobić tutaj:
http://ranking.wfb-pol.org/player_add.php
HARMONOGRAM TURNIEJU:
Zapisy 9:00 - 9:30
I bitwa 9:30 - 12:30
II bitwa 12:30 - 15:30
III bitwa 15:30 - 18:30
REGULAMIN:
Na potrzeby tych ograniczeń traktujemy obie sojusznicze armie jako jedną, tj. 2PD/DD na obie armie.
"upośledzone" armie mają +100 punktów i -10%
Bardziej szczegółowo tu:ETC 2011 AR FINAL
Rules changes:
I. General Restrictions:
Army used can be any of the currently published GW Army books.
An army may have up to 5 war machines and template weapons. Warmachines that use a template count as a single choice in this regard. All template weapons (from magic items, abilities, etc.) count, except for spells.
Magic Restrictions:
- Apart from Winds of magic and Channeling, an army may only generate 2 PD/DD per magic phase.
- “Count as” items/abilities may never exceed a cumulative 2 PD/DD per phase. This means that if you take the Book of Hoeth, you may not take any other items that “count as adding PD/DD”
Detailed description
Apart from winds of magic and through the channeling rule, an army may only ever add 2 dice to its power or dispel pool in each magic phase. Any dice added to the pool, regardless of source (generated, stolen, stored from previous magic phases, generated by magic items/abilities to boost spellcasting before or after the casting attempt, produced by spells, lore abilities, and so on) count. Excess dice are simply discarded and cannot be used in any way (i.e. - they can’t be stored).
Item restrictions:
- Power Scroll is banned
- Each Loremaster ability counts as generating 1 PD each magic phase
Army Specific Restrictions:
Beastmen: Beastmen armies have an extra 100 points for their roster. All victory points scored against this army are decreased by 10% (excluding bonus points for banners, general, etc.).
Bretts: No Restrictions
Dark Elves: Hydra is a 0-1 choice. Max. 35 repeater Crossbows in the army (regardless of who carries them). Repeater Bolt Throwers 0-2. Flying units (inc. characters on flying steeds) in the army limited to 0-3. Shades max 20 models per army. Dreadlord on pegasus cannot take Crown of Command.
Dwarves: Each spellbreaker/spelleater rune counts as +1 DD. Grudge Throwers are a 0-2 choice; May generate Max. +4 dispel dice instead of +2
DOC: Max. 28 Models per unit; Flamers are a 0-1 choice. All daemonic gifts are 0-1. Bloodletters and Herald of Khorne are 0-3 total. Daemonic Battle Standard can take either daemonic icon or gifts.
Empire: Steam Tank counts as a war machine; Tank, Rocket battery and Engineers are 0-1 choices
High Elves: Max. 500 points or 40 models per unit; Vortex Shard counts as +1DD; Book of Hoeth counts as 2PD and 2 DD; Banner of the World Dragon counts as +1 DD
Lizardmen: Salamanders are a 0-1 Choice; Terradons, Chameleon Skinks and Stegadons (any kind) are 0-2 choices; Beclaming Cogitations counts as +2DD; Cupped hands counts as +2PD
Ogres: Ogre Kingdoms armies have an extra 100 points for their roster. All victory points scored against this army are decreased by 10% (excluding bonus points for banners, general, etc.). Rhinox Riders are allowed.
O&G: Night Goblin Shamans are 0-3 (max 3 of any kind of NG shaman); mushroom dice do not count as power dice in regard to the PD limit.
Skaven: All Skaven rare choices 0-1; Gutter runners are a 0-2 choice; Engineers are a 0-3 choice;
Vampires: Wraiths and Varghulf are 0-1 choices. Wraith unit size - maximum 5 models. Army may have maximum two units (total) of: wraiths, black coach or spirit hosts. Army may include a maximum of two of the following: Helm of Commandment, Master of the Black Arts, Drakenhoff Banner.
TK: Tomb King armies have an extra 100 points for their roster. All victory points scored against this army armies are decreased by 10% (excluding bonus points for banners, general, etc.).
WE: Wand of Wych Elm counts as +1 DD
Warriors of Chaos: Hellcannon is a 0-1 choice. Infernal Puppet counts as +1 PD and +2DD; Tendrils of Tzeench and Conjoined Homunculus both counts as +1 PD. Favour of the Gods cannot be taken by a Champion of a Chosen of Tzeentch unit
II. Scoring
Victory points to Battle points per game:
0-150 Victory-Points difference - 10-10
151-300 - 11-9
301-450 - 12-8
451-600 - 13-7
601-750 - 14-6
751-900 – 15-5
901-1050 – 16-4
1051-1200- 17-3
1201-1350- 18-2
1351-1500-19-1
1500+ - 20/0
III. Virtual Line of Sight
http://warhammer.org.uk/phpBB/viewtopic ... 18&t=85740
SĘDZIOWIE:
Zbyszek "Barbarossa" Łobocki - główny
Rafał "Trikk" Bieliński - techniczny #1
Michał "Matej" Matejuk - techniczny #2
KOMPOZYCJA ARMII
0-25% Lord
0-25% Heroes
25%+ Core Units
0-50% Special Units
0-25% Rare Units
SCENARIIUSZE:
1) Meeting Engagement
2) Blood & Glory
3) Battleline
Zgodnie z tradycją i dobrym obyczajem, witamy gości z daleka darmowym wjazdem na turniej!
