"Pre-Kujawiak"
Turniej zgłoszony do ogólnopolskiej ligi WFB
Miejsce:Gimnazjum nr 2 przy ulicy Narbutta 65/71
Data: 02/03/2013
Zapisy startują o godzinie 9:15
Cena: 15zł od osoby
Zgłoszenia:
Będą przyjmowane do 28/02/13 do 23:59 na adres: nemezis.klub@gmail.com .
Poprawne zgłoszenie powinno zawierać Imie, Nazwisko, numer ID (ze strony ligii) gracza oraz rozpiskę w formacie txt, html lub pdf.
Za poprawne zgłoszenie w terminie gracz otrzyma +4DP do klasyfikacji końcowej.
Format:nowe EURO
Scenariusze: Bitwy 1-3 Battlelinenie skonczony i niepelny. Na pewno kilka rzeczy sie zmieni.Rules changes:
- Two characters per unit (owner's choice) will get "look out sir" versus the following spells that automatically kill models or automatically remove an entire regiment: Dwellers Below, Final Transmutation, Dreaded 13th, Infernal Gateway 11-12 effect. Normal requirements for lookout sir apply.
I. General Restrictions:
2400 Points.
Army used can be any of the currently published GW Army books. Forge World based army lists & units may not be used on the event, except for Chaos Dwarves.
An army may have up to 4 war machines and shooting template weapons. Warmachines that use a template count as a single choice in this regard. All template weapons (from magic items, abilities, etc.) count, except for spells. Bolt thr. count as ½ a war machine(round up).[s]Max. 45 models with missile weapons with a range of 20”+ (not incl. war machines, characters and chariots).
All BSBs can take all the Equipment, their unit type has acces to as if they weren't BSBs.[/s]
Magic Restrictions:
- No duplicate non-signature spells(not including bound spells) and max 2 Spirit Leech
- Player can use maximum 5 PD to cast a spell. For death & shadow spells this max is lowered to 4 power dice.
- An army may use up to 12 PD during each phase.
Detailed description
Apart from Winds of magic, an army may only use 2 PD/DD per magic phase (unless army restrictions specify otherwise). After an army generates the limit all the other extra dice are discarded. This includes channeled PD/DD.
Item restrictions:
Army Specific Restrictions:
Bretonnia
No Restrictions
Beastmen
Beastmen armies have an extra 250 points for their roster (2650 total)
All victory points scored against this army are decreased by 10% (excluding bonus points for banners, general, etc.)
Beastmen can generate 3 extra pd instead of 2
Tuskgor Chariots(not including character mounts), Ungor Raiders 0-4 each
A unit cap of 50 models per unit and point cap on units 550 instead of 450 pts.
Chaos Dwarfs
Hellcannon, Iron daemon are each 0-1.
Hobgoblin Khan 0-3
Lore of Hashut can be cast with max 4 PD.
Chalice or Sorcerer Prophet. Chalice of darkness counts as 2 pd
Iron daemon, K'daii destroyer, taur'ruk, count as war machines.
Max 3 out of Str. 5 shooting templates/Lore of death/Lore of Hashut.
[s]Daemon Flask of Ashak/Bale taurus, max 1 in total[/s]
Crown of Command on lord character/[s]Iron deamon[/s] K'daii, max 1 in total.
Daemons of Chaos
[s]Max. 30 Models per unit
All daemonic gifts are 0-1
Daemonic Battle Standard can have gifts if his magic banner does not cost over 50pts
Siren song cannot be taken by Herald of Slaanesh
Master of Sorcery: For Heralds of Tzeentch only it is a 0-2 gift and the Loremaster rule is removed; instead randomly determine spells (as a normal lvl 2) from any of the 8 rulebook lores.
Flyers 0-3
Soulgrinder 0-1
Bloodletter/Herald of Khorne max 4 in total[/s]
new book coming in 2nd draft
Dark Elves
[s]Reaper Bolt Throwers[/s], Harpies units are 0-2 each.
Dark riders 0-3
Hydra is a 0-1 choice.
flying characters 0-2
Max. 35 repeater Crossbows (excluding chariots & characters) in the army.
Shades max 20 models per army.
Pendant of Khaeleth cannot be taken by [s]lord characters[/s] dreadlord. and cannot be combined with crown of command on one model
Pendant of Khaeleth/Crown of command/Cauldron of Blood/Hydra max 2 in total
Sacrificial dagger/mage lord, max 2 in total
[s]Pegasus/mage lord/Standard of Discipline/Pendant of Khaeleth, max 3 in total[/s]
Assassins/Rending stars max 4 in total.
Dwarfs
Each spellbreaker/spelleater rune counts as +1 DD
Max 45 quarrelers/thunderers in total
Grudge Throwers are a 0-2 choice
May generate Max. +4 dispel dice instead of +2
Gyrocopter doesn't count for max 5 war machine/template.
Can have 5 war machines, anvil counts as 2.
The Empire
Knightly orders 0-3
Max 45 handgunners/crossbowmen in total
[s]Steam tank 0-1.[/s]
Demigryphs max [s]8[/s] 10models.
Cannon/Steam tank/[s]Standard of Discipline[/s] Demigryphs, max 4 in total.
Crown of Command/Steamtank, max 1 in total.
High Elves
High Elves armies have an extra 100 points for their roster (2500 total)
High elves army can generate extra 3 powerdice instead of 2
Vortex Shard counts as +1DD
Book of Hoeth counts as 3PD and 2 DD
Banner of the World Dragon counts as +1 DD
Lizardmen
Jungle swarm, Skinks <20, Skinks skirmish 0-3 each.
