Miejsce: Bard Wrocław
Link Mapy:
BARD WROCŁAW
Wpisowe: 10 zł
Nagrody: 10zł x Ilość graczy + 50% od Sklepu bard
Zgłoszenia:
Zgłoszenia zawierające imię, nazwisko, oraz rozpiskę (txt, html, pdf, rst) przyjmujemy pod adresem e-mailowym woltar@wp.pl
Wysłanie zgłoszenia do 23.03.2012 do 20:00 będzie premiowane dodatkowymi 3 dużymi punktami do klasyfikacji generalnej.
Sędzia: Kolektyw klubowy
Numer Graczy (ID) ze strony Polskiej Ligi WFB http://ranking.wfb-pol.org/players.php
ZASADY EURO DRAFT #2
Kod: Zaznacz cały
Rules changes:
I. General Restrictions:
2400 Points.
Army used can be any of the currently published GW Army books. Forge World based army lists & units may not be used on the event
An army may have up to 4 war machines and template weapons. Warmachines that use a template count as a single choice in this regard. All template weapons (from magic items, abilities, etc.) count, except for spells.
Magic Restrictions:
- Player can use maximum 5 PD to cast spell (+ wizard level). For death & shadow spells this max is lowered to 4 power dice.
- An army may use up to 12 PD during each phase.
Detailed description
Apart from Winds of magic, an army may only use 2 PD/DD per magic phase (unless army restrictions specify otherwise). After an army generates the limit all the other extra dice are discarded. This includes channeled PD/DD.
Item restrictions:
Army Specific Restrictions:
Beastmen: Beastmen armies have an extra 200 points for their roster (2600 total), All victory points scored against this army are decreased by 10% (excluding bonus points for banners, general, etc.), Beastmen can generate 3 extra pd instead of 2. Can use 4 instead of 3 same core units and have a unit cap of 50 models per unit.
Bretonnia: No Restrictions
Chaos Dwarfs:
Hellcannon 0-1
Iron daemon, kdai destroyer and every model with hashut lore count as war machines
chalice of darkness counts as 2 pd
Max 3 out of lore of Hashut, s5 war machine templates, destroyer, iron daemons.
Chalice or Sorcerer Prophet
Flask counts as 3 war machines.
Dark Elves: Hydra is a 0-1 choice. Max. 35 repeater Crossbows (including characters and excluding chariots) in the army. Repeater Bolt Throwers 0-2. Harpies are 0-2. Shades max 20 models per army, Pendant of khaeleth cannot be taken by lord characters, player may take up to 2 of following: Pendant of khaeleth\Crown of command\any number of wizards using death & shadow magic\Cauldron of Blood\Hydra.
Dwarfs: Each spellbreaker/spelleater rune counts as +1 DD. Grudge Throwers are a 0-2 choice; May generate Max. +4 dispel dice instead of +2.
Daemons of Chaos:Max. 30 Models per unit. All daemonic gifts are 0-1. Daemonic Battle Standard can take either daemonic icon or gifts. Siren song cannot be taken by Herald of Slaanesh. Max 6 flamers in the army. Mos: Rule change: It doesn't give loremaster lore (can take any rb lore)
The Empire: Steam Tank counts as a war machine; Tank, Rocket battery and Engineers are a 0-1 choice. Max 2 cannons, steam tank count as a cannon.
High Elves: High Elves armies have an extra 100 points for their roster (2500 total); High elves army can generate extra 3 powerdice instead of 2; Vortex Shard counts as +1DD; Book of Hoeth counts as 2PD and 2 DD; Banner of the World Dragon counts as +1 DD
Lizardmen: Salamanders are a 0-1 Choice;Scar-Veterans 0-2, player may take up to 2 of following: Beclaming Cogitations\ Focus of Mystery\ Focused Rumination \Higher State of Consciusness; Beclaming Cogitations counts as +2DD; Cupped hands of the Old Ones counts as +2PD; Higher State of Consciusness counts as 2 discplines (takes two slots, but cost same points); Crown of Command & Higher State of Consciousness cannot be taken on 1 model; A maximum total of 6 Skink, Chameleon skinks and Skink Cohorts units combined maybe taken in an army (Cohorts containing kroxigor or numbering above 20 models do not count for this restriction). Max 1 of these in army death lore/bane head/feedback scroll
Ogre Kingdoms: Hellheart counts as 2dd & 1pd, Greedyfist on death mage counts as 2dd. Each leadbelcher/ sniper maneater with pistol(s) counts as 3 models towards to shooting cap. Max 3 combined units of Mournfang Cav & Ironblaster. 0-1 Ironblaster.
