Salamandrowy Draft - Włocławek [10-01-2015] 2400 single
Moderatorzy: Laik, Dymitr
Heptun
Post autor: Heptun »
Włocławski Klub Gier Bitewnych "SALAMANDRA"
ma zaszczyt zaprosić na turniej organizowany w budynku Włocławskiego Centrum Kultury.
Dojazd:
- jadąc od strony Torunia, Gdańska, Bydgoszczy wypatrujemy po prawej stronie piętrowego budynku (na parterze Biedronka, na piętrze WCK),
- jadąc od Warszawy, Poznania czy Łodzi kierujemy się drogą nr 1/E75 na Toruń/Gdańsk i mamy WCK po lewej stronie;
Poza tym wszyscy co byli na masterze Kujawiak trafią z pewnością :)
Miejsce: http://www.wckwloclawek.pl/index.php,
Włocławskie Centrum Kultury,
ul. Toruńska 87,
87-800 Włocławek
Data: 10. 01 (stycznia). 2015 (sobota)
Format i zasady:
kudłaty pisze:
Kod: Zaznacz cały
ETC 2015 - Army Restrictions
Version - 2.0
Status - Draft
Army Building Restrictions
General Restrictions
All the Army building restrictions are applied only during the creation of the roster, and may be ignored during the game (for example, by joining characters to units or creating new units).
The army lists allowed are those from any of the currently published GW Army Books, and
The Legion of Azgorh from Tamurkhan.
Undead Legions, the Legions of Chaos and any other End Times army lists are not allowed.
Special or Named Characters that appear in army books are allowed ­ this excludes all
characters that appear in End Times books and /or battlescrolls or that initially appeared in
White Dwarf but were then included in End Times Books.
Fozzrik’s Folding Fortress may not be taken.
Units cannot be more than 450 points at the point of roster creation. This does not apply to
characters.
All army sizes are 2400 points unless stated otherwise in race specific composition below.
Armies must be constructed on the following basis (in addition to any specific conditions
imposed by their army book)
● Minimum of 3 units
● Minimum of 1 character that can be the army general
● Maximum of 50% of points spent on lords
● Maximum of 50% of points spent on heroes
● Minimum of 25% of points spent on core units
● Maximum of 50% of points spent on special units
● Maximum of 25% of points spent on rare choices
A team consists of 8 players, each of which with an army from a different army list.
A wizard generating spells from lore of death and the Standard of Discipline are mutually
exclusive in any army list at the start of the game (I.e. It is permissible to summon a character
on lore of death using the lore of Undeath if you have a standard of discipline already in the
list)
Generic pool choicesThe following pool choices apply to all armies with the exception of Orcs and Tomb Kings(as
they have no pools)
● If the total points spent on all lords and heroes is greater than 50% of the armies
points ­ 1 pool choice
● If the total points spent on all lords and heroes is greater than 60% of the armies
points ­ 1 further pool choice
Beastmen
Maximum unit size at roster creation excluding characters is increased to 550 points.
May take Blight Kings of Nurgle from Warhammer End Times ­ Glotkin
May select up to 5 choices from the pool below:
● Extra 75 points ­ 1 choices (up to +300 points maximum),
● May take marks for all units that can do it in Glotkin book ­ 1 choice
● Slugtongue ­ 1 choice
Note that the Marks of Tzeentch, Nurgle and Slaanesh DO NOT allow wizards access to the
corresponding lore from the Warriors of Chaos Book. Wizards with a mark have access to the
same lores of magic as unmarked beastmen wizards (Shadow, Beasts, Death, Beastmen)
May take any beastmen special characters.
Bretonnia
May select up to 2 choices from the pool below:
● Extra 100 points ­ 1 choices (up to +100 points maximum),
● The Green Knight ­ 1 choice
May take any Brettonian special characters.
