STARY KLINKIERA XXXI, 24.06.2012 Sopot
szade!
BWT Klika wraz z klubem "Rzeźnik" i sklepem Futurex oraz Starym Klinkiera ma zaszczyt zaprosić na turniej, który odbędzie się 24-06-2012
Turniej zaczyna się o 10:00, zapisy i wejście od 09:45
Format - 2400 Euro
liczba bitew - pierwsza 3 h, druga i trzecia 2,5h
Sędziowie: Suchy, Pająk
Wejściówka 10 zł
Miejsce Klub Rzeźnik Brodwino
Brak oceny malowania, proxy dopuszczone
- turniej zaliczany jest do Rankingu Ligi Ogólnopolskiej
Zasady turnieju:
Zasady turnieju zgodne z 8 edycją WFB.
Rozpiski jawne, zakaz wystawiania bohaterów, lordów i dowódców imiennych.
Obowiązują aktualne oficjalne erraty i FAQi oraz polskie uściślenia sędziowskie (http://strony.aster.pl/barbaros/usc8.pdf).
SLOS.
Rules changes:
I. General Restrictions:
2400 Points.
Army used can be any of the currently published GW Army books. Forge World based army lists & units may not be used on the event, except for Chaos Dwarves.
An army may have up to 4 war machines and shooting template weapons. Warmachines that use a template count as a single choice in this regard. All template weapons (from magic items, abilities, etc.) count, except for spells. Bolt thr. count as ½ a war machine(round up).[/color]
All BSBs can take all the Equipment, their unit type has acces to as if they weren't BSBs.
Magic Restrictions:
- Player can use maximum 5 PD to cast a spell. For death & shadow spells this max is lowered to 4 power dice.
- An army may use up to 12 PD during each phase.
Detailed description
Apart from Winds of magic, an army may only use 2 PD/DD per magic phase (unless army restrictions specify otherwise). After an army generates the limit all the other extra dice are discarded. This includes channeled PD/DD.
Item restrictions:
Army Specific Restrictions:
Beastmen: Beastmen armies have an extra 200 points for their roster (2600 total), All victory points scored against this army are decreased by 10% (excluding bonus points for banners, general, etc.), Beastmen can generate 3 extra pd instead of 2. Can use 4 instead of 3 same core units and have a unit cap of 50 models per unit and point cap on units 550 instead of 450 pts.
Bretonnia: No Restrictions
Chaos Dwarfs
Hellcannon, Iron daemon are each 0-1.
Iron daemon, kdai destroyer count as war machines.
Chalice of darkness counts as 2 pd.
Max 3 out of Str. 5 shooting templates, Kdai destroyer.
Chalice or Sorcerer Prophet.
Lore of Hashut can be cast with max 4 PD.
Dark Elves: Hydra is a 0-1 choice. Max. 35 repeater Crossbows (including characters and excluding chariots) in the army. Repeater Bolt Throwers 0-2. Harpies are 0-2. Shades max 20 models per army, Pendant of khaeleth cannot be taken by lord characters, player may take up to 2 of following: Pendant of khaeleth\Crown of command\Cauldron of Blood\Hydra.
Dwarfs: Each spellbreaker/spelleater rune counts as +1 DD. Grudge Throwers are a 0-2 choice; May generate Max. +4 dispel dice instead of +2; gyrocopter doesn't count for max 4 war machine/template.
Daemons of Chaos
Max. 30 Models per unit; All daemonic gifts are 0-1. Daemonic Battle Standard can have gifts if his magic banner does not cost over 50pts. Siren song cannot be taken by Herald of Slaanesh. Max 6 flamers in the army. MOS: For Heralds of Tzeentch only it is a 0-2 gift and the Loremaster rule is removed; instead randomly determine spells (as a normal lvl 2) from any of the 8 rulebook lores.
The Empire: Steam tank 0-1. Cannons 0-3, steam stank count as a cannon.
High Elves: High Elves armies have an extra 100 points for their roster (2500 total); High elves army can generate extra 3 powerdice instead of 2; Vortex Shard counts as +1DD; Book of Hoeth counts as 3PD and 2 DD; Banner of the World Dragon counts as +1 DD
Lizardmen: Salamanders are a 0-1 Choice;Scar-Veterans 0-2, player may take up to 2 of following: Beclaming Cogitations\ Focus of Mystery\ Focused Rumination \Higher State of Consciusness; Beclaming Cogitations counts as +2DD; Cupped hands of the Old Ones counts as +2PD; Higher State of Consciusness counts as 2 discplines (takes two slots, but cost same points); Crown of Command & Higher State of Consciousness cannot be taken on 1 model; A maximum total of 6 Skink, Chameleon skinks and Skink Cohorts units combined maybe taken in an army (Cohorts containing kroxigor or numbering above 20 models do not count for this restriction). Max 1 of these in army death lore/bane head/feedback scroll
Ogre Kingdoms: Hellheart counts as 2dd & 1pd, Greedyfist on death mage counts as 2dd, Rune Maw Banner counts as 1dd. Each leadbelcher/ sniper maneater with pistol(s) counts as 3 models towards to shooting cap. Max 3 combined units of Mournfang Cav & Ironblaster. 0-1 Ironblaster.
