![Obrazek](http://truelegion.pl/img/ajwajheim.png)
![Obrazek](https://lh3.googleusercontent.com/_GOX2svLRlM0/TNOvrDjLCEI/AAAAAAAAAsc/hKBp9xQjXaQ/s576/logo%20legion.jpg)
Data: 14.04.2012
Format: 2400 EURO DRAFT 2
Wpisowe: 10zł
Nagrody: Zależne od frekwencji
Limit miejsc: 14 + 2
Adres: ul. Lubicz 34/6
Tutaj jak trafić: link
Start turnieju: równo 10:00 zaczynamy grać bitwy (zapisy od 9:30)
Zakończenie turnieju: ok 19:00
Czas na bitwę: 2,5-3h. Gramy 3 bitwy, każda 6 tur.
Ogólne zasady turnieju
W czasie turnieju obowiązują zasady 8ed WFB zapisane w:
- rulebooku 8ed i army bookach
- aktualnych erratach i faq'ach publikowanych na stronach Games Workshop
- aktualnych uściśleniach sędziowskich http://strony.aster.pl/barbaros/usc8.pdf
- Simple LoS
Specyficzne zasady kompozycji armii (EURO):
Rules changes:
I. General Restrictions:
2400 Points.
Army used can be any of the currently published GW Army books. Forge World based army lists & units may not be used on the event
An army may have up to 4 war machines and shooting template weapons. Warmachines that use a template count as a single choice in this regard. All template weapons (from magic items, abilities, etc.) count, except for spells. Bolt thr. count as ½ a war machine(round up).
All BSBs can take all the Equipment, their unit type has acces to as if they weren't BSBs.
Magic Restrictions:
- Player can use maximum 5 PD to cast spell (+ wizard level). For death & shadow spells this max is lowered to 4 power dice.
- An army may use up to 12 PD during each phase.
Detailed description
Apart from Winds of magic, an army may only use 2 PD/DD per magic phase (unless army restrictions specify otherwise). After an army generates the limit all the other extra dice are discarded. This includes channeled PD/DD.
Item restrictions:
Army Specific Restrictions:
Beastmen: Beastmen armies have an extra 200 points for their roster (2600 total), All victory points scored against this army are decreased by 10% (excluding bonus points for banners, general, etc.), Beastmen can generate 3 extra pd instead of 2. Can use 4 instead of 3 same core units and have a unit cap of 50 models per unit and point cap on units 550 instead of 450 pts.
Bretonnia: No Restrictions
Chaos Dwarfs
Hellcannon, Iron daemon are each 0-1
Iron daemon, kdai destroyer count as war machines
chalice of darkness counts as 2 pd
Max 3 out of Str. 5 shooting templates, Kdai destroyer.
Chalice or Sorcerer Prophet
Lore of Hashut can be cast with max 4 PD.
Dark Elves: Hydra is a 0-1 choice. Max. 35 repeater Crossbows (including characters and excluding chariots) in the army. Repeater Bolt Throwers 0-2. Harpies are 0-2. Shades max 20 models per army, Pendant of khaeleth cannot be taken by lord characters, player may take up to 2 of following: Pendant of khaeleth\Crown of command\Cauldron of Blood\Hydra.
Dwarfs: Each spellbreaker/spelleater rune counts as +1 DD. Grudge Throwers are a 0-2 choice; May generate Max. +4 dispel dice instead of +2; gyrocopter doesn't count for max 4 war machine/template.
Daemons of Chaos
Max. 30 Models per unit; All daemonic gifts are 0-1. Daemonic Battle Standard can have gifts if his magic banner does not cost over 50pts. Siren song cannot be taken by Herald of Slaanesh. Max 6 flamers in the army. MOS: If taken by herald it gives you 'loremaster: Lore of Tzeentch' or the ability to randomly determine spells(as a normal lvl 2) from any of the 8 rulebook lores.
The Empire (NEW): Steam tank 0-1. Cannons 0-3, steam stank count as a cannon.
High Elves: High Elves armies have an extra 100 points for their roster (2500 total); High elves army can generate extra 3 powerdice instead of 2; Vortex Shard counts as +1DD; Book of Hoeth counts as 3PD and 2 DD; Banner of the World Dragon counts as +1 DD
Lizardmen: Salamanders are a 0-1 Choice;Scar-Veterans 0-2; player may take up to 2 of following: Beclaming Cogitations\ Focus of Mystery\ Focused Rumination \Higher State of Consciusness; Beclaming Cogitations counts as +2DD; Cupped hands of the Old Ones counts as +2PD; Higher State of Consciusness counts as 2 discplines (takes two slots, but cost same points); Crown of Command & Higher State of Consciousness cannot be taken on 1 model; A maximum total of 6 Skink, Chameleon skinks and Skink Cohorts units combined maybe taken in an army (Cohorts containing kroxigor or numbering above 20 models do not count for this restriction). Max 1 of these in army death lore/bane head/feedback scroll
Ogre Kingdoms: Hellheart counts as 2dd & 1pd, Greedyfist on death mage counts as 2dd, Rune Maw Banner counts as 1dd. Each leadbelcher/ sniper maneater with pistol(s) counts as 3 models towards to shooting cap. Max 3 combined units of Mournfang Cav & Ironblaster. 0-1 Ironblaster.
Orcs&Goblins: Night Goblin Shamans(0-3 cap removed) mushroom dice do not count as power dice in regard to the PD limit. Maximum model cap is 60 models per unit. +100 pts.
Skaven: All Skaven rare choices 0-1; Gutter runners are limited by 2 units & 20 models total; Engineers are a 0-3 choice; Can take max 2 of the following: doom rocket, brass orb, storm banner;
Vampire Counts
Master of black arts & blasphemous tome upgradeare 1pd each. 0- 3 etheral units (incl. Heroes). 0-2 red fury and/or quickblood abilities. 0-4 howls (death shriek counts as 2) 0-1 Terrorgheist , a max of 4 flying units, max 15 mounted characters and black knights combined
Tomb Kings: Tomb King armies have an extra 200 points for their roster (2600 total), All victory points scored against this army are decreased by 10% (excluding bonus points for banners, general, etc.), Neferra's Scrolls of Mighty Incantations counts as 2 PD AND 2 DD. Hierotitan is worth 1 PD so long as it's alive. Sphinxes of all kinds: 0-3 per army. Tomb Kings may generate up to 3 power dice per phase
Wood Elves: Wood Elf armies have an extra 200 points for their roster (2600 total) All victory points scored against this army are decreased by 10% (excluding bonus points for banners, general, etc.), Wood Elves can take 4 of the same core unit instead of 3, Wand of Wych Elm counts as +1 DD; Only Glade guards (including scouts) count for max of 45 models with shooting weapons
Warriors of Chaos: Hellcannon is a 0-1 choice. Infernal Puppet counts as +1 PD and +2DD; If you have warriors, knights and or chosen with marks of tzeentch in army then you can take max 2 out of 3 of warshrines and favor of the gods (2xwarshrines or warshrine and favor of the gods).
ZOSTANIE PRZEPROWADZONA OCENA HOBBYSTYCZNA:
100% pomalowanych modeli + brak proksów: 2 DP
Posiadanie własnych kostek, miarki, AB i czytelnej rozpiski (nie drukowanej w Vanaheimie): 1 DP
Zgłoszenia przyjmowane wyłącznie poprzez PW oraz wfb.krakow@gmail.com
Zgłoszenie powinno zawierać imię, nazwisko lub ksywkę i nr ID ze strony ligowej (http://ranking.wfb-pol.org/players.php)