Chaos Dwarves
● Each character using the Lore of Death – 1 choice
● Each HellCannon ­ 1 choice (3 choices with lore of death)
● K'daai Destroyer – 2 choices
● Each DeathShrieker, Magma Cannon, Dreadquake Mortar or Iron Demon – 1 choice
● Each 2(or part thereof) hobgoblin khans after the first 2 ­ 1 choice
● Chalice of Blood and Darkness (may be used only before casting a spell) ­ 1 choice
May take any Chaos Dwarf special characters.
Dark Elves
● Each character using the Lore of Death – 2 choices
● Each 5(or part of 5) Doomfire Warlock models – 1 choice
● Each mounted dreadlord or master – 1 choice
● One or more repeater bolt throwers– 1 choice
● Each unit of dark riders after the second ­ 1 choice
● Crown of Command – 1 choice
● More than 80 shots from repeater crossbows per turn (Repeater bolt throwers count as
6 shots) ­ 2 choices
● Morathi ­ 4 choices (Lore of Death choice is included)
● Malekith ­ 2 Choices (3 choices if mounted)
May take any Dark Elf special characters.
Demons of Chaos
May take Blight Kings of Nurgle from Warhammer End Times ­ Glotkin­ these models are not
demonic and therefore may not be joined by any model with the demonic special rule. If the
general and / or BSB have the mark of Nurgle they may benefit from them.
May take Exalted Flamers
May select up to 4 choices from the pool below:
● Lore of Death present in the army – 2 choices (irrespective of the number of users of
the lore of death)
● First Skull Cannon – 1 choice
● Second Skull Cannon – 3 choices
● Each Greater demon(Including Skarbrand, Ku’gath) – 1 choice
● Each unit of Pink Horrors after the second – 1 choice
● Each unit of Plague Flies – 1 choice
● Up to 2/6/10 beasts of nurgle in the army ­ 1/2/3 choices
● Kairos Fateweaver ­ 4 choices (includes the cost of lore of death)
● Epidemius ­ 1 choice + 1 choice per unit (excluding Heralds of Nurgle ) of demons of
nurgle.
May take any Demons of Chaos special characters.
Dwarves
May select up to 5 choices from the pool below:● Each Cannon, Organ gun, Grudge Thrower or Flame cannon ­ 1 choice each
● Each 2 (or part thereof) gyrocopters after the first ­ 1 choice
● Grimm Burloksson ­ 1 choice
May take any Dwarf special characters.
Empire
● Steam Tank – 1 choice
● Second Steam Tank – 4 choices
● Crown of Command, Standard of Discipline, War altar, Great Cannon – 1 choice each
● Third Great Cannon – 1 additional choice
● 3 or more wizards using the Lore of Light ­ 1 choice
● Each unit of 4 or less Demi­Griffons – 1 choice
● Each unit of 5 or more Demi­Griffons – 2 choices
● Balthasar Gelt ­ 1 choice
● Karl Franz ­ 1 choice
May take any Empire special characters.
High Elves
● Banner of the World Dragon ­ 3 choices
● Each frostheart Phoenix ­ 1 choice
● 3 or more mounted characters ­ 1 choice
● 1 or more characters generating spells from lore of death ­ 1 choice
● 1 or more bolt throwers ­ 1 choice
● Each flying strength 6 or greater large target after the second ­ 2 choices
● Teclis ­ 5 choices (Lore of Death if taken is included in this cost)
● Alarielle ­ 2 choices
● Banner of Averlorn ­ 1 choice
May take any High Elf special characters.