Orcs&Goblins: Night Goblin Shamans mushroom dice do not count as power dice in regard to the PD limit. Maximum model cap is 60 models per unit. +100 pts.
Skaven: All Skaven rare choices 0-1; Gutter runners are limited by 2 units & 20 models total; Engineers are a 0-3 choice; Can take max 2 of the following: doom rocket, brass orb, storm banner.
Vampire Counts
Master of black arts & blasphemous tome upgradeare 1pd each. 0- 3 etheral units (incl. Heroes). 0-2 red fury and/or quickblood abilities. 0-4 howls (death shriek counts as 2). 0-1 Terrorgheist , a max of 4 flying units, max 15 mounted characters and black knights combined.
Tomb Kings: Tomb King armies have an extra 200 points for their roster (2600 total), All victory points scored against this army are decreased by 10% (excluding bonus points for banners, general, etc.), Neferra's Scrolls of Mighty Incantations counts as 2 PD AND 2 DD. Hierotitan is worth 1 PD so long as it's alive. Sphinxes of all kinds: 0-3 per army. Tomb Kings may generate up to 3 power dice per phase
Wood Elves: Wood Elf armies have an extra 200 points for their roster (2600 total) All victory points scored against this army are decreased by 10% (excluding bonus points for banners, general, etc.), Wood Elves can take 4 of the same core unit instead of 3, Wand of Wych Elm counts as +1 DD; Only Glade guards (including scouts) count for max of 45 models with shooting weapons.
Warriors of Chaos: Hellcannon is a 0-1 choice. Infernal Puppet counts as +1 PD and +2DD; If you have warriors, knights and or chosen with marks of tzeentch in army then you can take max 2 out of 3 of warshrines and favor of the gods (2xwarshrines or warshrine and favor of the gods).
III. Scoring
Progi co 150 pkt.
Zgłoszeni:
1. MAti
2. Pająk
3. DaBoss
4. Ja
5. Loki
6. Macias
7. Jagal
8. Eddie
9. Malin
10. Crovaxus
11. Kervyn
12. Wendigo
13. Korhil
14. Byro
15. Bogdan
16. Rogal
17. Afro
18. Lubin
19. Błażej
20. Rilam
21. Sowa
22. Pitul
23. BigPasiak
24. esgaroth
25. Sunil
26. Bladeweaver
27. Zręczny Krzyś
28. Mike
Format - 2400 Euro
Wejściówka 10 zł
Zasady turnieju:
SLOS.
Rules changes:
2400 Points.
Magic Restrictions:
Item restrictions:
Chaos Dwarfs
Daemons of Chaos
Vampire Counts
III. Scoring
Progi co 150 pkt.
Zgłoszeni:
1. MAti
2. Pająk
3. DaBoss
4. Ja
5. Loki
6. Macias
7. Jagal
8. Eddie
9. Malin
10. Crovaxus
11. Kervyn
12. Wendigo
13. Korhil
14. Byro
15. Bogdan
16. Rogal
17. Afro
18. Lubin
19. Błażej
20. Rilam
21. Sowa
22. Pitul
23. BigPasiak
24. esgaroth
25. Sunil
26. Bladeweaver
27. Zręczny Krzyś
28. Mike
Ostatnio zmieniony 23 cze 2012, o 00:32 przez Michał, łącznie zmieniany 8 razy.
zapisz
Będę.
Metalowi quesci,
4ed rycerze na piechotę.
Snot Fanpage <<--- , klikać!
Metalowi quesci,
zapisz
Loki będzie?!
długo go już nie widziałem.. Pisz waść ;]
Fajnie, gdybyście wpadli. Weź Byro podpachę dostarczycieli punktów tj. Pasiak i Piotr i wpadajcieByro pisze:Wstępnie się piszę.
Jak nie dasz radu znowu to daj proszę info. prędzej, żebyśmy nie czekali z rozpoczęciem. Z góry dziękiLorens pisze:Zapisz
Ech... Z chęcią, ale nie dam rady... Raz, że w czerwcu mocno kiepsko mam z terminami [ już kiedyś tłumaczyłem, że to najgorszy miesiąc w roku bo mam tyle rocznic,urodzin i imienin, że pała mała i wyrwać wolny weekend ba choćby sobotę/niedzielę graniczy z cudem ]a dwa że jeszcze moi "pilnowacze" nie puszczą mnie tak chętnie tak daleko [ wiem że to kawałek jednak wyjaśnić to niektórym obecnie równa się z kolejnym cudem :/ ]... Przykro mi bo głodnym turniejów...Michał pisze:Fajnie, gdybyście wpadli. Weź Byro podpachę dostarczycieli punktów tj. Pasiak i Piotr i wpadajcieByro pisze:Wstępnie się piszę.![]()
Ostatnio zmieniony 10 cze 2012, o 19:39 przez bigpasiak, łącznie zmieniany 1 raz.
Abandoned
Abandoned
