Plotki na temat army booka do 7. edycji
Moderator: Yudokuno
Może i jest silniejszy (Królestwa Magii czytałem jakiś czas temu i nie pamiętam dokładnie), ale niech ma to jakieś odzwierciedlenie w WFB, tylko jeśli jest bardziej ryzykowny w użytku to żebyśmy nie dostali jakiejś wrednej dodatkowej tabeli miscastów.
a ja czesto uzywam lorda z szadołem i 5 czarami + 3 stony (darkstarcloak) i to czesto na czym latajacym + 2 malych i tez szadoł + jeden zia walczacy i popychaczki na niego albo lot 3 razy, cos wchodzi
Te poswiecenie jednostki brzmi super!Heard an employee discussing this today at local GW store.
DE wizards that accompany a unit may sacrifice a model to roll an extra die AFTER they've rolled to cast a spell. Wether this applies to only warriors or any unit is unknown.
He mentioned poisoned blades for the army, but that seems a little drastic. Then again, so did the strike first rule for HE.
Oh yea, DE to hit in September. Kinda important, almost forgot that one!
iWell the latest rumor is that they do get Hatred towards everything, Eternal Hatred vs High Elves and Always Fight at Initiative, regardless who is charging.
It does not override ASF. So it is in a way like ASF against most armies.
I like that combo. Works well with the fluff. To just get Hatred is too dangerous for a fragile expensive race. AFI helps a bit...
a pisal to "benmannen", uzytkownik TWF.Secret reliable source
AFI wouldn't help vs High Elves, they would go first with their ASF. But DE would have hatred to help out the few attackers that survive HE attacks.
I heard rumors too about 1 or 2 new troop types. Which seems to be in line with what all the new Army books are getting.
I just wish they could fix the Cold One Knights. Either make them a lot cheaper, give them LD 10 or something. They also need to get the Xbow option back... Or free Xbows for the same point cost.
Jesli to prawda ( a benmannen raczej do powazanych czlonkow forum sie zalicza) to byloby wesolo!
Oj bardzo wesolo, poswiecanie modeli brzmi swietnie i wydaje sie byc calkiem klimatyczne. Natomiast AFI srednio mi sie podoba, ale przynajmniej brzmi fajnie - Afi
Nie moge sie juz doczekac
- Murmandamus
AFI na dobrą sprawę to ASF z wyłączeniem helfów jako przeciwnika.
podstawowe jednostki i5 elity niektóre nawet 6. Mało co ma tyle nie mówiąc już o bohaterach. W połączeniu z hatem i możliwym piercingiem to może być mordercze. Poświęcanie to coś charakterystcznego i podoba mi się.
mnie sie wydaje ze to bedzie armia ok tak jak vc, naczytalem sie kiedys o drowach i biorac do reki kodeks srogo sie zawiodlem no ale teraz sie moze odmienic, zawsze po inicjatywie, nienawisc + sporo atakow (nawet z niska sila) jakeis zatrute rzeczy wszystko pasuje do klimatu (tylko szkoda ze nie ma wiezniow zadnych).
tak stanowczo oddzial slavow by sie przydal staty mniej wiecej bym im dal takie: mv4 ws2 s3 t3 i2 ld5 kosztowal by taki koles ok 3 pkt. Do tego brak mozliwosci wlkadania bohaterow to tego oddzialu, nie kozystaja z ld generala, brak muzyka i sztandaru (czempionem moze byc jakis poganiacz) i zeby nie panikowaly jednostek delfickich.
zgadzam sie tym co powiedziales ale z jednym wyjatkiem mv5 slavy nie moga spowalniac reszty armi bo przeciez jak taki niewolnik bedzie lazl wolno to napewno padnie od jakiegos miecza lub od belta z kuszy DESexRocket pisze:tak stanowczo oddzial slavow by sie przydal staty mniej wiecej bym im dal takie: mv4 ws2 s3 t3 i2 ld5 kosztowal by taki koles ok 3 pkt.
Pomysł z Afi jest tak trochę dziwny, mam nadzieję, że nie zostanie wprowadzone zamiast AP. A co do nowych jednostek to pewnie jakiś nowy monster i slavy
- Paraszczak
Slejwów nie będzie. Na Druchii.net jest gdzieś wywiad z Gavem i on się tego trzyma.
Patrząc na stare modele do DE, to może być Temple Dog lub Great Eagle.
Ale Eagli bym nie chciał.
Chciałbym jakąś nową maszynę.
pzdr: JP
pzdr: JP
a ja bym chcial aby czarna straz wreszcie wzbudzala w przeciwniku strach a nie tylko dzieki sztandarowi za 75pkt w grze, bo do tej pory to ta jednostka mogla w przeciwniku wzzbudzic co najwyzej smiech......
......chociaz jako moi ulubiency i tak si pojawiali na stolach
Tez widzialem ten wywiad i moim zdaniem, bardzo dobrze, ze nie bedzie zadnych slave'ow, ani to klimatyczne, ani potrzebne.Paraszczak pisze:Slejwów nie będzie. Na Druchii.net jest gdzieś wywiad z Gavem i on się tego trzyma.
