EDIT: nazwę tematu wrzuciłem bardziej ogólną i poniżej z army buildera czary
#Attr - Raise the Dead Place a Raise Dead counter on the battlefield. Friendly Wizard that subsequently casts summoning spell from Lore of Undeath can choose to expend one or more of you counters to increase points of summoned unit by +10 per counter
#Un0 - Ryze - The Grave Call Signature Spell. Summoning. 9+ to Cast. Range 12". Summon Undead Legions infantry unit worth up to 50 points. OR 14+ to Cast, summon 100 points of infantry. OR 16+ to Cast, summon 150 points of Monstrous Infantry.
#Un1 - Morkharn - Breath of Darkness Augment. 6+ to Cast. Range 12". Friendly Undead unit regains D3+1 Wounds. In addition, if the unit is unengaged it may make a normal move as if it were a Remaining Moves sub-phase.
#Un2 - Sulekhim - The Hand of Dust Augment. 7+ to Cast. Targets caster. In close combat caster may exchange all of his normal attacks into a single one. If this attack hits, target suffers a Wound with Multiple Wounds (D6) and no armour saves. If this attack slays enemy character in challenge immediately gain D6 RtD counters.
#Un3 - Khizzar - The Soul Stealer Direct damage. 8+ to Cast. Range 12". Roll 2D6+2, for each point the result exceeds target's Ld, enemy suffers 1 Wound with no armour saves. If at least 1 Wound is caused gain D3 RtD counters.
#Un4 - Razkhar - The Abyssal Swarm Summoning. 10+ to Cast. Range 12". Summon Undead Legions War Beast or Swarm unit worth up to 75 points. OR 16+ to Cast, summon 150 points of Monstrous Beasts.
#Un5 - Kandorak - The Harbringer Summoning. 10+ to Cast. Range 12". Summon Undead Legions character worth up to 65 points. OR 24+ to Cast, summon single Monster, Chariot or War Machine worth up to 200 points.
#Un6 - Akar'aran - The Dark Riders Summoning. 16+ to Cast. Range 12". Summon Undead Legions Cavalry, Monstrous Cavalry or Chariots worth up to 150 points.
