bard 20.04.2013 EURO KATOWICE
Moderatorzy: Laik, Dymitr
QQrydza
Post autor: QQrydza »
Termin: 20. 04. 2013
Czas na bitwy: 10-18
Miejsce: Bard Katowice
Format: 2400 Euro
Bitwy: 3x Battleline
Wstęp: 10 PLN
nagrody: Pula x2 w bonach do zrealizowania w sklepie i top3/top1 zależne od liczby osob
Hobbystyka: zgodnie z ustaleniami kierownictwa sklepu, które są dostępne na oficjalnej stronie Barda
Zapisy:
1. Qc
2. Robert Brzezina
3. Jankiel
4. Solo
5. Tomek Miszta
6. Domin
7. Bercik
8. Ethelite
9. Denis Seweryn
10. Ficu
11.
12.
13.
14.
15.
16.
Zasady:
Rules changes:
Two characters per unit (owner's choice) will get "look out sir" versus the following spells that automatically kill models or automatically remove an entire regiment: Dwellers Below, Final Transmutation, Dreaded 13th. Normal requirements for lookout sir apply.
I. General Restrictions:
Army used can be any of the currently published GW Army books. Forge World based army lists & units may not be used on the event, except for Chaos Dwarves.
An army may have up to 4 war machines and shooting template weapons. Warmachines that use a template count as a single choice in this regard. All template weapons (from magic items, abilities, etc.) count, except for spells. Bolt thr. count as ½ a war machine(round up).
All BSBs can take all the Equipment, their unit type has acces to as if they weren't BSBs.
Army sizes, additional power dice/dispel dice and VP reduction are represented as follows:
Army (Point size, additionl power dice/dispel dice, VP reduction, if any (excluding bonus points for banners, general, etc.))
Magic Restrictions:
No duplicate non-signature spells(not including bound spells) and max 2 Spirit Leech (Signature spells are spells you can swap other spells to)
- Apart from Winds of magic, an army may only use 2 power dice/DD per magic phase. After an army generates the limit all the other extra dice are discarded. This includes channeled power dice/dispel dice.
- Player can use maximum 5 power dice to cast a spell. For spells from Lore of Death/Lore of Shadow/Lore of Hashut this max is lowered to 4 power dice.
- An army may use up to 12 power dice during each phase.
- “Count as” items/abilities may never exceed a cumulative 2 power dice/dispel dice per phase. This means that player who already spent his limit power dice limit, cant take more items which “count as adding power dice” or add power dice from channeling during game (same for dispel dice).
Detailed description
Apart from Winds of magic, an army may only use 2 power dice/dispel dice per magic phase (unless army restrictions specify otherwise). After an army generates the limit all the other extra dice are discarded. This includes channeled power dice/dispel dice.
Item restrictions:
- Any item that auto-dispels a spell counts as generating 1 dispel dice each magic phase.
Bretonnia (2400p)
Dispel Scroll/The Silver Mirror, max 1
Beastmen (2650p, +1 Power Dice, -10%)
Tuskgor Chariots, Ungor Raiders 0-4 each
A unit cap of 50 models per unit and point cap on units 550 instead of 450 pts.
Chaos Dwarfs (2400p)
Hellcannon, Iron daemon are each 0-1
Hobgoblin Khan 0-3
Chalice or Sorcerer Prophet. Chalice of darkness counts as 2 power dice
Iron daemon, K'daii destroyer, Second taur'ruk, count as war machines
Magma Cannon/Hellcannon/Dreadquake Mortar/Prophet with Lore of Death/Hashut, max 3 in total
Crown of Command on mage/K'daii Destroyer, max 1 in total
Dark Elves (2400p)
Max. 35 repeater Crossbows (excluding chariots & characters) in the army
Harpies 0-2
Dark riders 0-3
Flying characters 0-2
Shades max 20 models
Pendant cannot be worn by a Dreadlord or models with Crown of command
Pendant of Khaeleth/Crown of command/Cauldron of Blood/Hydra max 2 in total
Sacrificial dagger/mage lord, max 2 in total
Assassins/Rending stars max 4 in total
Daemons of Chaos (2400p,+1 Dispel Dice)
Skull cannon 0-1
Flyers max 4 in total
The Rock of Inevitability cannot be taken
Dwarfs (2400, +2 Dispel Dice)
Max 45 Quarrelers/Thunderers in total
Grudge Throwers are a 0-2 choice
Gyrocopter doesn't count for max 5 war machine/template
Can have 5 war wachines, anvil counts as 2
Empire (2400p)
Max 45 handgunners/crossbowmen in total
Knightly orders 0-3
Demigryphs max 10 models
Cannon/Steam tank max 3 in total
Cannon/Steam tank/Demigryph unit, max 4 in total
Crown of Command/Steamtank, max 1 in total
High Elves (2500p,+1 Power Dice)
Vortex Shard counts as +1 dispel dice
Book of Hoeth counts as 3 power dice and 2 dispel dice
Banner of the World Dragon counts as +1 dispel dice
Lizardmen (2400p)
Jungle swarm, Skinks <20, Skinks skirmish 0-3 each
Salamanders are a 0-1
Scar-Veterans on coldone 0-2
Cogitations counts as +2 dispel dice
Cupped hands of the Old Ones +2 power dice
Scroll/Cube of darkness/1 or more slanns, max 2 in total
Death lore/bane head/feedback scroll/Cupped hands of the Old Ones, max 1 in total.