Salamanders are a 0-1
Scar-Veterans on cold ones 0-2,
Cogitations counts as +2DD
Cupped hands of the Old Ones +2PD
Dispel Scroll/Cube of darkness/1 or more slanns, max 2 in total.
Death lore/bane head/feedback scroll/Cupped hands of the Old Ones, max 1 in total.
Crown of Command/Standard of Discipline/Focused Rumination/Higher State of Consciousness/1 or more slanns, max 2 in total.
Skinks <20/Skink skirmirshers/Jungle swarms/Chameleon skinks/Terradons(not including character mounts)/Salamanders/Razordons/Slann, units are max 9 in total.
Ogre Kingdom
Dispel scroll/Hell heart, max 1 in total.
Hell heart count as 1 DD
Max 15 Leadbelchers/maneaters with pistols in total
Rune Maw Banner counts as 1dd.
Iron Blaster/Crown of Command, max 1 in total.
Slaughter master/Iron blaster/Standard of Discipline, max 2 in total.
[s]Each leadbelcher/sniper maneater with pistol(s) counts as 3 models towards to shooting cap.[/s]
Max 3 combined units of Mournfang Cav & Ironblaster.
Maximum of 8 Mournfang models
Orcs&Goblins
Night Goblin Shamans mushroom dice do not count as power dice in regard to the PD limit
Maximum model cap is 60 models per unit
Fanatics/Mangler squigs max 9
O&G have an extra 200 pts for their roster (2600 total), scores are NOT decreased by 10%
Skaven
Slaves 0-3
Rat Packs <20 0-2
All Skaven rare choices 0-1
Gutter runners are limited by 2 units & 20 models total
Engineers are a 0-3 choice
Screaming Bell/Second Grey Seer/Power scroll, max 1 in total.
Hellpit Abomination/Screaming Bell/2nd Assassin, max 2 in total
Doom Rocket/Brass Orb/Storm Banner max 2 in total
Tomb Kings
Tomb King armies have an extra 200 points for their roster (2600 total)
Neferra's Scrolls of Mighty Incantations counts as 2 PD and 2 DD
Hierotitan is worth 1 PD so long as it's alive
Skeleton Horsemen, Skeleton Horse archers, Chariots units are 0-3 each
Warsphinx/Necrosphinx max 3 in total
Tomb Kings may generate up to 3 power dice per phase
Vampire Counts
Zombies, Dire Wolfs units are 0-3 each
Master of Black Arts/Blasphemous Tome upgrade are 1pd each
Ethereal units 0-3, and max 2 of same kind/characters.
Howls/shrieks max 2 in total.
Flying units 0-4
Max 15 mounted characters and black knights combined
Vargheists max 8 models
Red Fury/Quick Blood/Terrorgheist/Necromancer Lord using death magic, max 2 in total.
Terrorgheist 0-1
Warriors of Chaos
[s]Hellcannon 0-1
Marauder Horsemen units are 0-3
Infernal Puppet counts as +1 PD and +2DD
Tendrils of Tzeench and Conjoined Homunculus both counts as +1 PD
If you have warriors, knights, and or chosen with marks of tzeentch in army then you can take max 2 out of 3 of warshrines and favor of the gods (2xwarshrines or warshrine and favor of the gods)
Maximum of 8 skullcrushers.[/s]
Core Chaos chariots, Marauder Horsemen, Warhounds are each 0-3
Hell Cannon 0-1
Talisman of Preservation/Armour of Destiny/Third eye of Tzeentch, max 1 on same model. (maybe unless it is a choas lord)
Flyers max 4, models with the regenerating flesh upgrade count as 2.
Flying Breath weapons count as 2 templates.
A model can have max 1 of Soul feeder/Fly
A Daemon Prince model can have max 4 of Scaly skin/Soul feeder/Chaos armour/Mark of Nurgle/Fly/Lvl1-2/Lvl3-4
Wood Elves
Wood Elf armies have an extra 200 points for their roster (2600 total)
Glade Riders, Scouts units are 0-3 each
Wood Elves may take a maximum of 70 models with a missile weapon instead of 45. Only Glade guards (including scouts) count for max of 70
[s] [/s] to rzeczy wykreslone
Pomalowanie armii i proxy:
Nie ma wymogu posiadania pomalowanej armii
Proxy dopuszczone w granicach przyzwoitości.
Ocena malowania: brak
Harmonogram czasowy:
09:15-09:30 - zapisy
9:30-12:30 - I bitwa
12:30-15:30 - II bitwa
15:30-18:30 - III bitwa
Progi:
0-150 - 10-10
151-300 - 11-9
301-450 - 12-8
451-600 - 13-7
601-750 - 14-6
751-900 – 15-5
901-1050 – 16-4
1051-1200 - 17-3
1201-1350 - 18-2
1351-1500 - 19-1
1500+ - 20-0
Uwagi ogólne:
- 20 punktów karnych za nieodniesienie stołu po ostatniej bitwie
- karniaki za spóźnianie się przy oddawaniu wyników - 5 minut, 1 karny, 10 minut - 2 karne, więcej 5 karnych.
- będą mapki na stołach i ponumerowane stoły
- na terenie szkoły obowiązuje ZAKAZ spożywania alkoholu
Zapraszamy!
