Army List Dogs of War
Regiments of Renown
FAQ Dogs of War
Lista jednostek Dogs of War, które ukazały się w magazynie White Dwraf i innych publikacjach Games Workshop:
Anaconda's Amazons - WD 308(UK)
Amazon Serpent Priestesses - WD 307 (UK)
Gnoblar Manbiters - WD 310 (UK), jednostka z armii Gnoblar Horde
Gotrek i Feliks
Ice Trolls - WD 287(US)
Jednostki Albionu (Dark Emissary, Truthsayer, Fenbeast - Kampania Dark Shadows
Malakai Makainson Goblin Hewer - Kampania Storm of Chaos; Slayers Army
Mengil`s Manflayers - WD 296(US)
Rhinox Cavalery - WD 309(UK)
Stirgit 's Wooda Gobba's - WD 310 (UK)
Torston Treehaka's Sea Axes - WD 307 (UK)
Witch Hunters - WD 257
Zombie Pirates - Conquest of the New World
Bohaterowie specjalni Dogs of War z Warhammer Chronicles 2003:
http://img454.imageshack.us/img454/1012 ... ar1ps2.jpg
http://img20.imageshack.us/img20/406/do ... ar2vk0.jpg
http://img252.imageshack.us/img252/8386 ... ar3fl7.jpg
http://img252.imageshack.us/img252/3171 ... ar4cf9.jpg
Oryginalna wersja włoskiej kampanii DoW w języku włoskim
Magiczne przedmioty DoW z włoskiej kampanii:
- Brace of Pistols of Sartosa, 25 points (Magic Weapon) - Counts as a Brace of Pistols. The bearer may re-roll to-wound rolls. His ranged and close combat attacks count as magic.
Pike of Remas, 25 points (Magic Weapon) - Counts as a Tilean pike. Bearer has +1 Strength. Mounted enemies (horse, chariot or monster) cannot voluntarily charge if they would contact in Base to Base the bearer of the Pike.
Great Armour of Miragliano, 25 points (Magic Armour) - Only characters on foot. Gives the wearer a 4+ armour save and a 5+ ward save. The Great Armour is so heavy that the wearer has -1 Movement and -3 Initiative, and may not use weapons that require two hands.
Bright Helm of Myrmidia, 20 points (Magic Armour) - The Helm gives a 6+ armour save, and may be worn in addition to normal armour. Enemies in base to base contact suffer -2 WS. Wearer hates all models in a Tomb King army.
Crown of Luccini, 25 points (Enchanted Item) - Mercenary General only, +1 Leadership. If the wearer is the general, troops within 12" can use his modified leadership. If the wearer is killed, enemy gets +100 VP.
Estalian Cloak, 20 points (Talisman) - Bearer and his unit gets Magic Resistance (1).
Staff of Lightnings, 25 points (Arcane Item) - Bound Spell, Power Level 5. Contains a spell that, if not dispelled, generates a magic missile with a 24" range, that causes D3+1 Strength 6 hits, and a single Strength 4 hit to the bearer. After every use roll a die. With a result of 1, the staff loses temporarily his powers, and may not be used for the rest of
the battle.
Book of the Mage, 20 points (Arcane Item) - The mage knows another spell, randomly generated from one of the remaining 7 lores. The lore is chosen by the bearer.
Banner of Steel, 10 pts (Magic Banner) - Declare that you are using the powers of the banner at the start of any turn, yours or enemy's. The unit gets +1 Armour Save until the end of turn. One use only
http://www.solegends.com/index.htm
Posiadam jeszcze PDFy z fluffem do gigantów z Albionu, halflingów Lumpina, Tichi i kolegów oraz hobgoblinów Ghazaka Khana. Jeśli ktoś jest zainteresowany to mogę przesłać mailem.