Lizardmen
● Slann Mage Priest – 1 choice
● Discipline of Harmonic Convergence – 1 choice● Slann Mage Priest taking the Lore of Death – 1 choice (Slann Mage Priests with the
Wandering Deliberations do not count towards this)
● Each cold­one mounted saurus character after the first – 2 choices
● Each flying unit/character after the third – 1 choice
● Each unit of core skirmishers after the third ­ 1 choice
● Each skink cohort after the third ­ 1 choice
● Lord Kroak ­ 2 choices (includes 1 for being a Slann Mage Priest)
● Tetto’Eko ­ 3 choices
May take any Lizardmen special characters
Orcs and Goblins
Army size is increased to 2500 points
May take any Orcs and Goblins Special Characters
Ogres
● Ironblaster ­ 1 choice (second 4 choices)
● Hellheart ­ 2 choices
● Crown of command ­ 2 choices
● Runemaw ­ 1 choice
● 1 or more Slaughtermasters in the army including Skragg ­ 1 choices
● Each unit of gnoblars after the third ­ 1 choice
May take any Ogres Special Characters
Skaven
Slave units can be a maximum of 60 models.
● Each Warp­lightning Cannon ­ 1 choice
● Each doomwheel ­­ 1 choice
● First Hellpit Abomination ­ 1 choice
● Second Hellpit Abomination ­ 2 choices.
● Stormbanner ­ 1 choice (2 choices with double hellpit Abomination)
● Each non wizard warplock Engineer after the first ­ 1 choice
● Each 40 slaves (or part thereof) over 120 slave models ­ 1 choice● Each 2 slave units(or part thereof) after the third ­ 1 choice
● 15 or more gutter runners ­ 1 choice
Note ­ The rumoured new Skaven end time units below will be allowed but may cost one or
more pool choices.
● Vermin Lords
● Armoured Rat Ogres
The rumoured new Vermin Lord will not be allowed as he is an End Times Special character
and is by the vote expressely forbidden.
May take any Skaven Special Characters
Tomb Kings
Army size is increased to 2700 points.
Army does not crumble upon the death of the Hierophant
May include the following units from Warhammer End Times – Nagash
● Morghast Harbingers
● Morghast Archai
May add up to 3 power dice to the pool instead of 2 if an army does not include Arkhan
May take any Tomb Kings Special Characters
Vampire Counts
● Morghast Archai
● Terrorgheist – 1 choice
● 2nd Terrorgheist – 3 choices
● Each character with Red Fury and/or Quickblood – 1 choice
● Each character using the Lore of Death ­ 1 choice
● Each ethereal character or unit – 1 choice
● Each unit of hexwraith after the 1st ­ 1 choice● Each banshee howl or terrorgheist death shriek after the first – 1 choice
● More than 10 crypt horrors in the army ­ 1 choice
● Each Direwolf and / or Fellbat unit after the fourth ­ 1 choice
● Count Mannfred ­ 2 choices (including death)
May take any Vampire Counts Special Characters
Warriors of Chaos
May take Blight Kings of Nurgle from Warhammer End Times – Glotkin
● Each character using the Lore of Death – 1 choice (2 choices if it is a deamon prince)
● Each Demon Prince after the first – 1 choice
● 2+ or better save on a Demon Prince ­ 1 choice
● Each Demon Prince with Mark of Nurgle – 1 choice
● Exalted hero mounted on a demonic mount – 1 choice
● Model with a 3+ ward save and the third eye of tzeentch ­ 2 choices
● HellCannon – 1 choice (2 with lore of death or tzeentch)
● 2nd HellCannon – 2 choices (3 with lore of death or tzeentch)
● Each Chimera – 1 choice
● Each unit of Skullcrushers after the first – 1 choice
● Each Core chariot after the second – 1 choice
● Each flying model after the second ­ 1 choice
● Archaon ­ 2 choices
● Galrauch ­ 1 choice
● Throgg ­ 3 choices
● Crown of Command ­ 1 choice
May take any Warriors of Chaos Special Characters
Wood Elves
All limits are about models, you can spread them anyway you like among units, unless
otherwise specified.