Orcs&Goblins: Night Goblin Shamans(0-3 cap removed) mushroom dice do not count as power dice in regard to the PD limit. Maximum model cap is 60 models per unit. +100 pts.
Skaven: All Skaven rare choices 0-1; Gutter runners are limited by 2 units & 20 models total; Engineers are a 0-3 choice; Can take max 2 of the following: doom rocket, brass orb, storm banner;
Vampire Counts: Master of black arts & blasphemous tome upgradeare 1pd each. 0- 3 etheral units (incl. Heroes). 0-2 red fury and/or quickblood abilities. 0-4 howls (death shriek counts as 2)
Tomb Kings: Tomb King armies have an extra 200 points for their roster (2600 total), All victory points scored against this army are decreased by 10% (excluding bonus points for banners, general, etc.), Neferra's Scrolls of Mighty Incantations counts as 2 PD AND 2 DD. Hierotitan is worth 1 PD so long as it's alive. Sphinxes of all kinds: 0-3 per army. Tomb Kings may generate up to 3 power dice per phase
Wood Elves: Wood Elf armies have an extra 200 points for their roster (2600 total) All victory points scored against this army are decreased by 10% (excluding bonus points for banners, general, etc.), Wood Elves can take 4 of the same core unit instead of 3, Wand of Wych Elm counts as +1 DD; Only Glade guards (including scouts) count for max of 45 models with shooting weapons
Warriors of Chaos: Hellcannon is a 0-1 choice. Infernal Puppet counts as +1 PD and +2DD; Tendrils of Tzeench and Conjoined Homunculus both counts as +1 PD. If you have warriors, knights and or chosen with marks of tzeentch in army then you can take max 2 out of 3 of warshrines and favor of the gods (2xwarshrines or warshrine and favor of the gods).
II. Scoring
0-20 Victory-Points per game
Victory points to Battle points per game:
0-150 Victory-Points difference - 10-10
151-300 - 11-9
301-450 - 12-8
451-600 - 13-7
601-750 - 14-6
751-900 – 15-5
901-1050 – 16-4
1051-1200- 17-3
1201-1350- 18-2
1351-1500-19-1
1500+ - 20/0
III. Scenarios
Pitched battle scenario
IV. Simple Line of Sight
cumulative).
- When such a unit is doing the shooting there are no to hit penalties for interfering or non-blocking
units or terrain, other than interfering woods.
NADRZĘDNY REGULAMIN TURNIEJOWY KLUBU THE GAMBLERS:
Kod: Zaznacz cały
I. BYE
I.1 jeżeli NIE z winy gracza (np. nie może on zagrać bitwy z powodu nieparzystej ilości uczestników) dostaje wynik 15:5
BYE zawsze jest na najniższym stole
I.2 Kolejność przyznawania "bye"
- spóźnienie gracza ponad 15 minut od rozpoczęcia rundy
- na życzenie gracza
- nie klubowicz z nie wysłana rozpiską
- Gamblers z nie wysłaną rozpiską
- nie klubowicz, który wysłał rozpiskę
- Gamblers, który rozpiskę wysłał
II. DROP
Jest to sytuacja, gdy gracz zabiera się do domu, mimo trwania turnieju, wówczas dostaje:
- jeżeli powoduje, że przeciwnik zostaje bez paringu - 5:15
- jeżeli powoduje, że jest wciąż parzysta liczba graczy 10:10
III. WAŁY
Udowodniony wał, choćby nie rzutował na dalszą bitwę (tj. umyślne, celowe wprowadzanie przeciwnika w błąd) będzie weryfikowane na korzyść zwałowanego 20:0. Jeżeli sytuacja jest sporna, rozstrzyga sędzia. Podobnie ma się sytuacja ze zbyt szybkim zabieraniem kostek po rzucie bez możliwości zobaczenia wyników przez przeciwnika. Nagminne stosowanie powyższej techniki również będzie skutkowało wynikiem 20:0 dla przeciwnika.
IV. Recydywa
Każdy, kto wielokrotnie będzie łamał zasady dostaje bana na turnieje do odwołania
VI. Zachowanie
Wiadomo jak to w bitwie bywa, czasem nadchodzi taka chwila która aż prosi się o soczysty bluzg. W związku z tym jedno przekleństwo na bitwę obędzie się bez konsekwencji ale każde następne będzie skutkowało otrzymaniem -1 DP karniaków