Crown of Comand/Standard of Discipline/Focused Rumination/Higher State of Consciusness/1 or more slanns, max 2 in total
Skinks <20/Skink skirmirshers/Jungle swarms/Chameleon skinks/Terradons/Salamanders/Razordons/Slann, units are max 9 in total
Ogre Kingdoms (2400p)
Max 15 Leadbelchers/maneaters with pistols in total
Gnoblars < 20 0-3
Dispell scroll/Hell heart, max 1 in total
Hell heart/Rune Maw Banner count as 1 dispel dice each
Iron Blaster/Crown of Command, max 1 in total
Slaugther master/Iron blaster/Standard of Discipline, max 2 in total
Max 8 Mournfang models
Orcs&Goblins (2600p)
Night Goblin Shamans mushroom dice do not count as power dice in regard to the power dice limit
Maximum model cap is 60 models per unit
Fanatics/Manglers max 9
Skaven (2400p)
Slaves/Rat Swarms are 0-3 each
Rat Packs <20 0-2
Hellpit Abomination, Warp-Lightning Cannon, Doomwheel 0-1 each
Gutter runners are limited to 2 units & max 20 models in total
Engineers are a 0-3 choice
Screaming Bell/Second Grey Seer/Power scroll, max 1 in total.
Hellpit Abomination/Screaming Bell/2nd Assassin, max 2 in total
Doom Rocket/Brass Orb/Storm Banner max 2 in total
Tomb Kings (2600p, +1 Power Dice, -10%)
Neferra's Scrolls of Mighty Incantations counts as 2 power dice and 2 dispel dice
Hierotitan is worth 1 power dice so long as it's alive
Skeleton Horsemen, Skeleton Horse archers, Chariots units are 0-3 each
Warsphinx/Necrosphinx max 3 in total
Vampire Counts (2400p)
Zombies, Dire Wolfs units are 0-3 each
Flying units 0-4
Vargheists max 8 models
Ethereal units 0-3, and max 2 of same kind/characters
Terrorgheist 0-1
Howls/shrieks max 2 in total
Red Fury/Quick Blood/Terrorgheist/Necromancer Lord/Vampire Lord, max 3 in total
Max 15 mounted characters and black knights combined
Master of Black Arts/Blasphemous Tome upgrade are 1pd each
Warriors of Chaos (2400p)
Core Chaos chariots, Marauder Horsemen, Warhounds are each 0-3
Hell Cannon 0-1
Model with 3+ ward cannot have Crown of Command
Talisman of Preservation/Armour of Destiny/Third eye of Tzeentch, max 1 on same model
A Daemon Prince model can have max 4 of Scaly skin/Soul feeder/Chaos armour/Mark of Nurgle/Fly/Lvl1-2/Lvl3-4
Flyers 0-4, models with the regenerating flesh upgrade count as 2
Flyers with Breath weapons count as 2 templates
Wood Elves (2600p, -10%)
Max 70 glade guard
Max 5 Glade guard units
Glade Riders, Scouts units are 0-3 each
_________________
QQrydza
Jakby komuś umknęły:
Zapisy:
1. Qc
2. Robert Brzezina
3. Jankiel
4. Solo
5. Tomek Miszta
6. Domin
7. Bercik
8. Ethelite
9. Denis Seweryn
10. Ficu
11.
12.
13.
14.
15.
16.
Numer turnieju w lidze 3093
http://ranking.wfb-pol.org/n_turnieje.php
Solo
Post autor: Solo »
Jeśli interesuje Cię wielka rywalizacja z najlepszymi graczami z całego Śląska, bądź .
Jeśli lubisz dobry klimat i chcesz na jeden dzień tygodnia oderwać się od życia codziennego przesiąknąć klimatem tej gry, bądź .
Jeśli cieszysz się na spotkanie z najfajniejszymi kolegami jakich masz lub będziesz miał, bądź .
Jeśli chcesz ogrzać się ciepłem najjaśniejszego z jasnych klubów w Polsce, bądź .
To nie jest oferta dla każdego jest tylko i wyłącznie dla Ciebie, więc przyjacielu jeśli nie wiesz co myśleć nie myśl po prostu, bądź.
Pozdrawiam i zapraszam.
Solo
Golonka
Post autor: Golonka »
Będę cwaniaki :D
Furion pisze:
@nders9 pisze:
No, becouse no.
PiotrB
Maruda
Post autor: PiotrB »
niezła reklama :) poza tym najjaśniejszym - 6 tym na Dmś klubem :mrgreen: .... a tak poważnie to niestety dla mnie Bard jest zamknięty :)... więc odpadam :(...ale namówię chłopaków...
QQrydza
PiotrB pisze:niezła reklama :) poza tym najjaśniejszym.
Solowi chodzilo o transparentnosc i uczciwosc przy stole ; )
Dydu
Post autor: Dydu »
Jako, że bielsko nie wypalilo, a do katowic chyba tylko Kosa chce jechac, to mam 2-3 wolne miejsca w samochodzie
PiotrB
Maruda
nom - tak jak mówiłem - Bard nie dla mnie - trzymam kciuki za Dyda i Kosę !