● Each character using the Lore of Death – 1 choice (3 choices if 6 or more sisters of the
thorn are present in an army)
● Each unit of Wild Riders after the first – 1 choice
● Each 10 Waywatchers (or part thereof) ­ 1 choice
● Each 15 models (or part thereof) equipped with trueflight arrows or hagbane arrows
after the first 15 models ­ 1 choice● Each Waystalker after the first – 1 choice
● Moonstone of the Hidden Ways – 2 choices (4 choices with lore of death)
● Sisters of Twilight ­ 2 choices
May take any Wood Elf Special Characters
Gdyby były jakieś pytania to najlepiej pytać w tym wątku z draftem :)
-> dopuszczamy proksowanie figurasków w ramach przyzwoitości tzn. - nie ma samych podstawek czy kartoników; piechota=piechota, kawaleria=kawaleria
jak nie masz figsów napisz - pożyczymy coś :mrgreen:
Bitwy: 3
I Bitwa - Battleline
II Bitwa - Blood & Glory
III Bitwa - Battleline
Wjazd: 10 zł/osoby (chociaż wprowadzili nam czynsz za wynajem więc zastanowimy się nad podwyżką w przyszłości)
Nagrody:
- na 100% macie od nas dyplomy i punkty do ligi :mrgreen:,
- dodatkowo drobne upominki od Księgarnia Gdańscy - Wszystko dla ucznia; ul. Promienna 1b, 87-800 Włocławek
Zgłoszenia:
Zgłoszenia proszę wysyłać na adres wpierzchalski@tophost.pl
Poprawne zgłoszenie powinno zawierać: imię, nazwisko, ID*, armię, rozpiskę w formacie html
Wysłanie poprawnego zgłoszenia do 08.01.2015 do 23.59 (czwartek o północy) premiowane jest dodatkowymi 2 dużymi punktami do klasyfikacji generalnej (jest dużo czasu więc bądźcie punktualni byśmy nie musieli się kłocić :)).
*ID ze strony Ligi WFB: http://ranking.wfb-pol.org/players.php
Ocena malarska:
Jak zwykle wprowadzamy ocenę malarsko-hobbystyczną - do zdobycia będzie 5 DP do klasyfikacji ogólnej.
Oceną zajmą się muchozol oraz dany. Szczegóły wkrótce.
Limit miejsc: 40
Skład sędziowski:
główny - na pewno jakiś rozgarnięty z sali :) - ewentualnie ja służę pomocą;
boczny w sprawach błahych - Heptun
techniczno-organizacyjny - Heptun
malarsko-hobbystyczny - muchozol/dany
Rozkład jazdy:
08:45 - 9:15 Zapisy
09.20 - 12.00 I Bitwa - losowanie scenarios
12.05 - 14.45 II Bitwa - losowanie scenarios
15.00 - 17:40 III Bitwa - losowanie scenarios
18.00 - wręczanie dyplomów i ogłoszenie wyników
Ostatnio zmieniony 9 sty 2015, o 00:39 przez Heptun, łącznie zmieniany 3 razy.
:twisted: Klub Gier Bitewnych SALAMANDRA - Włocławek :twisted:
Heptun
Lista uczestników:
1. Muchozol DE (R)
2. Katerek OG (R)
3. Fumijako WOC (R)
4. Byro EMP (R)
5. Tapio DE (R)
6. Nargh OG (R)
7. Rollnik DF (R)
8. Pysiek DF (R)
9. Pająk OK (R)
10. Jagal BRE (R)
11. Młody Szkapa EMP (R)
12. Marvin WOC (R)
13. Bila DE (R)
14. Beszcza TK (R)
15. Muody WOC (R)
16. Urban WE (R)
17. Żero "Silvermen" TK (R)
18.
19. Helsing VC (R)
20. Michał Salamon DOC (R)
21. Azurix HE (R)
22. Kard VC (R)
23. S.Dziembowski DOC (R)
24. Krzychoss DE (R)
25. Sandra HE (R)
Ostatnio zmieniony 9 sty 2015, o 16:37 przez Heptun, łącznie zmieniany 10 razy.
