zasady te co zawsze
These restrictions are lifted for any units that share the same Mark of the Daemon Legion as the general. These restrictions do not apply to units with Mark of the Daemon Legion (Unbound) or to armies lead by Unbound Generals.
Haga na kotle to jeden model, znaczy witchki mogą uderzyć w challenge jako że nie są "other model"?If the Challenge was accepted, the Character or Champion issuing the Challenge and the Character or Champion
that answered the Challenge count as being in base contact with each other (even if their bases are not
physically touching each other) and must allocate all their attacks towards each other. Special attacks made
towards Units (such as Stomps, Breath Weapons, Impact Hits, Grinding Attacks) are always allocated to the
opposing Character or Champion (in the case of Stomps, the opposing character must be of a stompable Troop
Type, otherwise the Stomp attacks are lost). No other models can allocate attacks at either of these models and
attacks/hits can never be allocated onto a Character or a Champion in a Challenge. If a character with more than
one Initiative value (such as a rider and its mount or a model with Stomp) kills its opponent before it has made
all of its attacks, any of the remaining attacks can be directed at the killed model (as if it was still alive and in
base contact) in order to get an Overkill bonus.
Niekoniecznie, ale warto, gdy chcesz mieć mono-armię.Shino pisze:tak. chodzilo mi o sytuacje gdzie wszystkie 3 maja marki. jak furie maja 7ld to warto im juz jakis mark dawac. Niekoniecznie ten ,ktory ma general.
Pytanko - czy wystarczy żeby sztandarowy był jednym z szarżujących, czy też przeciwnik musi odpowiedzieć Hold na jego szarżę, ale jeśli potem zadeklarujemy kolejną kimś innym to może już uciec?Banner of Temptation 30 pts- Requires Mark of Lust
When a unit is charged by the bearer of this banner, they
may only declare Hold as their Charge reaction unless
they are already Fleeing.
W 8ed nie mógł latać gdy jego oddział nie latał, musiał używać ruchu pieszego.Crusader pisze:Czy jest jakaś zasada zakazująca dołączania do flyerów np. harpii? I nie mówię tylko o latającym herosie, ale również pieszym. I czy jeśli on ma więcej ruchu naziemnego niż unit to czy ten unit może używać latania, aby go podgonić?
W 8ed heros mogl latac w oddziale w koncu
