Ucieczka przed szarżą i ruch goniących
galahar
Post autor: galahar »
Mam jeszcze jeden problem :)
Lanca szarżuje w skinki. Mógłby ktoś narysować jak dokładnie wygląda ruch uciekających skinków i goniących rycerzy. Albo łopatologicznie wyjaśnić, lub jeśli podobny temat istniał to moze zarzucić linkiem?
Jedy Knight
Forma Skrótowa
Post autor: Jedy Knight »
Str 4 Erraty
http://us.games-workshop.com/errata/ass ... v7_faq.pdf
Q. How do skirmishers flee exactly (this may be
important for determining if they have to flee through
enemies or impassable terrain)?
A. If the skirmishers are fleeing from a combat the
situation is easy, as they are treated exactly as a normal
ranked up unit.
If they aren't, the situation may get a bit more
complicated. First, the closest visible skirmisher flees
directly away from the centre of the charging unit by the
distance rolled. Then, every other fleeing skirmisher is
moved by the same distance along the same (parallel)
direction as the first, trying to keep the skirmishing unit
as much as possible in the same formation, as shown in
the diagram below.
galahar
No to teraz wszystko jasne. Dzięki :D