Ziemko
Lex Luthor
Post autor: Ziemko »
Moze wpadne, choc od wyjscia dodatku do undeadow troche jestem zniesmaczony wfb.
Heptun
Można strajkować, ale pewnie i tak trzeba będzie jakoś do tego przywyknąć. Zostaje jeszcze zmiana systemu :)
Ziemko
Lex Luthor
Majac tak duza armie systemu na pewno nie zmienie :) Najwyzej bede rzadziej gral.
Jagal
Post autor: Jagal »
8 miejsc dla trójmiasta! :mrgreen:
Metalowi quesci,
4ed rycerze na piechotę.
Heptun
Fajnie będzie zobaczyć w nowym roku Wasze mordki znowu. Ubolewam nad IMP-em :( lecz niestety nie dałem rady (a szykuje się fajny tur jak zwykle).
Nijlor
Post autor: Nijlor »
Dopisz i mnie :)
bigpasiak
Post autor: bigpasiak »
Heptun pisze: Bitwy: 3
Nie powinno to być jak w drafcie...?
Znaczy losowe...?
Abandoned
Pedrodilgur
Post autor: Pedrodilgur »
Będę.
krzychoss
Post autor: krzychoss »
bigpasiak pisze:
Znaczy losowe...?
Wybór scenariuszy jest mega fajny można dopasować rozpę pod konkretne ale trzeba brać pod uwagę że ktoś to zauważy i weźmie "nie ten co trzeba":P
Od nas myślę samochodzik pełny się pojawi po prostu, chciałbym żeby dwa były ale to zależy od chłopaków :D
Heptun
bigpasiak pisze:
Znaczy losowe...?
No właśnie chyba trzeba będzie jakoś tak zrobić. Muszę to ogarnąć lub napiszę do Ciebie PM to mi podpowiesz :)
Byro
Post autor: Byro »
Nic jeszcze nie obiecuję, ale..... wstępnie zapiszcie.
Caledor Trzeci
Warzywo
Post autor: Caledor Trzeci »
Będę, jedyne wydarzenie jakie może mnie powstrzymać przed przyjazdem, to całkowite zniszczenie trasy TORUŃ-WŁOCŁAWEK :)
Nie wiem w tej chwili jak reszta ekipy z Chełmży, więc nie deklarujemy się, że przyjedzie pełny samochód :)
Gdy ogień wojny rozbłyśnie znów, w tym ogniu będę stał.
High Elves 2014 W/D/L/-3/5/4
Hoops
Post autor: Hoops »
Heptun Ośmiornica już grzeje furę :P Weź pan tam klepnij więc na wstępie 5 osób.
Fajnie że robicie 10ego bo my się zasadzamy na 17 lub 18 ego więc mamy dwa turnieje już na styczeń zaplanowane :)
Heptun
No to super. Już zapisuje i planujemy rewizytę :)
krzychoss
kurde za dużo tych fajnych ośrodków robi turnieje w styczniu;p My też będziemy robić 17.01 albo 24.01
Pacek
Post autor: Pacek »
zapiszcie
The messanger bowed low. "Speak-speak" snarled the Grey Seer, to agitated to appreciate the fawning. "Unexpected complications, most powerful of the potentates" said the Scurrier. Before the creature finish,Grey Seer sent bolt of lightning to roast him alive."Bad news can always wait" thougt the mage..
Afro
Post autor: Afro »
a co mi tam, nowy rok, więc wstępnie piszcie :D (o ile znajdzie się od nas lud z transportem)
Heptun
krzychoss pisze:kurde za dużo tych fajnych ośrodków robi turnieje w styczniu;p My też będziemy robić 17.01 albo 24.01
To jak już to 24.01 (jak dla mnie) gdyż 17.01 przynajmniej ja nie mogę z Salamandry. Jakoś pewnie będzie trzeba się podzielić i wybrać :)
